Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 04-13-2010, 02:51 PM   #176
fixit-p
fixit-p's Avatar
Re: Color Wiring Diagram FINISHED
Are you using part number PT298 the colors are not correct on your connector (the diagram is correct) but will still work below is a pic from BWD website for part number PT298 with the correct color code. Note the purple and brown wires.
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 04-13-2010, 06:37 PM   #177
actconstruction
Yes, but... Here's the problem... The one on the left is the one from the diagram. The one on the right is the one I have. Also, the diagram does not actually show enough prongs for the connector. Even the factory connector has two prongs on the left.
Last edited by actconstruction; 04-13-2010 at 06:40 PM. Reason: Pictures didn't upload
actconstruction is offline   Reply With Quote
Old 04-17-2010, 02:13 AM   #178
actconstruction
Okay, so the extra red wire is a way to wire something up that you want to always have power, in run, accy, off, and start. Such as??? Load limits?? Effects on the rest of the system?? The two purple wires on the diagram go on the SOL tab, second from left (the one you can't see on the diagram). The brown wires are correct (ACC). And the rest looks good. So, in other words, other than being a bit vague, the diagram IS correct. On a side note, nice work on the diagrams. If all that's true, then the wire that's missing goes to the "NFW Safety switch". Excuse my ignorance, but is that another way of saying Neutral Safety Switch (NSS)?? If that's the case, then awesome, because my truck never had one. Am I getting too far off topic here? I've been told I thread jacked already, so I'm trying to learn some online etiquette. Enough questions yet???
Old 04-23-2010, 07:20 PM   #179
70C10Toejam
Hellasick
70C10Toejam's Avatar
Originally Posted by blukangoo View Post
Iīd say that these wires have been put in by a previous owner. The wires in Fransiscos Diagrams are Factory. I have found a few things missing in the diagram but havenīt had time to change them or let Fransisco know.
I was looking here for this same issue, they are factory wires and are in the diagram. Any ideas what they actually do???
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes)
This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do.
RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!!
BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys
70C10Toejam is offline   Reply With Quote
Old 04-25-2010, 12:28 PM   #180
actconstruction
Toejam, the bottom wire seems to be a double of the wire that has the fusible link on it from the battery. Look where the power wire splits into four wires. One of those wires is supposed to have a fusible link on it and doesn't. They go the same place. I think the wire on the top is the same deal. It's trying to show the two wires with fusible links on them, but instead of showing it on the proper wire, the wires have been duplicated.
"Did you seriously just ask me what I need more power for?"
"You're stupid, cause I've smoked plastic."
Old 04-26-2010, 07:07 PM   #181
70C10Toejam
Hellasick
Took a few pics today...
The fuse at the battery connection
and the alternator junction (yes, I'm modifying it to add elec. fans)
and the back of the fuse block
All I really want to know is what do they feed?????
Old 04-26-2010, 07:10 PM   #182
fixit-p
fixit-p's Avatar
Those wires are for the factory ammeter
Old 04-26-2010, 09:44 PM   #183
70C10Toejam
Hellasick
fixit-p---Thank you! Thank you!
never thought it would be that hard to figure out.
Just something that was driving me crazy. Not that that's hard to do.
Old 06-10-2010, 04:18 PM   #184
RichardJ
Yes, the two fuses are for the Ammeter so don't mess with them. Your diagram isn't complete all the way way to the dash or you would probably have found where they went. If one or both of the fuses burn out, the gauge will not work.
That is not the best place to pick up your 12 Volts. The red wire that goes from there back over to the battery is already serving as the Alternator charging wire and provides the shunt for the ammeter. It doesn't need you tying accessories onto it.
I would recommend replacing that single pin insulated junction next to the battery. That one is to small and probably ready to crumble into 40 year old dust. That is where you should tie in your new accessories, next to the battery.
A lot of guys replace the original insulated post with one from a S10 and that is very similar to what you will find in a flaps. If you have a lot of accessories you could use two S10 posts. One would hold the battery wire and all original wires. A jumper from there to a second S10 post that would hold all of the new accessories.
I found a small fuse box with a large post on the bottom to hold all of the original wires. The fuses feed the various accessories as well as some relays in the corner.
In case you were wondering the radiator over-flow bottle is from a '70s Nova.
RichardJ is offline   Reply With Quote
Old 10-05-2010, 11:38 PM   #185
DBear
DBear's Avatar
hey guys, can someone send me a hi-res copy of the wiring diagram? My email is twbailey75@yahoo.com Thanks in advance.
Tommy
DBear is offline   Reply With Quote
Old 10-06-2010, 02:20 PM   #186
blukangoo
Neighborhood Pickle Slinger
blukangoo's Avatar
Tommy
Hi Tommy,
Go up to Post #163 and Download them.
I just checked them to make sure and the files are still online.
