Old 10-07-2021, 01:48 PM   #151
youngrodder
youngrodder's Avatar
Re: The Vandal. 1957 "Big glass" 3100 restomod.
Crazy camber on the rear there...Ha ha that is not something to see you too often on a classic truck.
Cool pic.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 10-08-2021, 09:47 AM   #152
57FleetsideC4
Looking really good. Doing all the fun stuff now. Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054
57FleetsideC4 is offline   Reply With Quote
Old 10-10-2021, 12:29 AM   #153
MD2020
MD2020's Avatar
Nice build
MD2020 is offline   Reply With Quote
Old 10-17-2021, 08:40 PM   #154
BIGglaSS
BIGglaSS's Avatar
Cool pic.
Marc
Wifey says NO to air ride...
But it'll look so sick!
My museum of good intentions: 1957 3100 BBW restomod -- 1970 442 W30
BIGglaSS is offline   Reply With Quote
Old 01-30-2022, 07:17 AM   #155
BIGglaSS
BIGglaSS's Avatar
Wiring done
There is very little room to cram modern amenities behind the dash of these trucks. I call this bracket the sooper dookie. It is the basis of stuffing 10lbs of caca into a 1 lb satchel. It mounts to the bottom lip of the dash, and the wiper motor bracket. It holds the radio, a/c ecu, alarm module, and a home made ground block. And the a/c duct hoses hang from it. The alarm is used for the power locks.
The restomod air VapirII ready to be stuffed up behind the dash.
Finished. The left kick panel is home for the OBDII port. I ran the heater hoses and heater control valve through the right kick panel.
The stereo amp will be under the seat, controlled by a bluetooth DSP (digital signal processor).
Old 01-30-2022, 12:02 PM   #156
Rickysnickers
Wow, it looks great!!!
Old 01-31-2022, 09:41 AM   #157
youngrodder
Looking good. Wiring always seems to take much longer than you think it should.
Looking forward to seeing this one on the rd.
Marc
Old 01-31-2022, 06:55 PM   #158
Kevin_C
Its really coming together. is that the heater hoses running behind the passenger side close out panel? I've got my evaporator mounted but that's as far as I got so far. keep up the good work
1955 chevy longbed shortened, C4 vette suspension front and rear with flatout kit. Gen V LT1/8L90
http://67-72chevytrucks.com/vboard/s...d.php?t=746958
Kevin_C is offline   Reply With Quote
Old 02-02-2022, 02:03 PM   #159
BIGglaSS
BIGglaSS's Avatar
Thanks, y'all. Hoping to let the smoke out of the tires by April 1.
I had no where to mount the heater valve, so I decided to put it in the kick panel. There are bulkhead fittings to run out under the floor to the frame rail. I'll get pics of the other side later.
Old 02-02-2022, 02:45 PM   #160
BBPanel
My Restomod - I was going to use the side cowl area to run all of the hoses then under the fender but decided to use the bulkhead to do all four just below the unit on the firewall. I tucked my heater control valve inline above the unit.
Size:  35.0 KB Name:  20220202_123703.jpg
BBPanel is online now   Reply With Quote
Old 02-02-2022, 02:56 PM   #161
youngrodder
Looks good. I did something similar with the heater control on my Vintage Air set up. Looks much cleaner this way.
Marc
Old 02-02-2022, 03:09 PM   #162
BIGglaSS
BIGglaSS's Avatar
BBPanel, That's a tight squeeze to run the hoses that way. I have the unit that has defrost ducts out the back. So, it would not have worked for me.
Old 02-02-2022, 03:33 PM   #163
BBPanel
Yeah, I went with the Vapir 3 - all ducts go out the top or forward. Then I mounted unit as close to firewall as possible and still get 4 hoses down the back side. The clearances are tight enough I used a spacer on the bulkhead on the front of firewall just to get another 3/8" inside for the fittings. There isn't much room in these trucks regardless of which units are used.
Old 02-02-2022, 10:12 PM   #164
joedoh
joedoh's Avatar
beauty man!
I was here when you started and I cant believe how great this is coming out
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 02-04-2022, 10:27 PM   #165
BIGglaSS
BIGglaSS's Avatar
Thanks.
