Old 04-05-2016, 08:39 AM   #151
Bennett68C10
Bennett68C10's Avatar
Re: Project "Redemption" 68 SWB Fleetside
Got my Boyd's tank in last night! Went with black powder coat Thanks to AZ Pro Performance for the hookup!
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 04-05-2016, 08:41 AM   #152
boostedc10
boostedc10's Avatar
Keith if you need any help with rear end stuff let me know. I have done a ton of them.
Brandon
Instagram: DRVFSTR
Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691
boostedc10 is offline   Reply With Quote
Old 04-05-2016, 06:31 PM   #153
69short
69short's Avatar
The tank looks nice. I need to order one soon. I like the black powder coat. I hate to see how much that is going to set me back lol
69short is offline   Reply With Quote
Old 04-05-2016, 07:51 PM   #154
jeh
jeh's Avatar
That's the first Boyd's tank I've seen in black, looks good!!
Jason
'70 C-10 short fleet 427BB TH400 (SOLD)
'10 Ford F 350
'13 Ford RAPTOR 6.2
MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623
jeh is offline   Reply With Quote
Old 04-05-2016, 09:09 PM   #155
trkfrk
trkfrk's Avatar
Great to see your project moving forward on a steady pace. Great choice on the Boyd's fuel tank.
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 04-06-2016, 07:44 AM   #156
mcbassin
Still Learning
mcbassin's Avatar
Very nice looking tank!
mcbassin is offline   Reply With Quote
Old 04-06-2016, 08:18 PM   #157
Bennett68C10
Thanks, I appreciate it. I'm doing some research now. What gears are you planning on running with your 4L80e?
It was a pretty good chunk of change especially since I got the EFI tank with the Aeromotive intank fuel pump.
Thanks Jason, I wanted to do something a little different then the one I had in my last truck which was bare aluminum. I think it looks pretty good I also got this one with center fill instead of offset to the side.
Thanks Mark, hope to get the rear frame crossmembers out this weekend. Then I'll be ready for my Porterbuilt parts.
Keith
66 Suburban
IG: bennett68c10
Old 04-06-2016, 08:19 PM   #158
Bennett68C10
Thanks Mike, I really like the black powdercoat
Keith
66 Suburban
IG: bennett68c10
Old 04-06-2016, 09:11 PM   #159
boostedc10
boostedc10's Avatar
I'm running 3:42s with an eaton posi for my turbo setup
Brandon
Instagram: DRVFSTR
Old 04-06-2016, 09:44 PM   #160
shores6
shores6's Avatar
I also opened up the rear and pulled the factory 6 lug axles! I have a open peg leg rear which means it will definitely get rebuilt with a new posi and gears! Any opinions on what posi to go with?
I went with the Detroit tru trac and Yukon 3.73. The 3.73 is a little on the low side for my turbo application but you can't beat them if you're motor only.
shores6 is offline   Reply With Quote
Old 04-08-2016, 08:56 AM   #161
Bennett68C10
I plan on staying motor only for a while, I would love to do a turbo setup but it's not in the budget plus I would have to swap my new cam out for a turbo friendly cam! I'm trying to decide on either 3.73's or 4.10's for the rear!
Keith
66 Suburban
IG: bennett68c10
Old 04-08-2016, 09:31 AM   #162
boostedc10
boostedc10's Avatar
No need for a 4:10 with a 4l60e in my opinion, I would stick with a 3:73.
Brandon
Instagram: DRVFSTR
Old 04-08-2016, 12:29 PM   #163
aggie91
I'm just glad to be here!
aggie91's Avatar
We did the 4:10's with a 4l60e in Sunburn and now again in White Trash. In hind sight we should have gone with 3:73's. It would give good performance and better MPG as we drive WT much more. Korbin drive about 30 miles one way each day for school....
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 04-08-2016, 08:28 PM   #164
Bennett68C10
Thanks for the input Brandon, I just want to make sure I do it right the first time as I don't plan on opening the rear back up after its done unless I have to!
I don't have to worry about daily driving this truck but I am starting to think the 3.73's might be the best choice! I did a rpm calculator and with 3.73's I would be turning a little less then 2000 rpm at 70! 4.10's would put me around 2200 rpm at the same speed!
Keith
66 Suburban
IG: bennett68c10
Old 04-08-2016, 08:52 PM   #165
jeh
jeh's Avatar
Kieth, from my experience with a 700r4 I think 4.10's would be to low. The 3.73 rear in my truck seemed just right on the interstate. (Just my thoughts)
Jason
'10 Ford F 350
'13 Ford RAPTOR 6.2
Old 04-09-2016, 04:51 PM   #166
Bennett68C10
Thanks Jason, it seems like everybody is suggesting 3.73's! I still need to figure out whether I'm going to run a 4l80e or 4l60e before I decide on the gears!
Keith
66 Suburban
IG: bennett68c10
Old 04-09-2016, 04:53 PM   #167
69short
69short's Avatar
I'm running a 4l80e with 3.73 gears. Obviously I have yet to drive it though lol
Old 04-09-2016, 04:54 PM   #168
Bennett68C10
Got all the crossmembers out today except for the one all the way in the rear! I'll remove that one after I install my Dropmember! My air hammer made quick work of the rivets!
Keith
66 Suburban
IG: bennett68c10
Old 04-09-2016, 04:55 PM   #169
Bennett68C10
3.73's seem to be the popular choice!
Keith
66 Suburban
IG: bennett68c10
Old 04-09-2016, 04:59 PM   #170
Bennett68C10
Also got the steering rack installed! I need to figure out what the thread size is for the tie rods because I need to trim a little off! It's a little to long right now and it's pitching the toe out in the front on the brake rotors! My rack didn't come with any jam nuts! Any body have a clue what size the thread is? It's a CPP rack!
Keith
66 Suburban
IG: bennett68c10
Old 04-09-2016, 05:10 PM   #171
69short
69short's Avatar
Mine did not come with jam nuts either. I just have a jam nut between the PB piece that screws to the tie rod and the joint that bolts to the spindle. I didn't even think about a nut on the other end but it sounds like I need one.
Old 04-09-2016, 05:12 PM   #172
69short
69short's Avatar
You could take your PB piece to the hardware store to find the right size bolt that threads in. Then you'll know what size nut you need. I can't remember if it is reverse threads on the tie rods?
Old 04-09-2016, 05:27 PM   #173
69short
69short's Avatar
Sorry I forgot you're not using the PB dropmember in the front. Lol my bad
Old 04-09-2016, 08:26 PM   #174
Bennett68C10
I know what you meant! I did take my adjusting sleeve to Lowes but they didn't have anything nearly bid enough to fit the threads! I'm going to have to try somewhere else I guess! You are correct though, it is reverse threads!
Keith
66 Suburban
IG: bennett68c10
Old 04-11-2016, 12:44 AM   #175
SierraMtns
SierraMtns's Avatar
Hey Keith,
Thanks for sharing this build with us. I will be tagging along. I know how you feel about waiting for parts. I order a rear drop member kit for my pro touring build from PB in March. Man the waiting is rough. June cant come fast enough.
SierraMtns is offline   Reply With Quote
