Old 07-30-2007, 04:50 PM   #176
killer71
killer71's Avatar
Re: Killers 5.3L install
Originally Posted by Ackattack View Post
I'm kinda concerned....is that tranny cooler going to be enough? I wouldn't think there is enough airflow underneath the cab to properly cool it. Something you might want to make sure of (maybe you already did.....if so disregard )
From the research i've found from different people the tranny cooler isn't necessary at all but to ease my mind while pulling my boats up into the Arkansas mnts I just wanted to make double sure the tranny would be o.k. We had planned on mounting a tranny temp gauge but it slipped my mind and I was gonna check with don to see if it was too late but either way, I think it will be fine mounted where it is from what i've read. The airflow flowing underneath the cab is supposed to be sufficient but if it's not i bet i know someone who can take care of it.
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 07-30-2007, 04:52 PM   #177
killer71
killer71's Avatar
I'll have to save for a year or two, I hope you're still doing this as I would seriously consider you doind a swap for me.
I have a 1972 GMC Jimmy and I think any modern 4X4 driveline would be sweet!!
Killer71 has posted about $13,500 (I'm sure that'll change) is that including the engine/transmission?
BTW You're welcome, you deserve the compliments. This should be a magazine feature!!
Yes thealien the $13,500 does include the engine/tranny. I have stop counting and don't want to know if it goes any higher.
R.I.P.
Killer 71
10/26/07
Old 07-30-2007, 06:07 PM   #178
Thealien
Thealien's Avatar
I also look at it this way. Many of us rebuild our engines, transmisions, and transfer cases at least once while owning our trucks. That alone can cost about what these engines are running that you are swapping in ($3500-5000?). That leaves $8-10,000 for this swap (68SS Labor and asst parts). These new FI engines all seem to go (just a generalizatios) 200,000 miles easily because they don 't run rich (gas washing cylinders) or lean (just as dammaging). Where the earlier engines usually we were happy with 100,000 miles before a rebuild (again I know just a generalization, some new engines die before 100, and some old engines have well over 200,000 but IMHO these are not the norm). Not to mention the increased fuel mileage. We would have to drive an awfull lot of miles to recoup $13,500 in fuel savings but getting 15-20 MPG as opposed to getting 8-12 out of our carbed engines might help us use/enjoy our trucks more than we do.
Also I for one wouldn't mind not having to wrench on my toy (although to some extent I enjoy it) and know when I want I can hop in and drive anywhere!!
Alright maybe I am just trying to justify it to myself LOL but I think it would be worth it. Starting saving now!
Old 07-30-2007, 06:22 PM   #179
killer71
killer71's Avatar
I agree with ya the carb and fi have their pro's/cons, and yea i like to work on my truck to...just at home and not setting on the side of the road. I guess it's just all in what a fella wants to go with and I chose what I chose so there is no turning back now. But i think i'll be more than happy with the end result.
Believe me when he gets through you'll see where the $$$ figure came from. There are several things that we've planned on doing that he hasn't revealed so...stay tuned!
R.I.P.
Killer 71
10/26/07
Old 08-01-2007, 06:32 AM   #180
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by 68 short step View Post
"the reason i installed it there was its hidden, yet accessable..and it controls the engine, trans, sensors, fuel pump, a/c clutch, starter, etc... all of this is under the hood and it keeps things nice and clean by not haveing to have a bulkhead connection on the firewall to connect things from the inside the cab to the outside of the cab
So what are you doing to hide the ECM???
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 08-01-2007, 10:48 AM   #181
68 short step
the ECM and TCM will be mounted on the firewall behind the engine, when the engine cover is on you wont see them unless you know to look there..
68 short step is offline   Reply With Quote
Old 08-01-2007, 10:54 AM   #182
shifty
Questionable
shifty's Avatar
Question: Is your quad-gauge electronic or analog?
I ask because I'm pretty sure that the PCM puts out serial data for the oil pressure and won't work with an electronic gauge.
I still (3 months later?) haven't received my speedo and tach from Jegs, still out of stock everywhere, but ... I am uncertain what gauges are actually going to work from the PCM output
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 08-01-2007, 12:16 PM   #183
killer71
killer71's Avatar
the quad gauge is electronic...don will have to chime in on pcm working with elect. gauge...I HOPE it will work tho.
I ordered the electronic set up from summit and don had em the next day.
R.I.P.
Killer 71
10/26/07
Old 08-01-2007, 02:34 PM   #184
68 short step
in answer to your ?, both, the guages are analog and electric.... IMO i dont like the idea of water or oil having the possibilty to mess up the interior.. and with the mechanical guage thats what could potentially happen.....
the PCM pinouts has a "SERIAL DATA" wire that goes to the guage cluster (this in most cases controls temp, oil, volts, etc...) you'll also have a "engine speed" wire pinout... you'll use this for your tach (set your tach to 4 cyl. mode, to read properly to the PCM output).. and lastly you'll have a "vehicle speed" wire pinout ( !!IMPORTANT!!---- the PCM gets its signal from the vehicle speed sensor, located on the tailhousing of the transmission... this sensor sends the PCM a 'sine wave' signal then the PCM turns it into a 4000 pulse per mile 'square wave' signal, and this is the pinout labeled "vehicle speed".... autometer guages are a bit diffrent pending on style you get... but you'll either have a pin labeled "SQ" for square wave, "SIN" for sine wave, or just one pin labeled "SIG" and you can connect either sine wave or square wave signals here.... if you use the the pinout on the PCM ( vehicle speed) connect it to the SQ pin if not you'll need to splice into the purple VSS wire and connect it to the SIN pin......
as for how im gonna make these guages work is im running the included sending units for the guages... i had to remove the plug on the pass side head and installed the temp sending unit there.... then on the oil pan i drilled and tapped the same "elbow" as you did and installed the oil pressure sending unit there....
