05-21-2015, 11:42 AM | #1726 |
Post Whore
Re: Restoring Rusty
05-21-2015, 11:52 AM | #1727 |
Post Whore
Re: Restoring Rusty
dang it the local junk yards are having a 50% off sale yesterday and today but I'm not sure I'll be able to make it out there, sure could use a better radiator support
05-21-2015, 12:48 PM | #1728 |
Re: Restoring Rusty
Sweet jesus! Can ya pick me up a windshield?
05-21-2015, 01:24 PM | #1729 |
Post Whore
Re: Restoring Rusty
05-21-2015, 01:31 PM | #1730 | |
Re: Restoring Rusty
Still have a sale the other days |
05-21-2015, 01:34 PM | #1731 |
Post Whore
Re: Restoring Rusty
picked up a couple of these plastic storage bin organizer thingies from Harbor Freight, they are normally $14 bucks but I found a coupon for $6, now I gave up on Harbor Freight tools a while back but I figure they can't screw up plastic bins too much, LOL
now maybe you can relate, I struggle organizing car bits, like fuses, washers, butt connectors, light bulbs (why do they insist on selling us two when all we need is one) nuts and bolts, cotter pins, etc, it seems like every little thing needs their special nook to live in, so there you go also from time to time I just stand in the middle of my Temple (some call it a Garage others a Workshop) and I say why can't I find the altar, where did all this junk come from, where am I to rest by beer and I take a moment and I try once again to get re-reorganized |
05-21-2015, 01:42 PM | #1732 |
Post Whore
Re: Restoring Rusty - Engine Bay Pics
mounted the driver side inner fender today and figure I'll share a few most recent pictures (yes I said pictures and not pics, I speak 40+ year old, LOL) of the engine bay, with the inner fender and them purdy (for a while at least) long tube headers, oh and the painted frame rail
not back for a blond Pollack if I do say so myself, but we're not there yet... Last edited by Gregski; 05-21-2015 at 01:48 PM. |
05-21-2015, 01:45 PM | #1733 |
Post Whore
Re: Restoring Rusty - Engine Bay Comparison @ 8 months
what's that? Show us the original how we got it out of the barn from the church lady, so we can Stare 'N' Compare
here we go... |
05-21-2015, 02:15 PM | #1734 |
Re: Restoring Rusty
Wow, Greg, what a difference! Those inner fenders look great, considering the low-buck approach you took with them. Radiator core support next?
Greg 64 GMC Suburban - 283, NV3500, 14 bolt 77 C10 swb - 292, SM465, 12 bolt |
05-21-2015, 04:07 PM | #1735 | |
Post Whore
Re: Restoring Rusty
I think the bed will be next, going to take off the old one and drop in a new(er) floor |
05-21-2015, 04:23 PM | #1736 | |
Post Whore
Re: Restoring Rusty
also please take my word for it that these pipes are fairly even and at the same height, it's these camera angles that make them look like Stevie Wonder did the install for me |
05-21-2015, 04:43 PM | #1737 |
Post Whore
Re: Restoring Rusty
A SUPER RARE SITE... a clean workbench!
~Approach with Caution ~ |
05-21-2015, 04:58 PM | #1738 |
Re: Restoring Rusty
05-21-2015, 05:22 PM | #1739 |
Post Whore
Re: Restoring Rusty - Work Bench
that's more like it...
05-21-2015, 05:28 PM | #1740 |
Post Whore
Re: Restoring Rusty
and so operation Tach You're It commences
there are three things to carefully disconnect before removing the gauge cluster 1. disconnect the mechanical speedo cable (cable looks and feels like the brake cables on your old 10 speed bicycle) 2. disconnect the mechanical oil pressure gauge by unscrewing a metal tube from the back, first undo the three screws that hold the gauge and pull it forward a bit (why it's called mechanical I don't know, it should be called hydraulic) 3, disconnect the thin ribbon cable that goes to one of the light bulbs, it may be an additional ground strap |
05-21-2015, 05:34 PM | #1741 |
Post Whore
Re: Restoring Rusty
then we are left with some ugly cobra looking wiring harness
which for all intensive purposes we must study and learn, so here is the front side of the connector Pins #1 through #9 and their respected colored wires, we shall call this poor man wiring diagram side Uno |
05-21-2015, 05:52 PM | #1742 |
Post Whore
Re: Restoring Rusty - Gauge Cluster Connection
ok lets check out the other side, here are Pins #10 - #18
05-21-2015, 05:54 PM | #1743 |
Post Whore
Re: Restoring Rusty
ok, so far so good, but here's where it gets interesting, I noticed that three wires loop from one side to the other, so wrap your mind around that for a minute
looks like the pink wire, the tan wire, and the tan/black wire are playing both sides (politicians are they) |
05-21-2015, 06:40 PM | #1744 |
Post Whore
Re: Restoring Rusty
ok folks put on your detective hats because we have a situation, there is a lonely loose black wire it disappears into the wiring harness and appears to be headed towards the cluster connector, we must track it down
05-21-2015, 07:21 PM | #1745 |
Post Whore
Re: Restoring Rusty
ok, it appears the black mystery wire splices into another black wire that plugs in to Pin # 9 ie Ground, fair enuff, now we need to figure out where it was headed the other direction does it go to the fuse box, or screw into the dash somewhere?
05-21-2015, 07:51 PM | #1746 |
Re: Restoring Rusty
Are those the black wires for your ammeter that run from under the hood? Run a test with your voltmeter to test.
05-21-2015, 07:59 PM | #1747 |
Post Whore
Re: Restoring Rusty - Oil Pressure Gauge Upgrade
so one of the side perks of upgrading to a 1978 gauge cluster is that it has the electronic oil pressure gauge, so out with the old mechanical one first
the mechanical setup has a metal tube that runs from the back of the engine block under the distributor by the firewall and into the cab, and connects to the back of the mechanical oil pressure gauge, yes oil goes way up there into your dash and could possibly spray you in the face @ 60 PSI awesome - NOT! |
05-21-2015, 09:03 PM | #1748 |
78K & 79C Jimmys
Re: Restoring Rusty
Maybe the black could be seat belts ?
Among everything else grounded they usually went down to one wire about a foot from the cluster plug in
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
05-21-2015, 09:42 PM | #1749 |
Post Whore
Re: Restoring Rusty
alright so had to go out and buy an oil pressure sending unit, they come in two flavors cheap (ie $8.00) and the one I need ($36.00)
cheap = idiot light expensive = with a gauge Pretty much right off the bat I knew we were going to have a fitment issue, this thing is just too tall and bulky to fit under the HEI distributor, any of you wan to share pics of your electronic sending units? that would be much appreciated |
05-21-2015, 09:52 PM | #1750 |
Re: Restoring Rusty
You need to get a 45 degree fitting with a 1/4 npt male to I think a 1/4 female of you have room behind the intake otherwise you will need a 1/4 nipple to 45 female/female.
