01-23-2016, 11:11 PM | #151 |
Re: FITech Experiences ?
Cool. Hopefully he will post how it is running after he uses it for a while.
I still think I'd like to mount the Fuel Command center on the Rh side somewhere.
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
01-28-2016, 08:35 PM | #152 | |
But Found Her 25yrs Later!
My FCC will be going on the passenger side firewall.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
01-28-2016, 11:01 PM | #153 | |
Posted via Mobile Device |
01-28-2016, 11:05 PM | #154 |
Forget it. You can't legally do it in CA, even though it would make sense and would probably be more fuel efficient.
01-29-2016, 11:21 PM | #155 |
01-30-2016, 12:51 AM | #156 |
01-30-2016, 11:21 AM | #157 |
Never Ending Projects
That is correct. If you have to smog it, whatever parts you put on have to have an EO #.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
01-30-2016, 05:34 PM | #158 |
01-30-2016, 07:08 PM | #159 |
02-01-2016, 11:05 AM | #160 |
http://www.lateral-g.net/forums/show....php4?p=628835
http://67-72chevytrucks.com/vboard/s....php?p=7468628
02-02-2016, 10:35 AM | #161 |
02-02-2016, 10:55 AM | #162 |
Hope this doesn't start happening to everyone
http://www.forabodiesonly.com/mopar/...post1971117741 |
02-02-2016, 11:23 AM | #163 |
So far, that's 3 that we know about that's had issues. All Power Adders.
02-07-2016, 04:01 AM | #164 |
I wonder if it's possible for them to put a password control for the ECU that we could use to lock out the unit
It would be a simple way to prevent the vehicle from starting without your permission.
02-07-2016, 08:22 AM | #165 | |
I might just go the simple route and put a kill switch in line to keep the pump from running. I do that now with my electric fuel pump but the carb float bowls hold enough fuel that you can drive it away before it runs out of gas. I wonder how long the injectors will still squirt without a pump. |
02-07-2016, 01:50 PM | #166 | |
Mopar... |
02-07-2016, 03:35 PM | #167 |
02-08-2016, 04:24 PM | #168 |
Here's their quick reply :
Hi Robert, * We do not have the password control yet, we are looking into it right now. * Thank you,
02-09-2016, 02:49 PM | #169 |
Starting my install later this week.
I hooked up a vacuum gauge. I'm glad to see I'm actually getting 15 at idle. Last time I checked, I seem to remember only about 10 or 11.
02-10-2016, 04:48 PM | #170 |
02-12-2016, 08:12 PM | #171 |
Here's an interesting tool for the hose fittings:
https://youtu.be/MQMpcZNpOjQ
02-12-2016, 08:29 PM | #172 |
A method for angle fittings :
https://youtu.be/iPTTX1llORk
02-13-2016, 12:18 PM | #173 |
I bought an in cab heater so I could mount the FCC on my firewall. I don't think I like the look.
I'll keep it there to get up and running, but I'll eventually either hide it in the under hood heater box, or move it to the radiator support - opposite side of the battery - where most guys mount it.
02-13-2016, 12:40 PM | #174 |
Agree, core support is where I am planning to install mine.
02-13-2016, 12:47 PM | #175 | |
