03-26-2018, 04:51 PM | #1 |
Always on the hunt...
F/S OE 72 Big Block Parts, Brackets, Stove Pipe, Air Cleaner, Towers and/or Request?
Large group of OE big block short water pump parts removed from BBC 396/402 trucks, no bracketry guesswork here, all guaranteed complete and correct original parts. All of the below listed pricing is plus shipping, if interested funds can be sent via paypal, venmo, check or money order, if using paypal option buyer covers fee's. Thanks for looking, Mel
***Update, we have decided to let this big block parts F/S thread run and will add parts to it, so for any other BBC parts needs, year specific request or for single bracket or pulley needs just inquire/ask in thread, if on hand we can add pictures and pricing info here in the F/S thread.*** BBC full 9 pc. A/C compressor bracket setup $395., will sell as a 7 pc. setup w/o rear rod & exh. manifold brace for $325. ***Qty. 4 Sets Sold/Shipped*** BBC 3 pc. A/C pulley set: 2 groove w/p pulley, 2 groove inner crank pulley and 1 groove outer crank add on p/s pulley. $195. ***Qty. 5 Sets Sold/Shipped*** We do have more BBC pulleys pulled/available, just ask. BBC 72 LH/RH Tower set w/clam shells and clam shell to motor mount bolts. $250. ***Qty. 4 Setups Sold/Shipped*** We also have 68-71 style BBC stands pulled/ready to ship. ***09/15/21 Update*** We have added another 72 BBC tower setup in post #150. BBC 72 3 pc. alternator mounting bracket setup. $175. ***Qty. 5 Sets Sold/Shipped***We do have more pulled/ready to ship. BBC Air cleaner and spacer setup, riser has both OE tower clamps yet and correct arrestor to valve cover tube. ***Sold/Shipped*** BBC Exhaust manifold heat shield and stove pipe setup. $275. ***Qty. 2 Setups Sold/Shipped*** ***02/27/23 Update*** We have added another complete OE 70-72 BBC LH exhaust manifold heat shield tin and stove pipe setup in post #186 BBC Remote fill P/S pump setup with both mounting brackets, pulley on pump and fill reservoir w/cap. $300. (pictured in post #11) ***Qty. 4 Setups Sold/Shipped*** ***11/24/21 Update*** The below listed BBC pulley setup and the BBC 70-71 style alternator brackets that are pictured in post #168 are now available to anyone interested, we also just added some BBC/TH400 auto high hump tunnel covers to thread in post #169 BBC 3 pc. pulley setup (Non-A/C) including w/p pulley, inner crank pulley and add on outer crank pulley for p/s. $195. (pictured in post #168) BBC 70-71 style 2 pc. alternator mounting bracket setup. $150. (pictured in post #168) BBC 68-71 style LH/RH engine stand/tower set. $125. (pictured in post #175) BBC/Th400 high hump bolt in transmission tunnel covers in 506 dk. olive & 516 orange, pictured in post #169. $135. ea. ***Qty. 2 Sold/Shipped*** . ***For any return/past customers & friends*** Before sending of any funds, please wait for a confirmed total and instructions for sending as our paypal account & info has been changed as of Jan. 2022. Thanks... Last edited by Classic Bowties; 02-27-2023 at 06:56 PM. Reason: Updated availability |
03-26-2018, 04:57 PM | #2 |
Re: F/S OE 72 Big Block Parts, Brackets, Stove Pipe, Air Cleaner, Towers and/or Reque
More pics...
08-12-2019, 06:41 AM | #3 |
Do you have a clutch pivot bracket. The one on side of block
03-26-2018, 05:03 PM | #4 |
Do you have any power steering brackets available for 72 402 ? Thank you!
