Old 01-17-2021, 02:09 AM   #151
72cs20
Re: Project 1966 K20 adventure rig
Today I started putting the bed frame together. I'm using all of the factory bed mounting locations. 2x2 rectangular tube blocks were cut to mount the main rails to. The blocks are bolted down with grade 8 half inch bolts. The main rails will then be welded to the blocks
This truck had a hard life before I got it. The rear portion of the frame is a bit tweaked to say the least. But with a little shimming of the mounting blocks, the main rails came out square and level.
1966 K20 flatbed build thread - http://www.67-72chevytrucks.com/vboa...d.php?t=768827
62 C20 build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=703583
72cs20 is offline   Reply With Quote
Old 01-17-2021, 11:22 PM   #152
Captainfab
60-66 Nut
Good looking progress Was that vinyl floor covering just a generic rolled vinyl material?
Old 01-18-2021, 11:29 AM   #153
roll_the_dice
roll_the_dice's Avatar
Originally Posted by 72cs20 View Post
After settling on a blurred vision for a bed configuration I went ahead and ordered some steel. It will mainly consist of 2x3 and 1 1/2x1 1/2 rectangular tubing. All with 3/16 wall. The decking will be 2x6 wood. Don't know what kind of wood just yet, although I can get some redwood free.
When I got the steel home I did another basic mock up to get a visual.
I am about to start a new build of my 64 GMC 1 ton dually and put a flatbed on it since it was originally a farm truck with a flatbed. I noticed in one of your pictures you had a flat bed and also had the bed mount frame brackets. Why did you raise the bed with the 2x2 blocks on top of the frame? These are great photos to help me when I get to that point! Thanks!
roll_the_dice is offline   Reply With Quote
Old 01-18-2021, 03:42 PM   #154
72cs20
This vinyl flooring is supposed to be a molded covering for the 60-66 trucks. I got it from ACC Custom Carpets. Now that it is in the truck I think it will be durable and effective. Time will tell if it will fully "relax". And the now oddly shaped transmission cover isn't helping.
Old 01-18-2021, 04:27 PM   #155
72cs20
This bed is actually only half an inch higher than the old bed. The old bed also had 2x3 main rails but but sat directly against the portion of the truck's frame that goes over the rear axle. And they only used 6 of the factory bed mounting locations.
I decided I didn't like that frame to frame contact so I lifted the new bed and used all 10 factory mounting locations. And that extra half inch made a perfect gap for the fuel filler hose.
I am by no means an expert in any of this stuff. But I think they cut a few corners when they mounted the old bed by not using all on of the available mounting locations. In fact, that area where there was frame to frame contact has some slight but noticeable deformation. You can actually see the slight bow in the top inside edge of the truck frame in the first pic.
I hope that answers your question. If you want any photos from other angles, just holler.
Old 01-18-2021, 07:22 PM   #156
roll_the_dice
Thanks that helps a lot. Makes much more sense to me now. I thought you might be raising it some for the gas tank fill. I had to cut some of my bed on my 65 for the side gas tank fill...There is a 1/2" gap in the below picture from bed rail to frame rail? Are you going to fill this gap with anything?
Old 01-18-2021, 10:22 PM   #157
72cs20
For now I'll leave that gap open. I don't expect much bending or deflection in that area. But we'll see once the truck is loaded up to it's trip ready weight.
Old 01-18-2021, 11:56 PM   #158
roll_the_dice
Thanks, I appreciate it!
Old 01-19-2021, 12:53 AM   #159
72cs20
More progress on the bed. Got the 1 1/2 x1 1/2 cross rails and the 2x3 outside rails in today. Now just need to finish up the welding.
Old 01-20-2021, 10:55 AM   #160
roll_the_dice
The bed is going to look so good! Are you buying your steel tubing locally? Mind saying how much you think the bed will cost? I looked yesterday and haven't found a local source yet and online pricing was crazy. Thanks
Old 01-20-2021, 02:49 PM   #161
72cs20
Thanks!
