06-07-2015, 01:43 AM | #1901 |
Second Chance Program
Re: Restoring Rusty
Good fun!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
06-07-2015, 02:40 AM | #1902 |
Re: Restoring Rusty
Dang...
06-07-2015, 10:09 AM | #1903 |
Post Whore
Re: Restoring Rusty
06-07-2015, 10:09 AM | #1904 |
Post Whore
Re: Restoring Rusty
06-07-2015, 10:58 PM | #1905 |
Post Whore
Re: Restoring Rusty
the twins sun bathing, after taking a good bath in some dish soap, they were preserved because they were covered in grease and sludge
you probably could not see how badly these wheel housings were beat up before I hammered out all the dings and dents, apparently the previous owned used the truck to haul lumber anywho, can you tell me how to pop out the big slight indentations in the vertical sides, what happens is when I step on the dents they pop out, but as soon as I step off of them they pop back in, it's as if the metal is teasing me |
06-07-2015, 11:01 PM | #1906 |
Post Whore
Re: Restoring Rusty
since I didn't want to use a replacement wheel housing with the wire harness hole in it, I thought I could save one of mine, however after taking a wire wheel to it, we found lots of swiss cheese
so we'll use the orange ones |
06-07-2015, 11:04 PM | #1907 |
Post Whore
Re: Restoring Rusty
the Greg has no idea how the front end bed panel got rusted here, but there is a matching rusty spot on the back of the cab, so my guess is a wet cat must have gotten stock in there, LOL
06-07-2015, 11:08 PM | #1908 |
Post Whore
Re: Restoring Rusty
we deployed a dual attack on the rust on this piece, abrasion and acid
first loosen up and remove as much rust as possible with a wire wheel then use Phosphoric acid to fight the rust, in this case I had some Metal Prep left over, (it's just diluted Phosphoric acid I bought from POR-15, I won't be buying it agian, since I can get 50 times the amount from Home Depot for $5 bucks) brush on some acid, let sit, have a beer, watch the rusty spots turn white, then wire wheel them off, and repeat till no more white shows up |
06-07-2015, 11:10 PM | #1909 |
Post Whore
Re: Restoring Rusty
the dance of the wire wheel
went through another cup wire brush, (I need to start buying these in bulk) |
06-07-2015, 11:11 PM | #1910 |
Re: Restoring Rusty
Rusty is so very lucky to have you mending things up.
06-07-2015, 11:14 PM | #1911 |
Post Whore
Re: Restoring Rusty
kicked the bed floor outside - cause it's not potty tained, LOL
keep in mind this thing is ORANGE, it's not all covered up in rust, just some surface rust, so it's solid otherwise |
06-07-2015, 11:16 PM | #1912 |
Post Whore
Re: Restoring Rusty
thanks, then tell him to stop biting me
06-07-2015, 11:19 PM | #1913 |
Post Whore
Re: Restoring Rusty
same deal on the bed floor, wire wheel, then coat in phosphoric acid
I swear I went out and bought the most beat up bed I could find, this thing looks like it was used as a dance floor by $300 lb strippers in iron stiletto heels try and visualize that I'll wait, JK |
06-07-2015, 11:22 PM | #1914 |
Post Whore
Re: Restoring Rusty
couple annoyed neighbors and beers later, the top of the bed floor is wire wheeled and bathed in [deluted] phosphoric acid
not my favorite part of the restoration process, but it must be done |
06-07-2015, 11:22 PM | #1915 |
Re: Restoring Rusty
I think I will visualize Rusty all nice and pretty instead if you dont mind ,thanks .
06-07-2015, 11:25 PM | #1916 |
Post Whore
Re: Restoring Rusty
tomorrow we will change the wire wheel on the angle grinder to a grinding stone and grind down these welds
these are the weld spots where the old bed side walls were attached to the bed floor in the bottom corners of the tailgate |
06-07-2015, 11:28 PM | #1917 |
Post Whore
Re: Restoring Rusty
and the other side...
the detail is in the devil I know the next time I am walking by a restored C10, I will stop, I will look at the truck, I will find the owner, I will gaze down at his hands, seek the scars, then look down at his worn out boots, and just look him in the eye and and give him that nod of sweat, blood, and tears of approval |
06-08-2015, 12:24 AM | #1918 |
Re: Restoring Rusty
For metal that keeps popping when you try to remove the dent the easiest way to fix this is by cutting the dent in half then rewelding it.
It's usually popping because the metal is stretched. The other way you could try is getting it red hot then quenching it quickly to shrink it. |
06-08-2015, 12:28 AM | #1919 | |
Re: Restoring Rusty
http://cid.vcc.ca/p1-dl/instructions...emo-shrink.htm
Rich Weyand 1978 K10 RCSB DD. |
06-08-2015, 12:29 AM | #1920 |
Re: Restoring Rusty
enaberif and I were typing at the same time. Yeah, don't cut it, at least not as a first try. Heat it and quench it.
06-08-2015, 12:21 PM | #1921 |
Re: Restoring Rusty
I sure am glad that you mentioned that the bed was orange..I thought the Gregski had sniffed too much cleaning products. |
06-08-2015, 02:39 PM | #1922 |
At the body shop.
Re: Restoring Rusty
I have some fairly straight wheel tubs, you could have... Already out and in my way.
" That didnt make it any newer " " Dont antique the equipment " |
06-08-2015, 06:31 PM | #1923 |
Re: Restoring Rusty
LOL
Greg 64 GMC Suburban - 283, NV3500, 14 bolt 77 C10 swb - 292, SM465, 12 bolt |
06-08-2015, 07:12 PM | #1924 |
Post Whore
Re: Restoring Rusty
105* F outside so The Greg will be taking a day off
06-09-2015, 09:19 AM | #1925 |
Re: Restoring Rusty
