Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 10-13-2007, 10:10 PM   #176
msgross
msgross's Avatar
Re: 68 K-10 SWB build thread - project Money Pit...pics galore!
well, its been awhile since I posted.... due to the fact that its been awhile since I have touched the truck. I did pick up a nice black steering wheel off Ebay for $30, it has a few small cracks but it's a better start than my original... Decided to finally swap out those crappy motor mounts for a slightly less crappy set (both from India!). Atleast the 7/16" center bolt fits in this set.... Also cleaned up my power steering brackets since I noticed that they go with the motor mounts. Finally installed the "spin-on" fliter too! Hoping to get the carb and HEI back on this week and fire it up again....
It's always motivation to hear them run ya know....
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 10-14-2007, 04:46 PM   #177
turner15
I love how you grafted the snow blower on the side of the frame!
turner15 is offline   Reply With Quote
Old 10-14-2007, 08:59 PM   #178
msgross
msgross's Avatar
yeah, I might have to make a seperate build thread on that modification!
I picked that up for my 316 a few months ago but can't mount it till the mower deck is off... So there it sits
The Garage:
Old 10-14-2007, 09:25 PM   #179
samwise68
FarmBoy.
samwise68's Avatar
ahh..i love the look of fresh orange small blocks.
it's a beautiful thing.
looking goooood.
-Sam.
1969 GMC C1500. long fleet.
307. 3 on the tree. 3.07 gears.
Oliver green. Bent and bruised. Daily Driver.
Screw patina... it's a beater...Beaters are cool.
my build thread - Project Homebrew:
http://67-72chevytrucks.com/vboard/s...d.php?t=242993
samwise68 is offline   Reply With Quote
Old 10-21-2007, 08:42 AM   #180
msgross
msgross's Avatar
Decided to work on the ramhorns... Broke out the wire wheel on the grinder to prep for Hot Jet coating.... I'm having trouble with the AIR holes that are plugged in both sides. I'm trying to replace them with alan head plugs but 40 years of heat and rust are working against me....
I also seem to have some kind of alignment problems with the front pulleys.... What did I forget? I measured the old pump with the new and it's only 1/8" difference so it must be something with the crank pully.... any thoughts?
Carb is on, HEI is back in.... once the ramhorns are coated then its time for plugs, wires and hopefully starting it again...
Oh yeah, my spin-on filter adapter is leaking badly just while priming the engine... Anyone used on of them with success or should I just go back with the canister?
The Garage:
Old 10-22-2007, 08:52 AM   #181
turner15
Any chance you could upload a photo of the carb and throttle cable, kick down cable. I am reinstalling this now and want to make sure it looks good and works right.
Old 10-22-2007, 06:39 PM   #182
msgross
msgross's Avatar
mine has a manual tranny so no kickdown cable... and it has a throttle bar not cable since it's a 68. I also swapped the Q-jet for a Holley so it might look different anyway..... sorry
The Garage:
Old 10-22-2007, 09:38 PM   #183
68K20
Noobie McNoobster
68K20's Avatar
I went the easy route...I bought a set of good used mid-60's corvette rams horns for about $100 delivered. I used both 3747038 RH manifolds since I am using late model alternator brackets...
The Stable:
1968 Chevy K20 w/tilt, working AM/FM, AC and 350/350/205 w/Disk Brakes
1990 Chevy V2500 Suburban
2005 Kawi KLR650
1983 Honda Goldwing GL1100 Standard (Naked)
1995 Miata M
Fortes Fortuna adiuvat
68K20 is offline   Reply With Quote
Old 10-22-2007, 09:52 PM   #184
msgross
msgross's Avatar
I was going to buy a 2.5" set that one of the vendors was selling but wanted to stick with my alternator...
The Garage:
Old 10-25-2007, 04:47 PM   #185
70rs/ss
70rs/ss's Avatar
Is the balancer seated all the way in? It could cause the pulley to be too far out. Is that gun a sand blaster? I am looking for the blaster that hooks to the pressure washers? Looking good!!
70rs/ss is offline   Reply With Quote
Old 10-25-2007, 06:15 PM   #186
msgross
msgross's Avatar
I never removed the balancer... I think that it's the aftermarket el'cheapo water pump from Advanced auto parts. It works for now but I might try to return it later. The little sandblaster does OK but you still eat half the media (reminds me why I hate sandblasting) when it bounces back into your face.
Thanks...
The Garage:
Old 10-25-2007, 06:54 PM   #187
67_C-30
I have a radical idea!