With the steel, lighting, welding supplies and miscellaneous items, 2500.00 or less is the goal. So far I have 1550.00 in steel alone and still need more to finish the cab guard and the tail end.
I bought locally.
Old 01-20-2021, 02:53 PM   #162
roll_the_dice
Much appreciated! I need to find the steel locally then...
It makes me happy when someone is a few (thousand) steps ahead and I can learn. This is such a great board! I have seen boards where people show things, but are stingy on how they actually achieve it.
Old 02-12-2021, 04:44 PM   #163
72cs20
Still working on the bed! The main part of the bed and most of the welding is finished. The remainder of the welding can be completed when the bed is off the truck for painting.
Currently working on the rear step and light panel. Have the main step installed and rear panel cut out to hold the rear lighting. I'm trying to keep this all as simple as possible, but there is still a bit more work to do in the step area.
The lighting locations are all good. Now working on routing all the wiring to get the lights hooked up and tested. Playing around with license plate locations too.
Old 02-12-2021, 05:47 PM   #164
roll_the_dice
Looks good..are you going to put a hitch receiver on the rear?
Old 02-12-2021, 06:56 PM   #165
The Rocknrod
Moderator
The Rocknrod's Avatar
This is some great Fab work your doing and it's coming along nicely.
Old 02-13-2021, 10:54 AM   #166
88Stanger
88Stanger's Avatar
damn fine work sir!!
John 3:16 - Saved me... God Bless
88Stanger is offline   Reply With Quote
Old 02-14-2021, 10:52 PM   #167
72cs20
A little more progress at the rear of the bed. Settled on a license plate location and then installed the license plate light.
Also kept going on the step area. Added a second section behind the main step to support a hitch receiver. I then want tie all of this to the frame utilizing the factory bumper bracket bolt holes.
Old 02-20-2021, 11:44 PM   #168
72cs20
Thanks fellas for the positive comments. Much appreciated!
Still plugging along on the bed. This week was work on the rear lighting terminal block. Got it mounted to the rear crossmember with a homemade L bracket.
Receiver for the hitch is in. And also got some plates made to tie into frame.
This next week I'm going look at fuel fill and mud flaps.
Old 02-21-2021, 12:44 AM   #169
roll_the_dice
I love what you're doing with the bed! It's awesome...great job.
Old 02-21-2021, 12:35 PM   #170
72cs20
Thanks! It has been a lot of work, but fun. And I've been using this project to learn how to use my mig welder.
Old 02-21-2021, 11:48 PM   #171
72cs20
I decided to tackle the fuel filler location today. Settled on a final location and mocked it up. I think it will work. Still need to get a reducer for the vent line.
And also terminated the rear wiring harness.
Old 02-22-2021, 09:55 PM   #172
cwcarpenter98
cwcarpenter98's Avatar
The bed is turning out great!
Might just be me, but I'd be worried about some fuel spilling out with the neck being parallel to the ground like that. Maybe you could pull the bottom of the mount out some to give it more of a downward angle right at the opening so it's less likely to have any fuel splash out?
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 02-22-2021, 11:16 PM   #173
Captainfab
60-66 Nut
I agree with Christian. The fuel filler should be at more of an angle. You are going to get fuel spilling on the ground while trying to fill the tank. You might have to recess it into the outside bed rail.
Old 02-22-2021, 11:49 PM   #174
72cs20
Thanks! Input for this project is always welcome and you're right concerning the angle of that filler hose. I have fiddled with the angle and position of the filler neck bracket. It should work for now but I'm not quite done messing with it just yet. Also, the filler neck is newer type with a screw in cap that has a big sealing o-ring. I'm confident fuel spillage won't be a problem.
Old 02-23-2021, 12:03 AM   #175
72cs20
I have looked into recessing it into the bed rail but am trying to avoid that. But if all else fails, what is necessary will be done. There are a number of options, but in end, I don't want a truck that is difficult to fill up.
