Old 04-25-2019, 11:33 PM   #151
j.kirn
Re: 66 k20
Originally Posted by jdl71 View Post
I bought a 4:10 ho72 last weekend and I’m going to pick up another later this week don’t know what ratio yet. Haven’t done any more.
never heard of a 4.10 gear ratio in a HO72, I have seen them in a HO52
j.kirn is offline   Reply With Quote
Old 04-26-2019, 08:46 PM   #152
jdl71
jdl71's Avatar
Re: 66 k20
It was in a 70 3/4 ton 4x4. Has the adjuster bolt on the yoke which I thought only the ho72 had. 41 10 stamped on the ring gear. Guess someone could have regeared it but the front axle was 4:10 also
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 04-26-2019, 08:48 PM   #153
jdl71
jdl71's Avatar
Re: 66 k20
I picked up another Eaton today, this one stamped 7-32, just what I need. Seems pretty tight and looks good. Not sure what I’m going to do with the 4:10 just yet.
Psalm 23
64 C10
66 K20
Old 04-26-2019, 08:54 PM   #154
jdl71
jdl71's Avatar
Re: 66 k20
Ever since I’ve put this bed on, it’s bothered me that it’s so crooked. I figured the bed was jacked up somehow or it was due to some of the wood missing. I broke out the tape measure and found that one frame rail is higher than the other over the axle. So I’ve got a weak or broken spring, right? No. 8 leaves on the right, 7 on the left.
Psalm 23
64 C10
66 K20
Old 04-27-2019, 12:36 AM   #155
Captainfab
60-66 Nut
Re: 66 k20
Have you also checked your rear cab mounts?
Old 04-28-2019, 09:54 AM   #156
jdl71
jdl71's Avatar
Re: 66 k20
Yes, the cab is level. I've got 2 different size spring packs on the rear for some reason.
Psalm 23
64 C10
66 K20
Old 04-28-2019, 09:13 PM   #157
Short 3/4
Re: 66 k20
While your messing around with that rear end, can you take some pictures of the rear brakes and hubs etc. Long story, but I don't have the stock K20 rear brakes on mine and they are unique to that model (I'm using C20 rears now). Been looking for a long time and a picture or two would help me remember what they are suppose to look like if I find them. Several K10s in this area, but haven't seen a stock K20 around here in a couple of decades. Yours should be 12x2" with slide on drums, like on the front.
Tom
65 short stepside K10
292-SM420-T221
8 lug closed D44 front
NoSpin HO72 4.10 rear
Short 3/4 is offline   Reply With Quote
Old 04-28-2019, 11:25 PM   #158
j.kirn
Re: 66 k20
A H052 is a 3/4 ton , a HO72 is a 1 ton axle
Old 04-29-2019, 01:31 PM   #159
jdl71
jdl71's Avatar
Re: 66 k20
Tom
Go back to post #50. I bought new drums from rockauto I believe.
Psalm 23
64 C10
66 K20
Old 04-29-2019, 01:38 PM   #160
jdl71
jdl71's Avatar
Re: 66 k20
Was there an HO52 with the load bolt?
Psalm 23
64 C10
66 K20
Old 04-30-2019, 11:29 AM   #161
Short 3/4
Re: 66 k20
Oh ya, forgot about that discussion. From your pictures it looks like you may have 2wd set up like me. K20 should have rear drums that just slide off the lug studs to remove (like in front) your pictures look like the kind that have bearings inside drum, so you have to remove the large adjusting nut to remove the drum. Am I seeing that right? Correct drums should be 12x2" like front, but with a slightly different offset.
292-SM420-T221
Old 04-30-2019, 01:35 PM   #162
jdl71
jdl71's Avatar
Re: 66 k20
You are seeing it correctly. Wheel studs are pressed into the drum and the hub nut has to be removed to get the drum off. They are 12x2 and use the same shoes as the front. I don’t know what was supposed to be on there but they looked original and the new drums I ordered were for a K series truck. May be the same application for 2wd also not sure.
