Old 02-15-2012, 12:54 AM   #176
greystoke
Re: project BIG RED (gen3 on air)
welcome to SPEED building with your host 68 shortstep
"Fear makes the wolf look bigger"
http://67-72chevytrucks.com/vboard/s...d.php?t=305629
greystoke is offline   Reply With Quote
Old 02-15-2012, 12:01 PM   #177
ERASER5
ERASER5's Avatar
GASP! The tie rods have RUST!
Yea, I know, I'm just envious. I like the weather pack plugs. Things like that makes your build very interesting to me.
This is the one with the smaller engine right? Do you have any guesses as the the possible MPGs?
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 02-15-2012, 06:21 PM   #178
68 short step
yea, the tie rods are new (altho not in that pic).... i like to make everything modular, and factory functioning, so weather pack connectors are the only way to go.... as for MPG im guessing with the 373 gears i have, about 20mpg..
68 short step is offline   Reply With Quote
Old 03-29-2012, 09:21 PM   #179
68 short step
welp, of coarse, painters are a breed of their own (they must breath all them fumes to long) i checked in on the cab, and after 2 months it was almost the same as when i dropped it off, but it did have alot of additional bondo all over it, over rust, paint, pinholes everywhere, and everything else...so needless to say, i picked it up and brought it to another shop...where they sanded on it for about 30 mins, and suggested that it get blasted, then they'll get me a better idea of where we stand....so thats where we're at... it was blasted, and we found all the thin metal, now its holey...so they are tackeling more rust repair.....i should of found a new cab along time ago, lol....
the first set of pics is the shotty work the first shop did, and it only took them 2 months too...
the second set of pics is the blasted cab, doors were too, but now they are wearing primmer, since they were in good shape...
Old 03-29-2012, 09:22 PM   #180
68 short step
Old 03-29-2012, 10:10 PM   #181
67cheby
67cheby
67cheby's Avatar
Well it's looking good now , at least you caught it before they had it all covered up !
67cheby is offline   Reply With Quote
Old 03-30-2012, 07:02 AM   #182
rob32472
Painters are a breed of there own, I am really glad I have found a good one that is dependable and does what he says..... he is not the cheapest guy around but I beleive he is well worth it.... I hope you find a good one
rob32472 is offline   Reply With Quote
Old 03-30-2012, 08:44 AM   #183
mcbassin
Still Learning
mcbassin's Avatar
Lots of good progress on this project!
mcbassin is offline   Reply With Quote
Old 05-29-2012, 07:28 PM   #184
68 short step
little progress to report from the painters...he got the doors fit, and primed... he wanted me to take the cab, bolt it down on the frame, then bring it back to do the final fit of the doors, and paint the rest of the cab.... so i bolted the cab on and started doing some of the little (very time consuming) things
Old 05-29-2012, 07:30 PM   #185
68 short step
Old 05-29-2012, 07:49 PM   #186
68 short step
once the cab was bolted down, i started getting all my pedals blasted, painted, lubed, and rebuilt with new pads/hardware/knobs...
Old 05-29-2012, 07:58 PM   #187
68 short step
i also rebuilt a factory tilt, with a few upgraded knobs, pointers, gear displayes, etc... (note to self: put the lower seal on facing the right way, or you'll be taking apart the column again )... here are a few pics
Old 05-29-2012, 08:03 PM   #188
68 short step
blasted and painted the misc brackets to hang the column...
Old 05-29-2012, 08:07 PM   #189
n2billet
Village Idiot....
n2billet's Avatar
Very nice!
http://www.hubgarage.com/mygarage/n2billet
-67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold
-71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold
n2billet is offline   Reply With Quote
Old 05-29-2012, 08:08 PM   #190
68 short step
once i had the column installed i did a little custom gear shifter rod bending....ive done a few of these swaps, useing the same engine/trans, and the 'normal' way i bend them wouldnt of worked for this setup, im not sure what was so diffrent with this setup, but i got it all bent up and shifting well....
Old 05-29-2012, 09:23 PM   #191
kev2809
low n' slo
kev2809's Avatar
Lookin good man, nice progress!
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 05-29-2012, 10:32 PM   #192
mcbassin
Still Learning
mcbassin's Avatar
Very nice work on everything. Couple of quick questions, what's the part number for the Lokar shifter linkage?-(?CA-1800) Where did you buy the replacement parts for the tilt? How did they fit? thanks
Old 05-30-2012, 10:08 AM   #193
67cheby
67cheby
67cheby's Avatar
looks GREAT !
Old 05-30-2012, 05:21 PM   #194
68 short step
shift rod kit is aca-1800, and kennys trucks is where most the parts came from... he is local to me ,and is a great guy
Old 05-30-2012, 10:53 PM   #195
mcbassin
Still Learning
mcbassin's Avatar
Thanks Don, I use Kenny's as well I will hit him up when I get ready to buy my tilt parts. Keep up all the hard work.
Old 07-03-2012, 10:17 PM   #196
68 short step
heres a little update.... i got the steering all done... i rebuilt the steering shaft with a new rag joint, blasted, and painted it....
then to top everything off, a new grant steering wheel, its simple, yet gives the truck a retro feel...
Old 07-03-2012, 10:24 PM   #197
68 short step
i then turned my attention to getting the brake system complete... i ordered a new master/booster assy from performanceonline, painted the master cylinder, and installed it. once it was installed i bent up some stainless 3/16 lines to connect the prop valve to the brake lines i already made up.
Old 07-04-2012, 12:05 AM   #198
VA72C10
VA72C10
VA72C10's Avatar
Looking good!!!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 07-04-2012, 08:51 AM   #199
67cheby
67cheby
67cheby's Avatar
Super nice !
Old 07-04-2012, 09:52 AM   #200
RaceAGMC
RaceAGMC's Avatar
Yet another sweet build. Any chance you have part nuMbers for all the steering hose fittings. I am working on plumbing my steering I also have a Gen III swap in my truck with a factory power steering chassis.
70 CST, 6.0/ 4L80E in the works.
*Custom harness by 68 Short Step*
RaceAGMC is offline   Reply With Quote
