Old 06-18-2015, 11:27 PM   #151
aknovaman
Search youtube for aknovaman to see my other harness vids. They explain how simple it is to build a harness.
aknovaman is offline   Reply With Quote
Old 06-19-2015, 01:41 AM   #152
tinydb84
tinydb84's Avatar
Re: Project "Steppin Wolf" LS swap
aknovaman PM incoming
David
Instagram: myfabguy
Old 06-19-2015, 04:11 PM   #153
Liltroy
Liltroy's Avatar
I paid wait4me performance $360 to redo my harness. since getting it back I have completely torn it apart and redid it. I now know how simple it is and I would never pay to have another one done. Matter of fact, my uncle is talking 5.3 in one of his trucks and Im gonna offer to do his harness for him in exchange for some parts. Yes, its easy...just a bit time consuming but is a days worth of sipping beer and playing with wires worth paying someone almost $400? no.
74 Stepside"Steppin Wolf":78mm Turbo LQ4/4L80e,BTR stage 3 Truck cam,3.73 12 bolt with Detroit True-Trac
Project Steppin Wolf Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=670303
My Youtube channel "Bad Luck Garage" https://www.youtube.com/channel/UCRP...XkeEPCu_HmRfuw
Liltroy is offline   Reply With Quote
Old 06-19-2015, 04:16 PM   #154
Liltroy
Liltroy's Avatar
Aknovaman,
how did you group your harness wires and what am fuse for each set? I was going to group mine like this..
drivers side coil and injectors 15amp,
passenger side coils and injectors 15amp,
ign.ecu,sensors,transmission 15amp,
batt ecu 10amp
does this seem right? thanks for any help
Old 06-19-2015, 04:25 PM   #155
aknovaman
That sounds good. Pm me with your phone number so we can discuss. It's just easier for me that way. Too much typing.
Ls2 Gto actually connects all power on each bank together so there are only 3 power wires. USA gm separates them more into multiple circuits.
Went to u wrench it today and harvested over 30 Taurus relay banks. Not bad for $5 each bank. Last time I snagged over 40 obd ports. I prefer to use the new fuse panels as the wires connect with spade lugs below the fuses and terminals are not exposed to morons who drop stuff on them and short things out. Plus I have not found any suitable fuse panels on USA vehicles.
I did find some relay banks on ford explorers near driver side firewall on fender but they only contain 2 relays. I use 4 relays, main, fuel, fan1 and fan2.
Sunburnt and tired from morning activities.....need ice cream now.......
Current project 1959 Willys = GEZR TRUK
Geezer is a Latin compound word made up of two roots.
Gee meaning Urine Stain and Zer meaning your pants are open!
FMCDH GBU and GBA
http://www.youtube.com/user/aknovaman/videos
Old 06-20-2015, 03:17 PM   #156
Liltroy
Liltroy's Avatar
Aknovaman....thanks for the call and the help. Should have my fuse block done tonight. I'm still kinda confused about transmission but I think it'll make more since when everything is layed out in front of me.
Old 06-21-2015, 12:48 AM   #157
Liltroy
Liltroy's Avatar
got a little done today. Painted transmission..
installed an-6 line adapters...
long one goes in the rear....lol
short one in the front
all done
this is how i avoid scuffing up my aluminum fittings when using a regular wrench...
also i finally installed the last new appliance !!!! finally thats over!!!
MURICA!!!!!
got my fuse/relay box finished today as well but no pics yet....sorry.
Old 06-21-2015, 11:02 AM   #158
OutlawDrifter
Good progress!
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 06-21-2015, 03:11 PM   #159
Liltroy
Liltroy's Avatar
Finished fuse/relay box. I havent wired in the electric fan relay because Ill be running the manual fan starting off.
Also decided to replace the transmission seals. I already had a th400 rear seal laying around and theyre the same part number so I stuck it in there but hafta go buy a 4l80 front seal.
I have been on this earth almost 38 years and have yet to find a humane way to remove these seals,lol
Old 06-22-2015, 07:27 AM   #160
aknovaman
That looks pretty humane to me"..................
FMCDH GBU and GBA
Old 06-22-2015, 11:02 PM   #161
Liltroy
Liltroy's Avatar
sorry for slow progress guys. works kicking my rear right now. hope to remedy that soon though.... on to a few pics
got motor mounts cleaned,painted and installed
drilled,tapped,and installed nipple for steam line in water pump...
