11-19-2021, 11:01 AM | #1951 |
Re: My 50 roadster pickup build
ICT Bracket #551472-3 for truck uses a Sanden 7176 ac compressor (mini), anything else let me know...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
11-19-2021, 11:03 AM | #1952 |
Thanks Jim!
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
11-19-2021, 10:52 PM | #1953 |
Little update from yesterday. Before removing AC stuff Mark and I measured up for new belt.
1st pic is the new radiator set up with an old mount, for checking for what type of bends I would need for new hoses, did find upper at local auto place, should have bottom by tomorrow. Pic 2 and 3 are of the ac compressor and brackets painted in etching primer
11-19-2021, 10:57 PM | #1954 |
First 2 pics are same parts painted flat black, not dry so they look odd.
finall pic is of the exhaust pipe from header to the new mufflers, Mark welded them up using is tig machine, came out super. They are now ready to install. Till next time...Jim
11-22-2021, 08:36 PM | #1955 |
Not much to show today. Mark put the exhaust system together, and reinstalled the AC stuff after it was painted. Started fitting hoses to the radiator. Can't do anything without parts, hope some will arrive this week...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> Last edited by oldman3; 11-24-2021 at 12:54 AM. |
11-26-2021, 10:25 AM | #1956 |
beeeeeautiful stuff jim and mark!
and your "not much to show" list is impressive, one guy who works on truck to another.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
11-26-2021, 11:08 AM | #1957 |
Thanks Russ, appreciate it. Hope to get some parts today (11/26) so we can finish up loose ends...Jim
11-29-2021, 11:51 AM | #1958 |
Looking good! I think everyone is waiting on parts.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
11-30-2021, 12:56 AM | #1959 |
Parts did come in Friday (11/26) Mark installed the refaced gauges and hooked up all the wiring. I really like this new look. Also carried the front clip back down to the shop, tried to put back on and found several items that were hitting. Had to pull back off and modify things. Will install next week.
Today I took off the old ac condenser and put on the new aluminum radiator, installed on my original radiator bracket and it was hitting. After checking I found out that the bracket on the new radiator, didn't match the same angle that was on my Walker radiator. This pulled the lower section in about 1/2" compared to the old set-up. Will have to make some changes tomorrow. Here's pics of the gauges and the radiator...Jim
11-30-2021, 09:01 AM | #1960 |
Gauges look great Jim. I had a similar issue with my radiator. I cut the welds that attached the bracket and moved them to where I needed them then had a friend weld the aluminum brackets back in place.
With fitment, you don't know what you don't know. Your gaining. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
12-01-2021, 12:50 AM | #1961 |
Well a few things got done today, but also still have fitment issues.
All finished with the radiator set-up. Mark and I installed the front clip, and found that we still can't clear the ac tensioner, it's hitting the inner fender. We had clearance it a little, but still hitting, so off it comes tomorrow and do some more work. Here's a better pic of the gauges, and also with the front end on (not a good pic)...Jim
12-01-2021, 07:59 AM | #1962 |
That paint looks like smoothly flowing, molten glass. It's absolutely gorgeous.
Awesome work! |
12-01-2021, 08:14 AM | #1963 |
Do you know what the condenser is from or is it part of a kit?
12-01-2021, 08:55 AM | #1964 |
That dash is awesome!
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
12-01-2021, 10:51 AM | #1965 | |||
Thanks Robert...Jim
12-02-2021, 12:38 AM | #1966 |
Well not a good day today. Mark and I removed the front clip, did some more relief in the inner fender and tried to install the front clip again. Was still way to tight. So I said let's cut out the sheet metal and make a new piece that will clear the AC compressor clutch and the belt tensioner.
Man I hated to do that, but had to. pic 1 is looking at the metal cut away, and template made. Pic 2 is looking straight down, so you can see how much clearance was needed. Pic 3 is the ac stuff. Should have known everything was going to smooth to last..Jim
12-02-2021, 08:22 AM | #1967 |
Ya feels like you are going backwards sometimes.
12-02-2021, 09:33 AM | #1968 |
That's a bummer, but I'll bet you will be happier when it fits the next time with the cut out looking very custom!
12-02-2021, 11:01 AM | #1969 |
Thanks guys, will keep pluging away...Jim
12-02-2021, 11:16 AM | #1970 |
once it is welded in and painted, it will look as good as the 'inserts' that were made for the upper control arm adjusters. (very nicely done)
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
12-03-2021, 12:15 AM | #1971 |
Thank you, Mark did a great job on this 'new insert', posting pics later...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> Last edited by oldman3; 12-03-2021 at 12:33 AM. |
12-03-2021, 12:20 AM | #1972 |
Mark did a great job today, making the metal insert for the inner fender. Welding everything and meal finished...Jim
12-03-2021, 12:25 AM | #1973 |
After Mark did all the metal work, we installed the front clip again, to double check clearance. The next 3 pics aren't very good, but we have great clearance around the ac clutch and tensioner...Jim
12-03-2021, 12:29 AM | #1974 |
We removed the front clip, Mark mixed some filler and put it on the patch. Will sand tomorrow, prime. Then sand and paint, will post pics when done. We also worked on a few loose ends, etc....Jim
12-03-2021, 08:46 AM | #1975 |
sometimes ya gota do what ya gota do! this will be great in the end