Old 08-01-2007, 02:56 PM   #185
killer71
killer71's Avatar
Yea that's what I meant to say but that's way to much typing?
Don what the HE!! did you just say???
Guys again that's why Killer is at 68 ss's house...whew you lost me, i'm gonna have to read that again.
R.I.P.
Killer 71
10/26/07
Old 08-01-2007, 03:09 PM   #186
shifty
Questionable
shifty's Avatar
so, just to clarify, you used an electric sender for the oil pressure? i think i might replace the stock sender with an electric one ... but am sticking with analog for the time being.
Old 08-01-2007, 04:04 PM   #187
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by Stu Cool@LS1tech
I found a very useful adapter kit with 5 different fittings that will connect a 1/8 x27 NPT sender to M10 x 1, M12 x 1.5, M14 x 1.5 and M16 x 1.5 and 1/8" x 28 BSP. This will enable you to put a temp sender in the passenger side head without drilling or tapping. Also some aftermarket gauge manufacturers are stocking 12 mm senders now. Check with your gauge company.
Edit: I found that one of these adapters will also work with the oil sending hole at the back of the block behind the intake manifold. Just use the adapter, then a 1/8 npt nipple and a 90 degree fitting or what ever angle you need.
It is made by EQUUS, part number is #6848. Cost was less than $8 plus tax. I got it from my local Auto Parts. Much less expensive than the $16.50 for one fitting from one of the conversion specialists.
Pat
This is to use the supplied aftermarket senders or your stock ones if you want stock gauges. Or just drill and tap the elbow above the oil filter. I've also heard of guys drilling out the old temp sender. Wiring is easy, just use what's already in the vehicle, you should already have all the wiring for these at the fusebox bulkhead, or if you're real ambitious, route them through the LSX harness...
He just gave some priceless info on how to wire up a GenIII conversion. Should prolly cut/paste it to the LS1 FAQ...
-Chris
Old 08-01-2007, 04:17 PM   #188
shifty
Questionable
shifty's Avatar
good info on the adapter, not sure how i missed that info.
i still think i'm going to replace the adapeter on my oil pan and go electric.
Old 08-01-2007, 04:58 PM   #189
68 short step
ok here are the pics of the oil sender and the temp sender.... i drilled and tapped both the oil pan elbow and the head to install these... i didnt know about the adapter either, but wished i had, would of been easier...
aslo got the hidden hitch installed and the gas tank wont even be visable, so the stock look will be retained.... received the rear disc brake kit today and im macking it up, pics will be added soon of the install....
Old 08-01-2007, 05:19 PM   #190
shifty
Questionable
shifty's Avatar
the more i see your wire routing, the more and more i wish i had actually hacked my own wiring.
Old 08-01-2007, 06:37 PM   #191
killer71
killer71's Avatar
Oh Yea, KILLER dude!
R.I.P.
Killer 71
10/26/07
Old 08-01-2007, 07:00 PM   #192
indyracer
indyracer's Avatar
Which frame mounted trans cooler did you get?
Cheers,
Tony
A day without sunshine is like, you know, night.
1970 Chevy CST10 (Green)
2005 Silverado Z71
2000 Pontiac Bonneville
indyracer is offline   Reply With Quote
Old 08-01-2007, 07:17 PM   #193
1LoC10
Insert Title Here
1LoC10's Avatar
the passenger side tail pipe is just a tad bit lower, its hard to see, but it is...lol
Install looks awesome man, wish you lived closer to me
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 08-01-2007, 07:51 PM   #194
68 short step
Old 08-01-2007, 09:54 PM   #195
gringoloco
A guy with a truck
gringoloco's Avatar
What component is that between the mount adapter plate and the oil sender? Lookin' good btw...
-Chris
Old 08-01-2007, 10:09 PM   #196
killer71
killer71's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...128282413&rd=1
R.I.P.
Killer 71
10/26/07
Old 08-01-2007, 10:19 PM   #197
shifty
Questionable
shifty's Avatar
looks like a homemade heat shield, but don't recognize what would go there. looks like where my dipstick is mounted.
Old 08-01-2007, 11:45 PM   #198
68 short step
that is the knock sensor... on these DOD engines the valley cover isnt just a cover it is a valve body with electric solenoids to control the lifters... I.E cylinder shut off..........its a called VLOM (valve lifter oil manifold).... and thats a factory heat shield that i reused....
NOTE: on normal LS series engines the knock sensors are mounted in the valley cover under the intake
Old 08-02-2007, 12:20 AM   #199
gringoloco
A guy with a truck
gringoloco's Avatar
Aaahhh... 1 step forward, 2 steps back- goin' old school SBC style with the KS. I haven't delt with one of the DOD motors yet. Cool.
Keep up the good work -Chris
-Chris
Old 08-02-2007, 12:29 AM   #200
shifty
Questionable
shifty's Avatar
Ah, DOD (Displacement on Demand)
Note to self: Don't get one
