Old 03-01-2013, 03:54 PM   #176
AJohn6
Knuckle head
AJohn6's Avatar
Re: Project Step Aside, 1971 SWB/Step
I know it has been a while since I have posted but rest assured because they have arrived.
Adam
'71 SWB/Step http://67-72chevytrucks.com/vboard/s...d.php?t=291750
2017 Crew Cab Silverado LTZ with 6.2l, 8 Speed tuned by RPM in Garner, NC
'00 Chevy 1500 6.0l Silverado Reg. Cab Short Bed
'09 Chevy 1500 5.3l Silverado Crew Cab Short Bed (SOLD)
1971 LWB on 2014 1 ton chassis, L96 6.0LS / 6L90E http://67-72chevytrucks.com/vboard/s...d.php?t=796785
1969 LWB C10- Future project, possible AWD C10 on a 2002 Escalade Chassis.
AJohn6 is offline   Reply With Quote
Old 03-01-2013, 03:55 PM   #177
AJohn6
Knuckle head
AJohn6's Avatar
This is the "finished" floor pan and firewall.
Adam
Old 03-01-2013, 03:56 PM   #178
AJohn6
Knuckle head
AJohn6's Avatar
Here are the new seats I got. Corbeau A4
Adam
Old 03-01-2013, 04:38 PM   #179
Zoomin
Man of Mini-Talents
Zoomin's Avatar
That's looking killer! All you lack is finishing up.
Zoomin is offline   Reply With Quote
Old 03-24-2013, 10:41 AM   #180
AJohn6
Knuckle head
AJohn6's Avatar
Here are a few more pics. I am still in the mock up phase and now trying to figure out a good way to mount the bed and still use the wooden bed. Right now I built a frame work out of 3/4" square tubing and I plan on using some rubber isolater material between it and the frame rails. I got the rear-end completed and welded up, third member installed, and Moser axles installed. I ordered Mar-K bedsides and front bed panel and they are some of the nicest replacement panels money can buy. I am also starting to mock up the radiator and other front end parts.
Adam
Old 03-24-2013, 10:47 AM   #181
raull
raull's Avatar
Working progress !!! Love it
check out my build thread
71 c/10 step side 5.3 twin turbo
http://67-72chevytrucks.com/vboard/s...d.php?t=485320
raul
raull is offline   Reply With Quote
Old 03-26-2013, 10:37 AM   #182
AJohn6
Knuckle head
AJohn6's Avatar
If anyone is thinking about getting the 80 Gallon single stage Kobalt air compressor from Lowe's, my advice is get a different one. I bought one a little over a month ago and followed all the lube guidelines, compressor gets hot leaks oil and now seizes up and can't get to 150 psi without blowing a 220v 30a breaker.
I love my local Lowe's and their customer service here, they are coming today with a new one and taking the old one back. The simple fact remains though, I should have done my homework and looked at the reviews of it. That's what I get for trying to save money by using my 10% military discount.
Adam
Old 03-26-2013, 12:53 PM   #183
Bennett68C10
Bennett68C10's Avatar
Truck is looking great, can't wait to see it back on the ground. Sorry to hear about your compressor issues, hopefully Lowes resolves them for you.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 03-26-2013, 05:02 PM   #184
gdavis
gdavis's Avatar
I bought the same compresser from Lowes. I used it about 6 months now. I had only one thing that went wrong with it. The main pulley on the compresser kept coming loose. I tighten it and now it is doing great. I have sand blasted and grind and used a DA sander and it keeps up with me. I am sorry for you trouble. But sometimes a bad one or a good one gets by. But it does get a little warm sometimes. So I mounted a fan over the compresser when I willl used it for a while. Signed some what happy with it.
gdavis is offline   Reply With Quote
Old 03-26-2013, 05:14 PM   #185
67cheby
67cheby
67cheby's Avatar
great progress, frame looks great, that radiator is pretty sweet too !
67cheby is offline   Reply With Quote
Old 03-27-2013, 10:39 PM   #186
AJohn6
Knuckle head
AJohn6's Avatar
Thanks man. The Lowes here have some great people working for them and they got it taken care of. I actually had it on the ground today to shift it around and give myslef some more room on the drivers side.
The compressor did run good until it stopped, haha. So they came yesterday and dropped off the new one and when I got it all hooked up I ran the break in period. I went to fill the tank and it wouldn't even fill up. After closer inspection someone did not push the compression sleeve on the tank inlet. Easy enough fix though. I called Lowes back up and had them pull the inlet tube off of the old one and swung by and picked it up. Got it put on and I can already tell that this one runs better than the last one.
