07-10-2023, 10:03 PM | #1751 |
Post Whore
Re: My Dusty 71 GMCe Electruck
so back to that transmission oil top off which I have been avoiding doing, and here's why
Lexus claims for this to be a Maintenance Free Transmission (pronounced: good for 100k miles before you have to do anything to it) I recall this being attempted by automobile manufacturers in the past and it just takes simple tasks like checking the fluid levels and or topping off the fluid and makes them impossible to do later! For instance this transmission does not have a dip stick, [unless you consider it's owner] and what appears to be metal dip stick tube, is actually an inlet for the coolant aka water cooling. and the best thing about that tube is that it is joined to the pressed in actual inlet on the body of the trans with a flexible rubber hose, so you can easily remove it / delete it as it is almost guaranteed it will interfere with the firewall in your conversion vehicle, and then you just run a rubber hose directly to that short stub on the transmission Second, this transmission does not have a filler hole. That's right there is no unscrew this bolt and pour some delicious trans fluid in. |
07-10-2023, 10:08 PM | #1752 |
Post Whore
so I am relying on this LS600h procedures but I recon they is the same(ish) Lexus LS600h Chassis
any of youz own or have dealt with one of these lifetime maintenance free transmissions ? |
07-11-2023, 03:14 AM | #1753 |
Post Whore
poor girl was thirsty she drank 3 quarts and never overflowed yet, looks like I'll be heading back to the floor mat store
07-11-2023, 06:09 AM | #1754 |
“Floor mat store”
71 C10 72 K20 72 K10 Super Kirk |
07-11-2023, 06:43 AM | #1755 |
Nice work.....nowhere in the drain refill, instructions and implementation was the term filter used, reused, or filtered. Maybe that's where the floor mats come in, hope you got some. Nice work rehumping the trans bump hump. Oops, or metal thingy over transmission....Vacuuming the garage, oh boy, something big is coming!
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
07-11-2023, 09:17 AM | #1756 | |
Post Whore
07-12-2023, 06:38 AM | #1757 |
Post Whore
so it was back to the Floor Mat Emporium
Me: "two quarts of ATF WS transmission juice please" Lexus: |
07-12-2023, 06:49 AM | #1758 |
Post Whore
so after a second trip to get more trans fluid, she only took a small swig of the 4th bottle for a total of 3 1/4 quarts thought this will be helpful to future Padawans topping theirs off
07-12-2023, 07:06 AM | #1759 |
Post Whore
this next high voltage motor cable repair I wrote up in excruciating detail in this Lexus GS450h Transmission Inverter High Voltage Cable Repair so here I will just share some highlights, in case you was wondering why the truck aint running yet
when i first got my Lexus GS450h transmission off a seller on eBay I noticed the big fat orange cables attached to the motors had small gashes in them with some copper exposed, Not Good! |
07-12-2023, 07:08 AM | #1760 |
Post Whore
I was very pleased to learn that the cable ends come apart and that these cables are serviceable, Mr. Toyota will be receiving a Christmas Card this year
07-12-2023, 07:09 AM | #1761 |
Post Whore
and now I had to do the other side
Fun Level: 2 |
07-12-2023, 09:23 AM | #1762 |
As always, I enjoy the humorous updates. "Floor Mat Emporium"
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
07-12-2023, 10:30 AM | #1763 |
Post Whore
appreciate the positive feedback MD, it feeds my fragile eagle, have you ventured out by the The Good Enuff Garage Channel of Tubes for You
07-12-2023, 10:53 AM | #1764 | |
07-12-2023, 10:56 AM | #1765 |
Post Whore
07-12-2023, 11:08 AM | #1766 |
The government can track that, I only take cash.
07-13-2023, 10:18 AM | #1767 |
Post Whore
just a quick check list of how my Final Assembly went down as a husband, amateur EV converter, and a father of a teenage daughter with a 2010 Mazda 3 which just through a P0753 code aka "bad shift solenoid" [pronounced: "needs a new friggen $900 dollar TCM"]
Easy-peasy !!! do you have a similar story? I would luv to hear about it to calm my nerves, jk The Suspect and People's Exhibits A & B |
07-13-2023, 07:36 PM | #1768 |
Bulletpoint for 9: Drive to Mazda stealership for TCM programming.
Bulletpoint for 10: Give Mazda back to teenage daughter. At least you made a few people happy. Your daughter will get her car back, your wife because your daughter is happy and you because both your daughter and your wife is happy. Nothing beats having a happy family. Oh, also you got practice in removing and re-installing a TCM in a 2010 Mazda 3. |
07-13-2023, 08:19 PM | #1769 | |
Post Whore
07-14-2023, 09:19 AM | #1770 |
Post Whore
then I assembled it all for what I hope is the final time, the S shows how they are connected in series
07-14-2023, 09:22 AM | #1771 |
Post Whore
a little close up of the leads going into the inverter, 90% of all that orange will be out of sight out of mind
07-14-2023, 09:24 AM | #1772 |
Post Whore
EV Conversion Walk Through YouTube video
of how this unicorn electric transmission ev conversion will work |
07-14-2023, 02:56 PM | #1773 |
Nice work, very informative. I am looking forward to seeing this truck run under its own power.
07-15-2023, 05:16 AM | #1774 | |
Post Whore
EV Conversion Low Voltage Wiring I |
07-16-2023, 07:54 AM | #1775 |
X2 great video...... question are you going to use that 67-68 steering wheel that's hanging up on the wall
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