Greetz
Sean
My C10 Diary
Our cars:
1966 Chevrolet Chevelle 396 - TH350
1968 Chevrolet C10/CST 327 TH400/375
1969 Corvette Stingray 350 - Muncie Manual Trans
1969 Chevrolet ElCamino 350 - TH400
1970 Cutlass Supreme Convertible - 350 Rocket - TH350
1973 Camaro LT - New Engine Done - TH350
1973 Corvette Convertible 454 - TH400
blukangoo is offline   Reply With Quote
Old 10-12-2010, 06:45 PM   #187
djgj74
If possible could you send a copy to me as well thanks djgj74@yahoo.com thanks
djgj74 is offline   Reply With Quote
Old 10-13-2010, 04:04 PM   #188
Edmond
Edmond's Avatar
Now read the post above yours again....
Cya,
Edmond
1971 Chevy C/20 Longhorn, 350/TH400, Edelbrock Performer, IMPCO 425 LPG Carb
1974 Chevy Camaro Z28 (Original)
Capelle a/d IJssel,
The Netherlands
Edmond is offline   Reply With Quote
Old 10-21-2010, 07:54 PM   #189
gkesseru
gkesseru's Avatar
The wiper motor wiring does not match the shop manual:
72 Fleet (died)
78 Step (sold)
55 Step named Fred (sold)
00 F150
68 Step (named El Scorcho by PO)
Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932
gkesseru is offline   Reply With Quote
Old 10-24-2010, 09:16 PM   #190
bguild
bguild's Avatar
I am trying to figure out what size fuses I need for my fuse panel. I looked at this diagram and if they are on here i am not seeing them.. if they are not can any of you please point me in the right direction.. I am unsure what sizes of fuses go were in the fuse panel. Thanks I have a 67 chevy c10
Project "Edna Marie"http://www.67-72chevytrucks.com/vboa...74#post5998074
Toys:
2014 Dodge Ram
1967 SHORTBED
bguild is offline   Reply With Quote
Old 10-29-2010, 12:55 PM   #191
Tagar89
I'ma yearnin for some learnin!
Tagar89's Avatar
Sorry if i missed it, but im looking for a digram for my straight six. is everything the same? If not can someone post it or send it to me tagar89@gmail.com
1968 Chevy C10 Shortbed Stepside
Tagar89 is offline   Reply With Quote
Old 01-11-2011, 04:10 PM   #192
Cambons
Yeah im looking for the wiring for my straight six too. So if someone could tell me where on here i can find it or what?
Cambons is offline   Reply With Quote
Old 01-12-2011, 06:11 PM   #193
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
Here is what I have from my website goodies http://www.2heeldrive.com/Chevrolet/
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 01-12-2011, 08:22 PM   #194
Cambons
thnx Twistted
Old 02-01-2011, 01:26 PM   #195
atgilford
if u go to 4200x2250 and either save this diagram to a thumbdrive or your desktop u can blow it up and explore it and u wont have to ask someone to email it to you the link is at the top of the page
atgilford is offline   Reply With Quote
Old 02-01-2011, 01:40 PM   #196
atgilford
thanks for the diagram . On yesterday i was cruising and a wire got caught up off of the hid kit i installed and riipped a factory wire from some where and when i went to diagnos the problem it was a nightmare. So thanks a ton for your hard work and dedication to the cause
Old 02-02-2011, 09:02 PM   #197
actconstruction
Originally Posted by Edmond View Post
Great post.
I can remember years ago I posted an AutoCAD version of the 67-72 schematic. (http://67-72chevytrucks.com/vboard/s...d.php?t=232796) (Not sure if the links are still working )
But these PDF's are great to have. Thanks for posting them!
Cya,
Edmond
Dutch Longhorn
8)
No, the links are not working. Do you still have this autoCAD document? It would be invaluable to me. I am making a few changes in different areas, and I think it would be great to be able to change the diagram around to match. Thanks in advance.
Old 02-02-2011, 09:50 PM   #198
fixit-p
fixit-p's Avatar
I also have the pfs' and would love a copy of the cad version if they are still available.
Old 02-02-2011, 09:54 PM   #199
crakarjax
crakarjax's Avatar
Man, that cad version must have taken some time! Hope it shows up here again so people can get more use from it.
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 02-06-2011, 05:13 PM   #200
actconstruction
Originally Posted by boundstaffpress View Post
I would love to have someone temporarily or permanently host a high res. image on their web site. Let me know if you do this, and I'll edit the first post in this thread
I could probably host it if someone sends a hi-res to actconstructiononline@yahoo.com
I also have the original CAD documents from Edmond a few years back. I can't vouch for their accuracy but all looks well, and it's an AutoCAD so you can always modify (which is why I wanted it with all my junkyard upgrades). If anybody wants the AutoCAD version, just PM your e-mail address to me and I'll get it to you.
Or, somebody could e-mail the high-res versions of these to me at the e-mail address above and I'll just host these files along with the high-res pdf's. (Edmond just gave me permission to host the CAD files, so long as he keeps the credit, so: THIS PROFESSIONALLY RENDERED CAD DOCUMENT AND ASSOCIATED FILES ARE ENTIRELY THE PRODUCT OF EDMOND'S HARD WORK. WE ALL OWE HIM AND ONLY HIM OUR DEEPEST GRATITUDE. So there it is. Credit where credit is due. Thanks again. You're a lifesaver.
Last edited by actconstruction; 02-08-2011 at 01:41 PM. Reason: Got permission to distribute AutoCAD freely. Thanks.