Thanks man, hopefully I can get those slosh tubs put in soon.
Adam
Old 12-25-2013, 01:28 PM   #187
AJohn6
Knuckle head
AJohn6's Avatar
To the few who have been following this, I apologize for the lack of replies. I had to leave town for a few month for work and got home around Halloween. I hit a deer in my '09 right after lifting it an throwing new rims/tires on it. Had to get it fixed and it looks great now just spending time tuning it.
I also took a huge step and proposed to my girlfriend last night and the crazy girl said yes. WOOO HOOO!!! (There goes the money for the motor... Doh)
Adam
Old 12-25-2013, 10:45 PM   #188
BossHogg69
motor exploder
BossHogg69's Avatar
Congrats on the engagement! That '09 looks sweet as does what you've done to your '71. Can't wait to see the 'Step Aside' finished - great work so far!
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 12-26-2013, 06:53 AM   #189
Bennett68C10
Glad to see your back at it and congrats on the engagement. Can't wait to see more updates on your step side. Oh and your 09 looks pretty sweet too.
Keith
66 Suburban
IG: bennett68c10
Old 12-26-2013, 08:03 AM   #190
JointTech
JointTech's Avatar
did you fab that frame bracing or is it a kit? I saw a couple pages back you put in some supports and then on this page you magically have a full frame brace. details man!!! looks awesome.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 12-26-2013, 10:19 AM   #191
AJohn6
Knuckle head
AJohn6's Avatar
Thanks guys, the '09 along with the holidays has been sucking up most of my free time. The big tires are playing hell with the gas mileage and I am using HPtuners to tune it a little better.
Yeah I built it. The only stuff I didn't build was the 4-link and the touring dropmember and A-arms. I made a template I thought would look good and bent it up at work.
Adam
Old 12-29-2013, 07:43 PM   #192
AJohn6
Knuckle head
AJohn6's Avatar
I realized that I never posted photos of the cab after I epoxy primed it prior to my deployment. I also started to smooth out the cowl.... wish me luck.
Adam
Old 12-30-2013, 12:51 AM   #193
Graham57a
Graham57a's Avatar
You're going to have a killer truck when you're finished. Subscribed
ANDREW
1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072
1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827
1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315
1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788
1972 Chevy SWB Highlander OLIVE Build thread coming
Graham57a is offline   Reply With Quote
Old 12-30-2013, 11:03 PM   #194
mcbassin
Still Learning
mcbassin's Avatar
Love your truck! you have made some killer progress since starting. This thing is going to so nice. I feel your pain with all the rust repair and body work. Subscribed....
mcbassin is offline   Reply With Quote
Old 01-03-2014, 07:52 PM   #195
AJohn6
Knuckle head
AJohn6's Avatar
Got a little done over the last couple days. Finished smoothing the cowl and TIG welded some brackets with nutzerts in them to the radiator to mount it a little cleaner than I had it before. I am happier with the way it looks I just wish my TIG skills weren't so rusty. I also replaced the PS lower lip with a hand made one and modified the radiator opening a bit.
Adam
Old 01-03-2014, 07:54 PM   #196
AJohn6
Knuckle head
AJohn6's Avatar
Adam
Old 01-03-2014, 09:06 PM   #197
Bennett68C10
Nice job on the cowl, looks great
Keith
66 Suburban
IG: bennett68c10
Old 01-03-2014, 10:07 PM   #198
Graham57a
Graham57a's Avatar
Looking killer man, whats next on the to-do list?
ANDREW
Old 01-03-2014, 11:14 PM   #199
AJohn6
Knuckle head
AJohn6's Avatar
The to do list is a mile long and I seem to jump around from one part to another. I was at a stand still on the rest of the frame until I figured out how I was going to mount my roll cage to the frame. I need it to warm up so I can epoxy prime some more blasted parts and the frame but it has been too cold to get it done. I am going to paint my frame rather than powder coat since it is going to be a continuing project. I am nearly certain I am going to change a couple things prior to final assembly and removing and reapplying paint is a heck of a lot easier than powder coat. I may make the solid body mounts I need and get the cab mounted and start installing the cage.
Adam
Old 01-04-2014, 12:09 AM   #200
Graham57a
Graham57a's Avatar
Nice, yea idk about down where you are but up here in Boone we got 5 inches of snow last night. Now exactly painting weather haha. How are you gonna do the cage mount? I always pictured doing mine like an old go-kart, just have the tubing come through the bottom of the cab on all four corners and have a couple of inches of bigger diameter tubing sticking out of the frame so it slides right in and a bolt going through to hold it all tight.
ANDREW