Today, it looked like I built a bird house.
Nope... It's a baby boomer. 8" Image Dynamics sub, 5x7's and tweets. Zapco 5ch amp. I'm quite pleased with how it sounds!
Old 02-06-2022, 02:33 PM   #166
daveshilling
daveshilling's Avatar
Sweet! In that small cab that little guy will do a great job of balancing out the sound. I waffle between OG overhead speaker and custom system... on one hand, playing a baseball game through one tinny speaker on am radio sounds amazing... on the other hand, music.
daveshilling is offline   Reply With Quote
Old 02-07-2022, 09:41 AM   #167
6DoF
6DoF's Avatar
how was the restomod parts/kit? that's what i've been looking to use
6DoF is offline   Reply With Quote
Old 02-07-2022, 10:42 AM   #168
youngrodder
Looks great. Ya gotta have tunes...
I like the carpet you chose. It has a nice color/pattern.
Marc
Old 02-07-2022, 07:31 PM   #169
OKGMC4
OKGMC4's Avatar
I sure love this truck. Everything is so shiny, makes me feel like I'm assembling garbage in my garage. lol
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 02-07-2022, 07:55 PM   #170
daveshilling
I know exactly what you mean!!
Old 02-07-2022, 10:50 PM   #171
BIGglaSS
BIGglaSS's Avatar
Yep. I believe in a properly tuned system. Size doesn't matter.
I pieced it together over several years. I did not buy their kit. The only thing from Restomod is the Vapir2 unit and the stealth controls. Since I bought parts a few years apart, there were missing wiring harnesses. They were great and worked with me to get the right harnesses. I did not buy dash vents yet, the hoses are just hanging under the dash. A/C pump is a Sanden from Holley. Hoses/fittings are aeroquip ez-clip. Highly recommend!
Thank you. I gotta 'fess up on the carpet... I really, really wanted german square weave, honey brown:
https://relicate.com/collections/ger...et-honey-brown
But, I wasn't ready to spend $140/yard. I found this at Lowe's 6'x'12' for $18! I don't know how I'm going to finish the edges. This was more or less a cheap shot to temporarily throw something on the floor.
Let's just call this a "shiny" 10 - footer.
Thanks for all the comments. It is encouraging to keep going and get'er done. After 8 years, I've had enough. I just want to get this thing mostly done. (It will never be finished)
I promised wifey that this would be the year we will take it out for dinner on her Birthday. That's less than 2 months away!
Old 02-08-2022, 09:34 AM   #172
OKGMC4
OKGMC4's Avatar
Don’t know if you have access to a sewing machine, but this shows how carpet edge binding is normally done.
https://m.youtube.com/watch?v=vbPLrzq9NMM
One thing I do that they didn’t show is after the first stitching on top is done, I flip it over and use a little 3M super 90 to hold the vinyl / leather to the back of the carpet so it’s not shifting around and good and tight when the second row of stitching goes in. I’ve also considered welding up angle iron to fit the top of the step that will hold the carpet in place. Could be powder coated or vinyl wrapped.
Old 02-08-2022, 01:54 PM   #173
BIGglaSS
BIGglaSS's Avatar
Thanks for the tip. That looks easier than another method I watched. I have thought about using the glue-on instabind. However, there is only one shade of gray, and I don't think it will match.
One problem I found with industrial carpet is that the backing sheds a very sandy grit of material. I would be concerned if that sand finds its way into the sewing machine and damages it.
I have thought about sewing my own seat cover. At this point, I don't need to learn another hobby, and I don't want it to look like an amateur made it.
For now, I have no idea what I'm going to do for a seat cover.
Old 03-03-2022, 02:26 AM   #174
Vomit
Vomit's Avatar
Excellent work. Im jealous of your sheet metal skills.
Vomit is offline   Reply With Quote
Old 03-03-2022, 10:19 AM   #175
youngrodder
I know that you mean about the cost of German square weave. I had to purchase 5 yrds of it for my suburban. I didn't finished my edges either. It is not supper noticeable because they terminate under the door sill trim on the sides. I did have my upholstery guy (the one that did my seats) make me some custom floor mats so it doesn't look too bad.
Marc
