Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1967-1972 Chevrolet & GMC Pickups Parts Board > Blazer and Suburban Stuff
Old 01-08-2018, 06:29 PM   #151
jaybatta
jaybatta's Avatar
Re: Yet another 72 going under the torch, factory 3 speed on the tree!
Originally Posted by 1rippen6 View Post
Mike passed on the set in the other thread, there is close ups of the chrome rings. The one isn't bad the other has some pitting and marks.
Yea I think I saw those, I was wondering if these were any better
Joe
1968 K20
1970 K20
Semper Fi
jaybatta is offline   Reply With Quote
Old 01-08-2018, 08:44 PM   #152
mortoyz
Active Member
Do you have a set of the front hold down brackets?
mortoyz is offline   Reply With Quote
Old 01-08-2018, 11:02 PM   #153
1rippen6
For the top? if so yes
1rippen6 is offline   Reply With Quote
Old 01-08-2018, 11:03 PM   #154
1rippen6
Sorry the other set isn't any better.
Old 01-08-2018, 11:08 PM   #155
2006gmcdmax
I should have the plates give me a couple days to look, sorry no bolts but they are 7/16 NFT
Any updates yet on this topic?
2006gmcdmax is offline   Reply With Quote
Old 01-08-2018, 11:12 PM   #156
mortoyz
Active Member
Sorry about that. Yes, for the top.
Old 01-08-2018, 11:14 PM   #157
1rippen6
Attachment 1737966
I took some pictures of what I have tonight will post soon. I don't have the exact ones for the seat but have the 7/16 fine ones for the inside spare tire carrier. I'm not sure if they look the same but have the same thread size. Just realized something as I'm typing this I have another blazer that I'm going to part that had a rear seat. I will make sure tomorrow that I didn't already cut them out and let you know.
Old 01-08-2018, 11:17 PM   #158
2006gmcdmax
I had already purchased the rear seat brace from you several months ago and I realized that I need these front two mount which I believe that they are the same as the inside spare tire mounts too. Thanks 1rippin6.
Old 01-08-2018, 11:19 PM   #159
2006gmcdmax
I had already purchased the rear seat brace from you several months ago and I realized that I need these front two mount which I believe that they are the same as the inside spare tire mounts too. Thanks 1rippen6.
Old 01-08-2018, 11:31 PM   #160
1rippen6
32 shipped I can grab some pictures if you like.
Old 01-08-2018, 11:39 PM   #161
1rippen6
Originally Posted by chevyguy_72 View Post
Is the floor in this any good? I mainly need the outside front seat riser from each side... the PO chopped up the seat mounting plates under the floor to put in a different seat... once i removed the new seat mount pretty much everything is swiss cheese on both sides...
Not sure how much you need but here is what they look like
Old 01-09-2018, 06:16 PM   #162
mortoyz
Active Member
If you could please.
Old 01-09-2018, 11:21 PM   #163
1rippen6
Here you go.
Old 01-09-2018, 11:22 PM   #164
1rippen6
I got home after dark will take a look tomorrow.
Old 01-09-2018, 11:27 PM   #165
mortoyz
Active Member
Here you go.
Thanks. I’ll take em. Do you happen to have the plate that goes under the latch assembly on the hatch?
Old 01-09-2018, 11:52 PM   #166
1rippen6
I should have one but have looked a couple of times and can't find it.
Old 01-09-2018, 11:56 PM   #167
smbrouss70
smbrouss70's Avatar
Did you ever get a chance to check on those hatch latches?
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 01-10-2018, 12:00 AM   #168
1rippen6
Sorry, I didn't I will try to get to it tomorrow.
Old 01-10-2018, 09:50 AM   #169
Purple67C10
Received parts yesterday. Thanks again.
Purple67C10 is offline   Reply With Quote
Old 01-10-2018, 10:48 AM   #170
1rippen6
Awesome, good to hear!
Old 01-10-2018, 07:39 PM   #171
1rippen6
Sorry didn't get home until after dark again, its suppose to be 50 degrees Friday so I will get you an answer by this weekend.
Old 01-10-2018, 08:17 PM   #172
2006gmcdmax
Sounds good, thanks.
Old 01-10-2018, 09:58 PM   #173
1rippen6
Pulled the latches 1 is ok the other needs the spring replaced which I can do. I grind the crimped end off replace the spring and then I weld the pin in. Works good as new and the weld can be ground off if it would need worked on again. Let me know if still interested and I can get it repaired this weekend.
Old 01-10-2018, 10:26 PM   #174
smbrouss70
smbrouss70's Avatar
How much would that be?
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 01-11-2018, 08:32 AM   #175
1rippen6
80 for the latches
