#176 |
Still livin the "dream" in '54
Re: Project: white knight 1967 step
Nice bed wood... keep it up!
D
Current build. 1954 Chevrolet 3800 "Ella" SOLD! My '67 stepper "Tangerine Dream" "Anything worth doing is worth doing right" James Dean “When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.” Sherlock Holmes "There is no spoon." Neo |
#177 |
Rusty but Trusty
The bed wood and strips look great in the pics.
Too bad about the drive shaft and starter, It seems like nothing goes easy any more. I think I voted for the 383 if you replace the six, but I think that the six is just plain coooool. Lee
72 SWB, 454 / th400... hoping the kids don't get all the parts before it gets built |
#178 |
mini truck racer
Just thougth i'd throw a quick update in . Been working on the little stuff that doesn't make for good pictures . Head light adjuster , reverse lights , prindle light , glove box light , wiring the evap blower , dome light wiring , added speakers under the seat . Ended up with a 73' truck wheel on it for right now . Thing is starting to come together . All the little details that are needed at the end take alot of time .
Looks like the Luv is gonna get a new home . I got an offer i can't refuse for it . I just haven't seen the cash yet . Camaro is slow going , but if the Luv sells it will progress alot quicker . 49 is slated to be finished by Christmas . Roofers are starting tommorow to repair the hurricane damage , so that's starting to get back to normal also . I'll be glad to not have concrete floors again .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
#180 |
Rusty but Trusty
Very sorry to hear about the LUV, but I sure understand. Sometimes the best deals are made when you really don't want to sell something.
Glad to hear about the house repairs. Did the Ins. co. treat you good enough? Pics of the '49 would be nice also. Lee
#181 |
mini truck racer
Got a little bit done today . I sold the 6 'er to a1953mdl ( spraybombs dad Lee ) so i pulled it tonight . I will be pulling the 355 out of the Luv tommorow and it will be going in . I have a new motor for the Luv and a 383 in the shop ( someday to be finished )
![]() I also scored a 10 bolt 8.5 from a 74' Nova today for $140 3.08 open . For those of you that aren't familair with 1st gen Camaros , this is the strongest bolt in axle for these cars and parts are readily avalible for them . The housings alone are going for $650 on feebay . Anyway here are the pics . ![]() ![]() ![]()
#182 |
Texas Big Wig
Super cool !!!!
I cant wait to come get the engine so I can see your Camaro !!!! What are the specs of the Luv engine ??? Last edited by Spray-Bomb; 11-26-2008 at 12:19 AM. |
#183 |
mini truck racer
92' 2 bolt truck block , vortec nodular iron crank , powdered metal rods , trw 2256 flattops , balanced within 1/2 a gram , XR288HR hydraulic roller 236/242 @.050 .520/.540 lift on a 110 , Gm aluminum fastburn heads w/210 runners making 10.2 to 1 and is pump gas friendly . Edelbrock rpm air gap . MSD HEI . demon 650 double pump (which will prolly be switched for a 625 road demon i have , Camaro will get the double pump ) alan grove pulley system . Will eventually go to serpintine . all sfi stuff . This little motor made 360 HP to the ground and 575 HP on the spray . It has been 10.20 @ the track . I have had good luck with it and it would be a shame to stuff it in a corner . it has great oil pressure and compression .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 Last edited by hotrod 80; 11-26-2008 at 12:29 AM. |
#184 |
Motor is looking good!
D
#185 |
Rusty but Trusty
I guess in time you will get use to the low power of the 8 vs the 6. LOL
Thanks for the great deal on the six. Lee
#186 |
mini truck racer
Just got in tonight . Started pulling the motor out of the Luv about noon . Found out about half way through all the major races for the rest of the year are cancelled ( thank goodness ) . Motor is in it's retirement home . All the bearings looked good and compression test was great . Anyway i'll let the pics do the talking cause im tired and have to work tommorow and all weekend .
#187 |
looks right at home in that bay, she is gonna purrrrrrrrr
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
#189 |
mini truck racer
Finished the wiring , installed water pump and alt , bolted up trans crossmember and torque converter . Installed shift linkage . Need to install coolent , fuel pump and lines , trans lines ( im 1/2 done ) driveshaft with new u-joints and exhaust . The center pin cross bolt is broken off in the carrier , so i bought a new series 3 posi unit for it also .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 Last edited by hotrod 80; 11-30-2008 at 12:50 AM. |
#191 | |
Rusty but Trusty
You really will need it with the LUV engine.
#192 |
looking good, keep the pictures coming, bed looking great
#193 |
mini truck racer
Tonights progress was good trans lines are run . Anyway here's another boring pic .
#194 |
mini truck racer
It's alive HaHAHAHA!!! ( in best sinister voice) and it kills 235 radials at will. More to come , now back to the lab egor .
#195 |
Texas Big Wig
Is that with the posi ???
And where is the burnout vid ??? At least some pics if no vid !!! |
#196 |
accepting donations
Where is the yard in the very first post? The one with all the trucks?
Any good junk yards in Baytown? I need a front clip from a 67-68.
1999 Yamaha roadstar 1600 chop. (in progress.) See my builds here>http://s113.photobucket.com/albums/n238/nickrp_2006/ "Ya'll can go to hell, I'm going to Texas." David Crockett Last edited by theyammieguy; 12-06-2008 at 10:04 PM. |
#197 |
keep up the good work.
1991 1500 longbed: my daily driver ![]() 1937 chevy 2dr sedan. dads project ![]() |
#198 | |
Texas Big Wig
#199 |
accepting donations
Sure could use the front clip off that red stepper.
Mine is a 68 with 71-72 front clip and I want it back to original.
1999 Yamaha roadstar 1600 chop. (in progress.) See my builds here>http://s113.photobucket.com/albums/n238/nickrp_2006/ "Ya'll can go to hell, I'm going to Texas." David Crockett |
#200 |
mini truck racer
This thing is visous with one wheel peel ! i put down over 60 yards of black in one shot . everywhere i go somebody is looking at it or talking about it . I got my "break in" mufflers on it right now , so it's a bit loud and it cams hard 236/242@ .050 with .520/.540 on a 110 , i mean come on Ain't no hidin that . I put a coolent reseivor (spl?) on it and replaced the driver side header gasket as it blew on start up . Hooked the back speakers up ( gotta have jams ) and adjusted the idle air mix . I still only have 28* timing in it and the throttle linkage is only @ 3/4 stroke . Im guessing 13 flat with a posi on drag radials @ 35/36 degrees and all the carb . The tranny barks second every time ( hard ). Even next to the law , which happened twice today . Gotta love $1.82 for super no lead , burned a 10 spot today for sure . prolly gonna have to put the spare down if i don't get the posi installed soon . The front sets right , but i need to go anothe rinch or so down on the rear . Got all my Vortec serpintine stuff today also .
The yammieguy , i got a hook up on a 67 front clip . I'll check on it next week . And that's spray bombs shop in the first pic and the red 68' is to clean to part out .