03-26-2018, 05:19 PM | #5 |
Yes, was still waiting to hear back from BLT-NT-BOT on that other BBC P/S setup that was added/offered in his WTB thread, if he passes on it you are up next on the whole setup, or are you only needing the two BBC SWP remote fill p/s pump mounting brackets? Mel
03-27-2018, 10:54 AM | #6 | |
03-27-2018, 12:13 PM | #7 |
05-28-2021, 07:59 PM | #8 |
I need a set of pulleys for a bcc with air ,also a set of bbc exhaust manifolds, please let me know if you have any, thanks Adam, o by the way you need to clear some messages from your PM
03-27-2018, 05:00 PM | #9 |
We can get the 72 BBC P/S setup with both mounting brackets, pump pulley, and remote fill reservoir w/hose to you in CA. 93436 for $23.61 shipped via FedEx ground, total transit time will be 2 days. The provided address is a commercial/business listing correct? A non-residential/commercial address was used for the above quote and it does affect the shipping charge when using FedEx. Will return our info now for sending payment via paypal. Thanks, Mel
03-28-2018, 08:19 PM | #10 |
The BBC power steering setup shipped out via FedEx on Wed. 03/28, as of this evening the FedEx website is projecting that you should see the box on Fri. 03/30 by the end of the day. We had to swap out the lower pump cradle bracket because the one that was originally pictured (installed on truck yet) was cracked and was being held together while everything was tight, once I loosened the bolts up to remove the setup the broken ear fell off, see red arrow. I sent the top pictured OE BBC p/s lower cradle bracket in its place. Thanks again, Mel
03-26-2018, 10:23 PM | #11 |
Per your reply in that other thread, you are next up on this BBC remote fill P/S setup at $275., can have the setup pulled and shipped within 24 hours of payment, will need a zip code to figure your shipping options out. Thanks, Mel
03-27-2018, 12:21 PM | #12 |
03-26-2018, 05:24 PM | #13 |
“On The Hunt”
Do you have an entire set up for a short water pump big black? If so I’ll take it
03-26-2018, 05:38 PM | #14 | |
03-26-2018, 05:55 PM | #15 |
“On The Hunt”
All Brackets and pulleys for Alternator, air conditioning and power steering 68-69 Would probably be preferred if possible
03-26-2018, 06:10 PM | #16 |
Does the air cleaner have pretty nice original paint? And would you just sell it by its self? Thanks
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
03-26-2018, 06:42 PM | #17 |
I will take the 3- piece alternator brackets
72 Cheyenne Super 350 Holley EFI/700R4 67 Camaro SS/RS 68 Corvette 427 Tri-power 4-speed convertible 55 Chevy Belair Hardtop |
03-26-2018, 10:35 PM | #18 |
03-26-2018, 10:57 PM | #19 |
Wes, if it gets to me I'll take them both. Thanks
03-26-2018, 09:43 PM | #20 |
I will take the following. Please send PM with payment info. Thanks
$125. / Air cleaner and spacer setup, riser has both OE tower clamps yet and correct arrestor to valve cover tube. $225. / Exhaust manifold heat shield and stove pipe setup. |
03-26-2018, 10:48 PM | #21 |
We can ship this setup to you via USPS priority large box for $18.90, let us know how you would like to send payment and we will get that info returned to you. Thanks
Okay, will need a shipping Zip to figure out your FedEx shipping cost, confirm if residential or commercial/business for the ground shipment quote. The payment options are listed in the first post, let us know your preferred method and we will return that info to you. Thanks, Mel |
03-26-2018, 11:08 PM | #22 | |
I can PayPal you tonight......let me know your papal address
03-27-2018, 06:18 PM | #23 |
We can get the above requested BBC parts to you in MI. 48451 for $39.55 shipped via FedEx home delivery/Res. (23" x 20" x 7" @ 12 Lbs.), total transit time will be 4 business days. Will fwd the info now for sending payment via paypal. Thanks, Mel
03-28-2018, 11:12 PM | #24 |
Your box has been shipped out via FedEx on Wed. 03/28, as of this evening the FedEx website is projecting that you should see the box next Tue. 04/03 by the end of the day. Thanks again, Mel
03-27-2018, 02:19 AM | #25 | |
$375. **SOLD** Full big block 9 pc. A/C compressor bracket setup or $300. on this as a 7 pc. setup (w/o rear rod & exh. manifold brace) $150. **SOLD** 68 big block with A/C 3 pc. 2 groove water pump, 2 groove inner crank and 1 groove outer crank pulley setup. $125. **SOLD** 68 big block 2 pc. alternator bracket setup. $150. **SOLD** 68 big block air cleaner and spacer setup, riser hose has both OE tower clamps and correct crank case vent to valve cover arrestor. $375. **SOLD** 68 big block P/S pump, both brackets, pulley on pump and remote fill reservoir can w/one year 68 fender ext. bracket, will take $300. on this setup (w/o reservoir ext. bracket) . Last edited by Classic Bowties; 01-15-2020 at 01:38 PM. |