67_C-30's Avatar
Originally Posted by Rust Buster View Post
I was looking forward to doing the same when I was down in training in AL, but when I asked around they all said to bring a big stick to ward off the snakes that are apparently all over those places, and I hate snakes...so I never went.
Yep, snakes galore down here. When I bought my '67 C-30 2 years ago, there was a huge Copperhead with babies under it. You get used to them though. The Rattlers and Copperheads usually try to avoid you, but the Cottonmouths are the ones you really gotta watch - They come after YOU!
I hate to be the buzz kill for you, but rust-free sheet metal is almost non-existent here. It's probably a lot better than what ya'll have, but when they are parked, the humidity does take it's toll.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 10-25-2007, 09:11 PM   #188
msgross
msgross's Avatar
YIKES!
guess I need a bigger stick then.... The sheetmetal can't be nearly as bad as mine or others in our boneyards.... I'm heading down to Ft. Rucker on Saturday to spend the next 6 months away from home.... gotta do something ya know..
The Garage:
Old 10-25-2007, 11:11 PM   #189
67_C-30
67_C-30's Avatar
YIKES!
Oh, there's definitely plenty of salvageable parts, its just that a lot of people north of here assume everything is perfect. What we consider badly rusted is usually better than average up there. I noticed on another you were talking about going to Moultrie. I highly recommend. There's always lots of good stuff there. Ft Rucker is only about 2 1/2 hours from here, and there are several good yards here locally that have plenty of 67-72's. When you get down and settled, shoot me a PM and I can show you around if you need some stuff.
My trucks
Old 10-26-2007, 08:04 AM   #190
msgross
msgross's Avatar
cool thanks for the assistance. I'll be sure to look up all the Alabama members in the next few weeks.
The Garage:
Old 11-13-2007, 12:18 AM   #191
soala70
soala70's Avatar
there is a place 45 min north of you called the truck farm its 10 min nne of troy al. need to look in to it 10ac of nothing but trucks
bogey5
soala70 is offline   Reply With Quote
Old 11-13-2007, 03:48 AM   #192
msgross
msgross's Avatar
cool, thanks for the tip...i'll look it up
The Garage:
Old 11-13-2007, 04:58 AM   #193
jamie72
jamie72's Avatar
looking good Mike!! good luck on your trip.
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 11-13-2007, 05:18 AM   #194
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
It's coming along Mike, looking good.
67_C-30,
I'm not usually afraid of snakes but I will admit that I did jump a bit when I scrolled down and saw that thing.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 11-13-2007, 07:50 AM   #195
65chevy4x4
Not many trucks like yours with the clearance lights.Lucky find!!!!
65chevy4x4 is offline   Reply With Quote
Old 11-13-2007, 07:32 PM   #196
68K20
Noobie McNoobster
68K20's Avatar
Anyone know where the clearnce lights can be obtained, I just noticed my truck had them originally, and I am thinking about putting them back.
The Stable:
2005 Kawi KLR650
1995 Miata M
Old 11-13-2007, 07:41 PM   #197
msgross
msgross's Avatar
The only one's that are identical to mine are in the LMC catalog. Only $37 for a complete set so let me know how they look. Mine are shot so I will be replacing them with the LMC set.
I did get the truck running before I left for school in Alabama. Realized my radiator is shot though... boy, once that pressure started building it was springing leaks like old faithful! I only ran it for about 5 minutes or so...
thanks for the words and good luck to everyone over the winter. I just heard that another classmate from flightschool died in the blackhawk crash in Italy. That's two out of 40 in 6 years. sad day...
The Garage:
Old 04-13-2008, 08:32 PM   #198
msgross
msgross's Avatar
Well, I am back from my Lower Alabama trip now, what a way to spend the winter!
Just picked up a new toy that I got on Ebay. Ready to start working on that cab now! Here's how the truck sat all winter That spin-on oil filter kit leaked like crazy so I went back to the canister type. I would like to get the cab blasted but not sure if the budget will allow that....
More to follow...
The Garage:
Old 04-13-2008, 09:21 PM   #199
Rust Buster
Rust Buster's Avatar
Nice welder Mike, is it a 140 or a 180?
Maj USAF
71 K5 Blazer CST
72 K20 HT383 NV4500 Mass-Flo EFI
71 K10 LWB
52 Dodge Power Wagon
67 Dodge WM300 Power Wagon
48 Dodge WDX Power Wagon
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=239487
Rust Buster is offline   Reply With Quote
Old 04-13-2008, 09:23 PM   #200
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
Glad to see you're back...looking forward to more progress.
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