Psalm 23
64 C10
66 K20
Old 04-30-2019, 11:28 PM   #163
j.kirn
Re: 66 k20
yes
Old 05-02-2019, 08:32 PM   #164
jdl71
jdl71's Avatar
Re: 66 k20
yes
I stand corrected then. I was under the impression only the 72 has that.
Psalm 23
64 C10
66 K20
Old 05-02-2019, 11:37 PM   #165
raylube
raylube's Avatar
Re: 66 k20
I believe my truck has 6 leaves per side. ,make sure your shocks are not siezed causing the lean or binding spring shackles.
raylube is offline   Reply With Quote
Old 05-03-2019, 01:41 AM   #166
Short 3/4
Re: 66 k20
I wonder if that was a 66 thing. Mine was out of a 64 K20 and definitely had 12x2 slide on drums. All I've read says they were all that way, but I'm still learning. Anybody out there know what the story is? Would love to find out.
Thanks for the info
Tom
292-SM420-T221
Old 05-03-2019, 02:37 PM   #167
straight6chevyguy
straight6chevyguy's Avatar
Re: 66 k20
I like these nmo antennas, they flex easily and don’t look obnoxious. I don’t know if this is ideal mounting spot (I know the middle of the cab would be best) but I’m going to try it a while.
Since it looks like the antenna sticks up above the cab it should work ok but you really wont know until you try it.
Sometimes short antennas that are shorter than the height of the cab tend to have some of the signal blocked or sometimes wont tune correctly because of funny signal reflections from the metal truck cab being right next to the antenna.
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1998 chevy c1500 4.3L 5speed (My current driver)
2002 Chevy s10 4.3L auto 4x4
1971 mercury monterey wagon 400 auto
To many projects!
straight6chevyguy is offline   Reply With Quote
Old 05-13-2019, 09:07 PM   #168
jdl71
jdl71's Avatar
Re: 66 k20
Putting that fender on made the rusty rocker stick out, which required cab support, inner floor,etc. I know I should have done the cab corner also but I had to stop somewhere for now. I still need to finish patching in the rear section of floor also.
Psalm 23
64 C10
66 K20
Old 05-13-2019, 09:15 PM   #169
jdl71
jdl71's Avatar
Re: 66 k20
I probably would have been ok stopping here but since that fender wasn’t fully bolted on and I have this spray gun I got at a thrift store a few years ago, and I finally have a real air compressor, I figured now was as good a time as any to learn to paint.
Psalm 23
64 C10
66 K20
Old 05-13-2019, 09:18 PM   #170
jdl71
jdl71's Avatar
Re: 66 k20a
Not sure what I did wrong but the second coat on on the fender ended up with some orange peel. I’m not gonna kick myself too hard since I’ve never held a spray gun before, was painting outside on a cloudy day and it should wet sand sand out anyway.
Psalm 23
64 C10
66 K20
Old 05-13-2019, 09:22 PM   #171
jdl71
jdl71's Avatar
Re: 66 k20
And finally, I had a friend of mine reproduce these old dealership stickers with her cricuit machine. She knocked it out of the park.
Psalm 23
64 C10
66 K20
Old 05-14-2019, 04:27 PM   #172
straight6chevyguy
Re: 66 k20
Nice! I love that green!
To many projects!
Old 05-14-2019, 07:02 PM   #173
72cs20
Re: 66 k20
You've been busy. Nice work on the rust damage.
Any details on the fender fitment? I'm thinking of getting new ones too.
1966 K20 flatbed build thread - http://www.67-72chevytrucks.com/vboa...d.php?t=768827
62 C20 build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=703583
72cs20 is offline   Reply With Quote
Old 05-14-2019, 07:35 PM   #174
jdl71
jdl71's Avatar
Re: 66 k20
It really wasn’t too bad. I had to kind of roll it over to get the top bolts under the hood to start and they still aren’t great but some of it could be my truck also. It’s a goodmark fender I ordered from rockauto.
Psalm 23
64 C10
66 K20
Old 06-08-2019, 10:59 AM   #175
jdl71
jdl71's Avatar
Re: 66 k20
New rear 8 leaf rear springs, pins, shackles and bolts. Quite an ordeal but it sure did that improve the stance.
Psalm 23
64 C10
66 K20
