Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 03-12-2018, 09:44 PM   #151
BlueBullet
BlueBullet's Avatar
Re: Big Bird - 1972 Longhorn K30
Not a lot of progress tonight. I ran and picked up my drive shaft. Went from shorting and new tubes to completely new shafts. Everything else on my old shafts where bad. The u-joints where obviously bad and the splines had enough wear that it would have viberated at high speeds. Also got the sill plates installed and saddle blanket seat cover. What's an old farm truck with out one.
1972 K10 SWB wife's driver
1967 Pontiac GTO
http://67-72chevytrucks.com/vboard/s...d.php?t=753294
BlueBullet is offline   Reply With Quote
Old 03-13-2018, 08:34 PM   #152
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
That stinks about the drive shafts but at least you saved yourself the headaches of fighting it now.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 03-15-2018, 04:00 PM   #153
DWilbur
Would you happen to have a picture of the drive shaft center bushing mount. I had to make my rear drive shaft 2 piece similar to yours and I'm trying to figure out best way to build support. Thanks
DWilbur is offline   Reply With Quote
Old 03-15-2018, 09:10 PM   #154
BlueBullet
BlueBullet's Avatar
Red face Re: Big Bird - 1972 Longhorn K30
DWilbur here are some pictures. Notice the side picture. The mounting location is at an angle towards the back as to help with driveline angle I would geuss. Can also kind of see it in the last picture.
1967 Pontiac GTO
Old 03-15-2018, 09:21 PM   #155
BlueBullet
BlueBullet's Avatar
Slow progress. Was putting in the rest of the fluids and noticed liquid on top of the water pump where the heater core is connected. There was a hair line crack.. New pump came in today. Napa stood behind it. Got the bumper hung for motivation and got the cowl installed. Tomorrow hopefully get the Bird to take flight.
1967 Pontiac GTO
Old 03-16-2018, 10:27 AM   #156
DWilbur
That helps a lot. I have to build a cross member this week end.
Old 03-16-2018, 12:56 PM   #157
First c10
First c10's Avatar
DW,
FYI....
I sent you a PM and it reads that your PM box is full and you cant receive a message until you make space by deleting messages
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 03-16-2018, 05:04 PM   #158
DWilbur
Originally Posted by First c10 View Post
DW,
FYI....
I just cleaned it out. try again.
Old 03-20-2018, 09:37 PM   #159
BlueBullet
BlueBullet's Avatar
Firday night I woke Big Bird up from his slumber. Splash of gas and a turn of the key and popped right off. Still need to get the timing dialed in. Will be doing that Thursday night and also getting the brakes bled so Bird can be mobile to get the bed on. In the meantime I got the driveline installed, front bumper mounted and the interior finished for the most part. I am having issues with the blinkers but the flashers work. Also the horn doesn't work but I tested it by itself and she honks. I am thinking it's in the column harness or blinker lever possibly. Once I get the column put back together I will be putting on a better horn button. Anybody have any ideas let's hear them. I am sloooowwwly getting the electrical system figured out on these trucks. I cleaned up some black door panels and got some duri color paint and painted some medium green armrests. I will have to say they turned out pretty good. I was in a zone so I forgot to get before pictures. Almost forgot but also installed dealership tags. Big Bird didn't have any but the other truck I got at the same time did. They were also sold at the same dealership.
1967 Pontiac GTO
Old 03-23-2018, 10:46 PM   #160
BlueBullet
BlueBullet's Avatar
Got started on mocking up the bed frame. I am going to try and get some of the tilt bed pieces done at the same time for ease in the future. Hopefully get brakes bled and timing dialed in this weekend.
1967 Pontiac GTO
Old 03-24-2018, 01:54 PM   #161
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Coming along really nicely Nathan, Curious how your hoist setup will look like and hook up.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 03-24-2018, 07:36 PM   #162
BlueBullet
BlueBullet's Avatar
I am working that through my head right know. I have somewhat of a plan. Where I am hung up on is how to set up front mount. Here is some pictures of some of the pieces. I am basically mount it like the C50 donor. Just with the frames being different the front has to be thought through what is going to be strong enough. A friend of mine has some thoughts on what I can use as a power source. He has something at work that might work. . If that works out I might just put in the hoist right away. Its about the same amount of steps to make happen. The front tube on the hoist assembly is the reservoir. Pretty cool I thought. I am getting pumped.
1967 Pontiac GTO
Old 03-24-2018, 07:56 PM   #163
BlueBullet
BlueBullet's Avatar
In the back I am going to make a pillow block similar to the one in the rear shackle of the front springs. That should be stout enough for the rear. For the front so far if it works out where the front angle irons line up with the cross support I will attach there. Today we got Bird chirping and moving. Got the timing dialed in and brakes bled. Has plenty of brakes. Hang on!! Got the hood mounted. Need to dial that in a bit yet. Tried a little and got it close enough for know. Drove over to shop to wash the hood and take a progress picture. Came along ways.
