02-17-2017, 02:11 PM | #1951 | |||
Re: Crusty Rusty Leaky Squeaky 67 Step
Thanks, Brian! Quote:
Victor 57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas |
02-18-2017, 07:23 PM | #1952 |
I know bodywork ain't the most glamorous topic... just didn't want you to think I was slacking off with all this good weather we've been having. Well, maybe a little bit.
02-18-2017, 08:14 PM | #1953 |
Proprietor of Dale's Corner
Looking fantastic!
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
02-21-2017, 08:35 AM | #1954 |
Beddy Beddy nice.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
02-21-2017, 09:01 AM | #1955 |
Vic, you nailed it, nice work
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
02-22-2017, 09:17 AM | #1956 |
Vic,
Lookin' good! won't be long now! by the way, how did your bed situation with the new chassis mods turn out? did everything fall back into place afterwards? I finally got my truck fired up yesterday, need to do a little "Finesse" on the tune, but it's running again. I kinda miss the lope I had with the old Cam, but the drive ability factor is better, and the clanking noise I had been hearing is long gone, I'm guessing that balancer was "Ringing" the pulleys during deceleration causing that clanking sound, because no matter how hard I tried, I could not get it to do it again.... now to fix my steering gear box leak..... Have a good one and I'll stop by one day here soon. Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time" “Serious Black” my 1971 Short Bed Fleetside Sold to an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten” |
02-22-2017, 09:20 AM | #1957 |
Awesome job Vic!
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
02-25-2017, 05:52 PM | #1958 | |
Bed ended up in a much better place than before, thankfully. I'd probably be under supervised care if it hadn't. The front bumper is pretty much solved with the exception of spot filler, a coat of slick sand and blocking. I used some fine line tape to lay out the gap I wanted between it and the valance. Some careful sanding and filing and it looks pretty good. I've turned my attention to the rear to tidy it up a bit. I picked up a painted rear fleet bumper at Classic on Monday and took both it, and the front, to Eagle Stripping. They returned the front bumper to clean white metal everywhere and removed the EDP from the rear bumper. I only plan a few mods out back. I'll narrow both sides to tuck in closer to the quarter panels, make a filler panel to eliminate the gap and weld in the fasteners to smooth out the bumper. Shouldn't be anywhere near the level of pain I endured up front.
02-25-2017, 05:54 PM | #1959 |
Some starter shots of the rear for reference...
02-25-2017, 05:55 PM | #1960 |
That has,worked in great Vic...can't wait until it is primed so we can see all the lines... Great work buddy ..
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847 Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210 |
02-26-2017, 12:15 AM | #1961 |
Doing great Vic. Keep up the great work. It's going to be a fantastic looking truck!
02-26-2017, 02:50 AM | #1962 |
Wow!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
02-27-2017, 09:02 AM | #1963 |
Love the front. Looking at the rear, wonder if you could make an angled slice on the ends to tip the bottom in and take the "bulge" out of the base? Just a thought.
02-27-2017, 07:09 PM | #1964 | ||
Hey Mike, good to hear from you. Weather up there lately sux from what I hear... good time to lay low and lurk on the forum. Thanks, Chip, we think a lot alike. I knew the ugly ends on the rear would need a bit of hammering. After I got them cut off, I used the press, vise and dolly to reform the edges similar to the front. I then tacked the shortened pieces back together and put the bumper back in place. Used some tape to mock up a filler piece that follows the line of the quarter panel a bit better. I sawed out a piece of mild steel flat stock using the tape as a template and have it taped in place in the last photo. All the mounting bolts have been welded in and smoothed out also. Not sure if this look is what you envisioned, but being a fundamentally "straight line between two points" person, this how I approached it.
02-28-2017, 07:19 AM | #1965 |
Vic, even though I've seen pictures of the stuff that has fought with you, you still make it look so easy and virtually seamless. As usual, I am very impressed by your work and your approach!
I must figure out how to straighten my line(s) between two points. My tiny little mind tends to wander and overcomplicate stuff WAY too much!
1968 SWB Stepside "Bella coming home" "Bella's Build Thread" A master in the art of living draws no sharp distinction between his work and his play. He simply pursues his vision of excellence through whatever he is doing, and leaves others to determine whether he is working or playing. To himself, he always appears to be doing both. L. P. Jack |
02-28-2017, 09:27 AM | #1966 |
Still Learning
Very nice work on the bumpers and body Vic! looks great!
02-28-2017, 01:33 PM | #1967 |
Diggin it!
02-28-2017, 06:45 PM | #1968 |
You do some nice work Vic! The front turned out great. The back looks like you're already on a good path. Keep it up!
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
03-01-2017, 07:13 PM | #1969 |
Nachos Garcia, everyone! I've only been able to spend a few hours in the shop due to other stuff that needed tending, so not much progress. The filler pieces for the ends are tacked on and I modified the bumper mounts very slightly to get the fit I wanted. Next up is to weld some 1/8 x 1/4 flat bar on the ends of the filler pieces to give them a more finished look. Then it will be time for the filler between the bed and the top lip of the bumper. Stay tuned.
03-01-2017, 09:55 PM | #1970 |
I'm very impressed Vic. I always liked the rear bumpers the way they came from the general. But it's looking awesome, I may have been wrong. I'm looking forward to see it completed.
03-03-2017, 08:18 PM | #1971 | |
Spent all day yesterday taking Dad to doctors and the ER. Thought he might have a fractured hip, but the CAT scan turned up gallstones and a cyst on his kidney. I reckon walking must have put pressure on that area and he was reacting to the pain. Anyway, he's doing better today and I was able to sneak downstairs and get some welding done. The ends are taking shape and I'm pleased with the edge I added. Now just need to do the other side.
03-03-2017, 08:48 PM | #1972 |
Vic, you nailed it on the front bumper.... I've looked at some trucks at the shows and always thought of how good that looked. As far as the rear, I would of never thought about doing what you've done, it looks awesome as well. Keep it up and get some paint on that thing.
Jason '70 C-10 short fleet 427BB TH400 (SOLD) '10 Ford F 350 '13 Ford RAPTOR 6.2 MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623 |
03-04-2017, 12:40 AM | #1973 |
X2 what Jason said . Awesome work Vic!
Scott |
03-04-2017, 08:30 AM | #1974 |
Hope your Dad is doing alright.
Hey man 67 GMC Short Stepside 400 small block, turbo 350. Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=650603 |
03-06-2017, 09:04 AM | #1975 |
I like the way the back came out. Good job!
