03-26-2015, 12:20 AM | #1951 | |
Re: What did you do to your truck today? Chapter II
03-26-2015, 12:15 PM | #1952 |
Brushed some Calyx on the exhaust manifolds I replaced last year. The rattle can silver header paint spot rusted in about a month in our wet and sticky climate. "Ooh ooh that smell, can't you smell that smell?" Now I need some heat shields so I can clean up the wiring mess!
Life is too long to go slow... 71 GMC 1500 Super Custom LWB 350/350 AC(replaced w/vintage air)/PS/PB 2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt 20x8.5 OldSkools 5" BS, 275/45 Falkens |
03-26-2015, 01:31 PM | #1953 |
I called about a front fender since I think I will need one when I remove the radiator core support! So much rust there I think the fender will fall to pieces.
I also stood looking at my truck and decided "if I can stay focused, she can run before fall." I plan to get back on her beginning in April. |
03-26-2015, 05:38 PM | #1954 |
03-26-2015, 05:54 PM | #1955 | |
1971 GMC 4x4 4 speed Project |
03-26-2015, 11:35 PM | #1956 |
Yesterday I paid for upper and lower moldings, NOS. Wasn't cheap.
Today I bought this. May not be a box, but this is super clean. Looks like there's a small scratch, but I can definitely make this work. Little dab will doer. Looks like the real deal. Better be @$40 w shipping. Edit: Just spoke to the guy. No box. Bummers...... http://www.oldsobsolete.com/products...y-nos-911311/#
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 03-27-2015 at 01:04 AM. |
03-27-2015, 03:35 AM | #1957 |
Thank you ! Yes I did , I just about got it all buffed out now .
Peace
69 GMC 400/400 2.5/4 drop from ECE |
03-27-2015, 04:36 PM | #1958 |
Ya I had to trim a few spots on the frame and had to beat in one spot on the trans hump a little bit. Then I just welded some strap across the front so I could use all the original bolt holes. It doesn't slide forward or backward but the bottoms do flip up and the backs lay forward. I'll try to post some more pics later today.
03-27-2015, 07:39 PM | #1959 |
Hope these help
03-27-2015, 11:18 PM | #1960 |
Thanks! Those seats look great in there. I would really want the ability to move them forward and back. I'm sure someone on here has made them work that way.
03-28-2015, 12:24 AM | #1961 |
Spent another $26 for a service manual. Taught how to read GM instructions for bolt patterns.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
03-28-2015, 06:13 PM | #1962 |
Got the inner/outer fenders bolted back on. Hung the bumper including the heavy push guard. Hung the hood. Ran the front brake lines and hooked up the proportioning valve.
Little more brake/fuel lines and it time to set the short bed box in place.
"Life is too short to drive a boring vehicle". Later, Wayne |
03-28-2015, 08:08 PM | #1963 |
Out with the old, in with the new. Today I installed new front shocks w relocated upper mount points.
http://www.hotchkis.net/product/1963...-front-shocks/
--------------------------- 1972 C10 LWB - Sold 1968 C10 SWB - 350/700R4 Jacob, DFW/TX |
03-29-2015, 02:08 AM | #1964 |
Got the truck towed back to the house from the body shop, firewall filled and rust on cab floor repaired.
You remember when drinking too many beers was a bad idea? Me neither. |
03-29-2015, 11:22 AM | #1965 |
Finally finished up the engine and tranny re paint , rented a pickup and delivered it to The Paint Jail where my rig is looking very nice indeed .
Engine pix soon , I'm no where near my patch cable right now . Is there a separate thread for TH350 service ? . I have a couple Q's about mine .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
03-30-2015, 12:14 AM | #1966 |
Modified stock heater controls for vintage air streamline 4 knob controls
1970 2wd short/fleet 350/350 Project "iced green dream" http://67-72chevytrucks.com/vboard/s...d.php?t=272702 2006 Toyota Tacoma double cab 4x4 |
03-30-2015, 11:33 AM | #1967 |
It was yesterday but I ran the brake lines to the rearend. Once that was done I finally got to set the bed on for the first time. Mind you this is the first time I have ever seen this truck with any kind of a bed on it at all except in my minds eye or vision if you will. Been a long three months and still lots to go but at least I can now see that once I widen the bed about 5 inches it will look ok.
This is all phase 1. which is make it a running/driving truck. Phase 2. will probably start as soon as phase 1. is finished.
03-30-2015, 11:37 AM | #1968 | |
..................... ____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1970 C20 -_--_--_- ______ _--_--_- /___|__\____ -_--_-_ |_(0)|__|_(0)] 1972 K5 |
03-30-2015, 07:27 PM | #1969 |
03-30-2015, 07:31 PM | #1970 |
I dreamed and thought about driving it agin before 2016 as I was doing brake work on my '59 Metropolitan Nash FHC and installed the left front wheel bearings _backwards_ ~ old English cars use ball bearings and you have to install them with the thrust side facing in or you'll have troubles.... (duh) .
I'd cleaned and re packed them with the good Moly grease , installed new brake shoes all 'round , wish I was driving my truck instead . I had to take it all apart again and knock out the bearings , flip them over and re install , button it all up again . At least the dogs were happy ~ I usually close up shop earlier .
03-30-2015, 07:44 PM | #1971 |
I painted the white inserts/roof on my 72 cheyenne today!!!
03-30-2015, 08:54 PM | #1972 | |
http://amzn.com/B0055ARLUW
--------------------------- 1972 C10 LWB - Sold 1968 C10 SWB - 350/700R4 Jacob, DFW/TX Last edited by jrwild; 03-31-2015 at 01:38 AM. |
03-31-2015, 01:36 AM | #1973 |
And the work continues..... New tie rods (inner/outer/adjuster sleeve), idler arm, pitman arm, quick ratio steering gearbox and power steering pump.
03-31-2015, 03:12 PM | #1974 |
Today I installed 69-72 tail light bezels on my '67. Considering how rusty my truck is I was pleasantly surprised that all 12 holes drilled were into solid steel.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP |
03-31-2015, 10:13 PM | #1975 |
Drove it 225 miles over the West Virginia mountains...