1967 Pontiac GTO
Old 03-24-2018, 10:57 PM   #164
BlueBullet
BlueBullet's Avatar
Had an exciting morning also. Thank God I had layers on. Cleaning up the heavy angle iron and the grinder kicked back and I wasn't quite fast enough.
1967 Pontiac GTO
Old 03-24-2018, 11:02 PM   #165
too much stuff
Roadtrip!
too much stuff's Avatar
Not sure why you would want to grind on your belly! Trucks looking good.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 03-25-2018, 05:25 PM   #166
BlueBullet
BlueBullet's Avatar
Got the starting of the frame work installed on the Bird. Then cleaned up the hoist assembly and set it in between the rails to get a visual. Next was on with the bed to start figuring how to lay everything out.
1967 Pontiac GTO
Old 03-25-2018, 05:42 PM   #167
BlueBullet
BlueBullet's Avatar
I think I have the back figured out. Here is a picture of the back pivot mocked up. For more support I will add a similar piece to the inside of the frame. The front is where I am hung up on. In the picture below the two half inch holes on the side almost above the factory frame cross member is where the top hinge point was located. If I was to leave it in the same location I will need to figure out how I am going to support the bottom hinge point. If I leave it in the position that I mocked up the hoist assembly in I have the cross member I made for support. I will also be adding wood or metal under the heavy angle iron.
1967 Pontiac GTO
Old 03-27-2018, 09:47 PM   #168
BlueBullet
BlueBullet's Avatar
I didn't like the heighth of the bed so I cut down the main beams 3". I think it looks better and still have room for settling and bigger tires.
1967 Pontiac GTO
Old 03-27-2018, 10:10 PM   #169
DWilbur
The bed looks much better lower. The gap from the front tires to fender looks about the same from the rear tire to the bed.
Old 03-27-2018, 10:36 PM   #170
BlueBullet
BlueBullet's Avatar
Thanks for the reply. I also like how the bottom of bed is in line with lower body line and if I keep the sides they flow with the top side of the truck better. The bed needs to be moved a little more forward. I will also be building a headache rack. Now to refigure how to set up the hoist and frame work.
1967 Pontiac GTO
Old 03-29-2018, 11:14 PM   #171
BlueBullet
BlueBullet's Avatar
Got the front of the house assembly mounted to the frame. Not sure if it is the right route to go but that is what I have for room without modifying the frame cross member. I would rather not do that we will see how it or if it works. I will be replacing the 2x4's with a heavy piece of angle iron for support in the rear.
1967 Pontiac GTO
Old 03-29-2018, 11:21 PM   #172
BlueBullet
BlueBullet's Avatar
Here's a picture of the front bottom mounting plate for the hoist frame. It is being held up by chains. Once the chains were taken off the hangle irons dropped into the position I attached them in so I just went with it.
1967 Pontiac GTO
Old 03-30-2018, 05:15 PM   #173
Dieselwrencher
That looks so nice! Nice work getting the bed to fit on there.
Ryan
Old 03-30-2018, 11:53 PM   #174
BlueBullet
BlueBullet's Avatar
Thanks Ryan!! It's really coming together now. I think I put so much thought into everything lately that I have to adjust my hat a little bigger.. Well today I gave the guys the day off at noon for the Easter holiday and worked on the Bird. To get the bed dropped I cut the C channels in half that where running down the frame. I then flipped them over and welded them back on. Now I have roughly a 2.5"x2.5" main beams running down the bed. Once welded I added rubber belting to the bottom with decking screws. Then it was back to the chassis. I added another cross member below hoist for support and also added a top rear support. After noticing the location of the new bottom cross member I may have to redesign my bump stops. I was on cruise control. Then I set the bed back on and admired my work. The oil on the floor is from the hoist. Once I get the front set into place I will be adding plugs until I get my power source figured out. Hopefully tomorrow I can get the bed pivot done and possibly the top hoist frame finished. Easter number 1 starts tomorrow at 1. Once those are done I will get an appointment set for exhaust and get working on headache rack.
1967 Pontiac GTO
Old 03-31-2018, 05:19 PM   #175
BlueBullet
BlueBullet's Avatar
Got started on the rear pivot. I am going to make a plate inside the frame rails for extra support. Also noticed that I have to remove the rear side bolt behind pivot bracket because it's in the way for pivoting. The inside plate will fix that also. I added another piece of C channel on top of main beams for more support for outer bracket.
1967 Pontiac GTO