This hood latch bracket and bolt were so rusted up i had to put it in a vice and slam the wrench with a small sledge the whole way taking the nut off and the bolt out!!!! spent about an hour on the wire wheel on my grinder cleaning everything up, then painted and looks almost new!
in Glocks write up Im pretty sure he said you could unbolt this fitting on the steering pump and swap it for the fitting on the old one. I thought they were part of the pump. does anyone know for sure before I screw something up???
spending the rest of this week trying to clean up rust and just gonna hit the whole engine bay and frame with some of this rust converter for now.
Sometime down the road when I do my body work and get it painted Ill be replacing or redoing everything under the hood body color. For now I just wanna halt the rust and not put a sparkling engine into a dirty,rusty engine bay...
Old 06-23-2015, 09:32 AM   #162
Jonboy
Slots go on anything!
The P/S pump fitting is legit. It is a lot easier to do on the stand, too.
1974 Jimmy- 5.3/4L80e/NP241
Old 06-23-2015, 11:37 AM   #163
Liltroy
Liltroy's Avatar
That's what I wanted to hear!! No custom ps lines to be made!
Old 06-24-2015, 01:07 AM   #164
tinydb84
tinydb84's Avatar
What did you paint the engine and trans with? They look nice!
David
Instagram: myfabguy
Old 06-24-2015, 07:54 AM   #165
Liltroy
Liltroy's Avatar
Thanks!!! I used Duplicolor engine primer followed by a few coats of duplicolor ceramic engine enamel. Aluminum on block and transmission, cast aluminum on brackets, low gloss and semigloss black on various brackets and pulleys.
Old 06-25-2015, 10:44 AM   #166
Liltroy
Liltroy's Avatar
Well it turns out swapping the bungs on the back of the power steering pumps was unnecessary. My old 1974 ps line screwed right into the 2006 pump. I guess some things never change lol.
Old 06-25-2015, 10:45 AM   #167
OutlawDrifter
either way it's a win!
1991 Z/28, 6.0L/T56
Old 06-25-2015, 05:21 PM   #168
Liltroy
Liltroy's Avatar
Old 06-28-2015, 11:57 AM   #169
Liltroy
Liltroy's Avatar
on call and getting run to death this weekend but I did manage to get the engine and transmission bolted together last night.
but headers were hitting the transmission on both sides
so out came the cuttoff tool
All good now
My helpers
Stayed on that sum-beech for the full 8 seconds,lol
Old 06-28-2015, 12:03 PM   #170
Liltroy
Liltroy's Avatar
Also got my fuel sender converted to AN-6 fittings. I really worry about these compression fittings leaking but there was no other way I could do it. even the local hydraulic shop couldn't make adapter lines for the connections that were on these.
As far as the vent line, should I just cap it off, or should I put some kind of filter on it?
Old 06-28-2015, 03:34 PM   #171
Liltroy
Liltroy's Avatar
Just in case someone didn't know how politically incorrect I am, here's a little shot of the old headliner in project Steppin Wolf. I was actually going to recover it in black vinyl but in light of recent events I think I'll just leave it the way it is.
Old 06-28-2015, 06:49 PM   #172
TrailerTrash
TrailerTrash's Avatar
ive been fallowing this thread since the beginning(lurked for awhile) and i love the detail and how nice everything looks man keep it up
nice head liner
TrailerTrash is offline   Reply With Quote
Old 06-28-2015, 08:38 PM   #173
Liltroy
Liltroy's Avatar
nice head liner
thanks bro!
Old 06-29-2015, 04:43 PM   #174
Liltroy
Liltroy's Avatar
Some luck I got! I sent the first set of plug wires back cause the straight boot hit the headers, just got the new set with 135* boots and turns out I ordered car wires so they're too short! Boxed them back up to send back but didn't want to wait on exchange so I outright bought my third and hopefully final set from summit last night and turns out they're on back order and won't ship till July 8th.
Old 06-29-2015, 04:50 PM   #175
aknovaman
I highly recommend you cut off the tri-angular header flanges and tig weld on some stainless v-bands. Those will leak very quickly and the v-bands will give you more clearance.
The short and long wires come off Camaro and truck applications. The coil output connector is closer to the plugs one of the applications, I forget which.
FMCDH GBU and GBA
