07-06-2010, 07:45 PM | #176 |
big guy
Re: Dropmember Rear 63-72 Spy Pic
Thanks for your insight Scoti that is why i ask you guys! you guys know your stuff. So atleast now i know it's 13" across. As for width on the wheels they don't come in 11" only 10" or 12". here is a pic of the wheel i want to run. I don't know why i am trying to push the limits, i should just go with a tried and true wheel and tire combo. The 295x40x20 on a 10" with 5.5bs and stop going crazy over it, atleast i know it works and looks cool. It would suck if some one else did it next week and it looked killer! lol oh well
thanks again. Ray |
07-06-2010, 10:24 PM | #177 | |
07-07-2010, 06:41 PM | #178 |
big guy
I do like to see a nice side wall, i'm not into the rubber ban look myself, but each there own. As for the front you nail it, that is what nathan said would work out best with a 5.25 bs. I need to order those wheels so i can get this old girl back on the road. Thanks Scoti
Ray |
07-07-2010, 09:56 PM | #179 | |
R/ EDIT: You could always buy one of these to help you figure the wheel and tire size out: http://www.jegs.com/i/Percy's/760/01201/10002/-1?CT=999
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 07-07-2010 at 10:01 PM. |
07-07-2010, 10:33 PM | #180 | |
The issue here is a 12" wheel w/Porterbuilts rear DM-T/A kit. The placement of the bags is not in the OE location & that's where interference would/might occur.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 07-07-2010 at 10:34 PM. |
07-08-2010, 06:53 AM | #181 |
big guy
thanks for the tip hart rod. Maybe some one on the forum has one i can use or buy cheaper. Scoti is right i have a different setup then stock and it's so new that not many people are running it. Plus Nathan made mine special because i didn't want the really big notch, i am at about 5" witch is half of what they are. i really wish i had a wheel to play with maybe my local wheel shop has something i can barrow? i'll have to look into that.
by the way your truck looks killer with those big wheels and tires! Thanks Ray |
07-08-2010, 06:57 AM | #182 |
67-72 parts collector,…
Ray,... can you do your measuring with a stock 15" steel wheel (with no tire installed)?
I have the Percy's wheel tool that I just recently purchased here on the board. I can send it to you if you need it. (I may sell it actually) I like my homemade backspace tool much better anyway.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 07-08-2010 at 07:05 AM. |
07-08-2010, 05:07 PM | #183 |
big guy
do tell about the home made unit! if you don't want to say i understand i would still be interested in buying the tool if you decided to sell.
thanks Keith Ray |
07-08-2010, 11:21 PM | #184 |
Ray I have the Percy's tool that I would sell. ($35 plus shipping) PM me if you are interested.
The "homemade tool" that I show in the picture,... is made from plate steel The tool has two bolt patterns is drilled into it. (5x4.75 and 5x5). The different length threaded rods, represents the wheel width. (11" rod for a 10" wide wheel ,for example) This tool has threaded holes spaced in the arm for 15", 18" and 20" wheels. It works great. You bolt the tool to the rotor or rearend. This allows you to rotate it 360 degrees to check for interference. Up front you can turn the wheels and rotate to check for any problem areas. The only thing it won't do,... is check tire height. But I do that with a tape measure. When we measured 72BlckButy's truck for wheels I planned on using this. But Nate kept his truck a 6-lug truck,... so I had to make another tool that has the 6x5.5 pattern on it. It's not hard to build, if you have an accurate way to drill the bolt patterns. I used a mill at work. Sorry to hijack this thread way off track.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 07-08-2010 at 11:25 PM. |
