05-08-2021, 07:56 PM | #1751 |
Post Whore
Re: A '54 named Busty
forgot to compensate for the circumference of the earth, so she got a little trim
05-08-2021, 07:59 PM | #1752 |
Post Whore
these speed nuts are still the bestest way to mount it as the holes are all podawhumpuse, especially when she flexes in the corners on the race track, ha ha
05-08-2021, 08:01 PM | #1753 |
Post Whore
the wife left the fan outside so I had to hide in my time out corner to primer it, otherwise it was wayyyyy toooo windy AGAIN
FYI the sheet metal I got was galvanized (that's all Home Depot had) so I washed it in Phosphoric acid, then neutralized it with Baking Soda water, then sanded it off, then etched it with Phosphoric acid again, and washed it off with Baking Soda water for the second time. Last edited by Gregski; 05-10-2021 at 11:52 AM. |
05-09-2021, 07:49 AM | #1754 |
That turned out nice.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
05-09-2021, 10:40 AM | #1755 |
Turned out nice.
If you dont wanna see the ends of the rivets you could use steel stud screws, with the big flat head, and speed nuts on the backside. Nobody is gonna look in the glove box though and rivets are not sharp on the backside. |
05-09-2021, 10:45 AM | #1756 | |
Post Whore
I already have Pontiac Mike my buddy breathing down my neck saying rivet from the inside out to make it look mo bettah on the inside, (but that's hard and I don't know if that cheap rivet plier gun vice grip thing will even fit) so once it is painted I will make a Game Time decision Omaha, Omaha, ha ha |
05-10-2021, 12:44 PM | #1757 |
Nice work
05-10-2021, 01:32 PM | #1758 |
I've been told that there are three types of people:
1. Those that watch things happen. 2. Those that make things happen. 3. Those that ask what the hell just happened. You, sir, are those that make things happen. I love the wiring and the glove box. Awesome work. |
05-10-2021, 07:08 PM | #1759 | |
Post Whore
05-10-2021, 10:46 PM | #1760 |
Post Whore
Man I ain't gonna lie today was one of them days
I spent the first 4 hours just spinning my wheels in the garage, then my soldering iron gave up the ghost, I guess doing all that re wiring wore her out, funny thing is this was my second iron, the first one lasted me 20 years and was the serviceable kind but like an idiot I tossed it and bought this one which barely made it two years and instead of having three tiny screws to open her up they popped in a rivette, oh well I already bought my third in hind sight I should have gone to a Thrift Store and bought an old fashion one for like .99 cents and had it for another 20 years, I may still do that, Oh Well(er) |
05-10-2021, 10:54 PM | #1761 |
Post Whore
who says I ain't tryin'
here I decided to wash the worst of the three buckets, yes I own three seats just like this one, this one was the dirtiest of them all so I finger if I can clean this one than maybe I can clean the others plus I need something to sit on while the other two go to the leather house and who knows when I'll get them back here I am using the orange stuff with plum juice |
05-10-2021, 10:59 PM | #1762 |
Post Whore
so I went to start her today for the first time since looming the entire engine wiring harness and buttoning her up for the last(ish) time
and she would crank but not start my heart sank, miles of wires hidden in yards of conduit ran through my mind, I dreaded the idea of having to troubleshoot all of that then I calmed myself down and said: When dealing with LSes You know it comes down to three things right? 1. groundsso I eyeballed the ground boundle, and I wiggled it with my hand, yup, nice and tight, started to pull up on them one by one, and the last one ended up in my hand yup Professor Silky Smooth hide the wiring loom under the engine forgot to ground the separate trick PCM branch, no worries it was only 19 ground wires bundled into one, ha ha so grounded those, and she winked at me and fired right up We'll call that the Anti Theft Device. |
05-11-2021, 08:44 AM | #1763 |
I like my Weller, and she fired up. Forget about the stuff before that, she fired up!!! Oh that'll be the day...
05-11-2021, 01:26 PM | #1764 |
05-11-2021, 05:02 PM | #1765 |
Post Whore
put the Grant wheel back on today and made sure everything worked, it's a simple setup with only a turn signal cam and a horn
apparently the kit I had for it only covered all GM cars from 1812 till present but not the 58-62 Impala so I had to buy a different one nothing like grinding your new paint off the steering wheel to make it go Beep Beep! |
05-11-2021, 05:04 PM | #1766 |
But it's no visible and won't rust, I mean it never rains in southern California...
05-11-2021, 05:05 PM | #1767 |
Post Whore
First Fill Up! Well 10 gallons just to see if the fuel gauge works, it was reading Empty before.
05-11-2021, 07:00 PM | #1769 |
Post Whore
05-12-2021, 06:45 AM | #1770 |
gas prices or not ... if someone ever convinced me and paid me enough to move to CA, (not actually possible) i'd be driving something pre-73 with a blower out the hood and a bumper stick "suck my exhaust"
05-12-2021, 09:50 AM | #1771 |
05-12-2021, 11:01 AM | #1772 |
Post Whore
Well Forumners dare I say everything electronic works:
1. Headlights (both high and low beam) 2. Parking Lights (as front turn signals I put orange bulbs in 'em) 3. Tail Lights 4. Brake Lights 5. Reverse Lights 6. Brake Lights (as rear turn signals) 7. Dome Light 8. Gauge Lights 9. Horn (yeah I know, this may be like the first truck with a horn I ever owned) and yes it's got it's own relay 10. TCC aka the Torque Converter Clutch (this one was tricky because our trucks have an old style brake light switch so I used a reverse wired relay) and no I did not follow this guys video, lol How to wire TCC for PCM, ECM, ECU with break light positive. (RELAY) though using all red wire probably does save you some money, ha ha I am so happy, and I am so grateful for all you guys and gals for following along and encouraging me when I got down. Last edited by Gregski; 05-12-2021 at 11:09 AM. |
05-12-2021, 11:10 AM | #1773 |
Post Whore
05-12-2021, 11:44 AM | #1774 |
well done, that was a lot of wires to sort through, and you were successful. congratulations.
the truck look great there sitting at the pumps, looks mean without the hood.
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
05-12-2021, 11:57 AM | #1775 |
Well darn, what are you going to do now? You need another project....
