08-04-2020, 06:00 PM | #151 |
Re: Orson the 49 GMC ~ Chris C.
The replacement 3/4 carriage bolts finally came in! It’s been more than a few years since these were produced, several of the bracket lengths were off and need to be corrected.
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 |
08-04-2020, 06:04 PM | #152 |
Michael mocking the board up.
08-04-2020, 10:26 PM | #153 |
great progress chris!
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
08-05-2020, 08:50 AM | #154 |
Thanks joedoh, a little slower than I’m used to, but it’s coming.
08-05-2020, 06:38 PM | #155 |
The first picture is that new running board bracket design with the proper measurements. The second is shortening the center bracket. These seem less time consuming to build, they will be my new standard.
08-21-2020, 09:40 AM | #156 |
We wound up having to replace the rear mounts with this. I designed the mounts for a 118”, not a 123” wb!
08-21-2020, 09:44 AM | #157 |
Boards getting mocked up
08-25-2020, 10:04 AM | #158 |
Now that the brackets are finished it’s time to shorten those splashguards to tuck the bed against the cab and center those rear wheels! They started by marking the 1.25” to be removed.
08-25-2020, 10:22 AM | #159 |
Here they’ve removed the metal
08-25-2020, 10:27 AM | #160 |
Here they have tacked it together and mocked up the boards.
08-25-2020, 07:59 PM | #161 |
tell em I said nice freakin work! a real chip off the ol sarge!
08-26-2020, 08:34 AM | #162 |
Thanks dude
08-26-2020, 11:33 PM | #163 |
Yes nice job...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
08-27-2020, 09:36 AM | #164 |
Thanks Jim!
01-01-2021, 12:09 AM | #165 |
after 8.5 months of prison, I finally got fed up and left! I now live in an apartment in town . I'm at the shop weekday's from noon-5. we get so much more done when I'm there! here is the finished stance. he didn't want it too low.
01-01-2021, 12:16 AM | #166 |
we put the steering column in
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by skymangs; 01-01-2021 at 10:10 AM. |
01-01-2021, 12:57 AM | #167 | |
Is this the wife? If so I completely understand.
Project "Eagle Spirit" 52 Chevy http://67-72chevytrucks.com/vboard/s...d.php?t=763085 Project "LS Scout" https://67-72chevytrucks.com/vboard/...d.php?t=844133 |
01-01-2021, 10:07 AM | #168 |
the VA home held me prisoner for 8.5 months. couldn't Leave, no visitors, not even delivery's! they called it quarantine, I called it unconstitutional! I fought for 4 months to leave, they even tried to have me declared incompetent IOT keep me! I won of course! total tyranny!
01-01-2021, 10:18 AM | #169 |
next we built a new cab dolly. (wife sold mine after the fire, didn't think I'd ever recover enough to need it I guess) that's OK, this one's better built!
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 01-01-2021 at 12:06 PM. |
01-01-2021, 10:27 AM | #170 |
oh, I almost forgot! before the cab came off, we did steering geometry! we used a piece of DD shaft and a 3/4 hiem to capture the lower joint. to keep it from wobbling.
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 01-01-2021 at 12:10 PM. |
01-01-2021, 10:37 AM | #171 |
then we tried to split the cast 4L60, to put in the torque converter and flywheel, but we couldn't get it to work even with the adapter!
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 01-01-2021 at 12:12 PM. |
01-01-2021, 10:46 AM | #172 |
so finally out of frustration, we pullud one of our expensive 4L65E's off the shelf and put it in. this required completely rebuilding the crossmember as it needed to move farther back .
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 01-01-2021 at 12:13 PM. |
01-01-2021, 10:55 AM | #173 |
I'll leave you with a bit on the gas tank. before he quit, Alex managed to misplace the gas tank straps! so we had to scavenge some from our personal junkyard! needless to say it was a fight!
01-01-2021, 12:14 PM | #174 |
Hope you don't mind, I just straightened your photos. Nice work!!
01-01-2021, 12:22 PM | #175 |
not at all!
