Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 03-19-2016, 12:38 AM   #176
Will206
Re: Hydroboost Mounting Plates
Originally Posted by Captainfab View Post
All you need is a factory hydroboost mounting plate for a '73-'86 C/K or a '87-'91 R/V truck, Suburban or Blazer. Then just remove the factory '99 mounting bracket and install the earlier one. As for connecting to the pedal, some fabrication may be needed. I'm not sure as I have not done anything like this. It would likely be a whole lot easier to just get a '73-'86 C/K or '87-'92 R/V hydroboost and bolt it up.
I'm kinda limited in terms of selection, I'm out in the middle of nowhere South Dakota, so my primary resource is the internets. I sourced that unit on eBay for $99 bucks, in an effort to save a bit. I'm not too concerned about the pedal situation, I'm going to thread the rod and put an adjustable linkage to the pedal, I may have to modify its connecting location as well because I think the geomtry is a bit different.
I've never seen the bracket for sale by itself, which I think would look like this:
https://imgur.com/a/HUH6U
I could buy the pump with the plate for $180+$60 core+ I'd still need the proper res and I think the pedal is still wrong so I'd have to modify that or replace it as well.
If you happen to know where to locate a plate like that, awesome. Otherwise perhaps you could just sell me the plate and the bracket sans mounting holes, I could drill them myself.
Will206 is offline   Reply With Quote
Old 03-19-2016, 01:17 AM   #177
Captainfab
60-66 Nut
Yes that is what the correct mounting plate looks like. Have you checked the '73-'87 classifieds here on the forum for a hydroboost? If you were to purchase a rebuilt hydroboost for a '89 V2500 from your local auto parts store, it should come with the bracket.
Of the 3 standard booster brackets I make, I don't know if any of them would work in your application. I do not drill any holes. All of my parts are CNC laser cut, which includes all the holes.
Old 03-19-2016, 01:21 AM   #178
Captainfab
60-66 Nut
Here is a truck with a complete hydroboost unit, master cylinder and all. You could likely get everything you need from this one source.
http://www.67-72chevytrucks.com/vboa...d.php?t=700334
Old 03-19-2016, 10:41 AM   #179
Classic v6 GMC's
Classic v6 GMC's's Avatar
So will this bracket work with a 2000 GMC 2500 hydroboost unit?
A friend is swapping a 6.0 and 4l80 out of a 2000 GMC 2500 into his 1971 El Camino and the GMC has hydro boost. I am trying to help him figure out if we can make it work.
Thanks, Andy
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Classic v6 GMC's is offline   Reply With Quote
Old 03-19-2016, 11:25 PM   #180
Captainfab
60-66 Nut
All GM hydroboost units that I have seen are all the same once you remove the factory mounting bracket. So yes, this hydroboost mounting plate will work on a 2000 model year hydroboost once the factory bracket is removed. As for mounting it to the '71 El Camino firewall, you will either have to open up the center hole and drill holes for the mounting plate, or fabricate a booster bracket similar to what I make for the '60-'72 trucks.
Thanks, Andy
Old 03-19-2016, 11:51 PM   #181
Classic v6 GMC's
I was thinking that we can mount it to his stock power brake booster brackets.
Please PM me total for the hydroboost plate and special socket along with Paypal info and I will get you paid.
Thanks,
Andy
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 03-24-2016, 06:32 PM   #182
Classic v6 GMC's
Thumbs up Re: Hydroboost Mounting Plates
Parts arrived today. Quality parts and great packaging!!
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 03-26-2016, 11:03 AM   #183
BBPanel
What determines the HB pedal rod displacement distance? Does the m/c dictate that or does the HB pedal rod have its own unique travel length? Would seem like the m/c should be the determining factor - I'm retrofitting a HB and need to determine what my pedal travel should/needs to be. -Bob
BBPanel is offline   Reply With Quote
Old 03-26-2016, 12:37 PM   #184
Will206
I haven't a clue to be honest. I replied to the guy Capitanfab said had one but I haven't heard anything back, right now I am planning on using the rivited bracket off my old booster and a hydroboost mounting plate. I will then cut the end off the HB pedal rod, thread both halves and use a adjustable type linkage in between. Possibly off something like a turn buckle, but add jam nuts. I still have to figure out the *actual* angle of the rod because I know the HB units generally connect a little higher on the pedal. I was really hoping to find just a HB brake pedal but haven't had any luck yet.
Old 03-26-2016, 04:00 PM   #185
Will206
Here is a custom setup from http://www.custompowerbrake.com/: http://i.imgur.com/fKY8Kcp.jpg
Old 03-26-2016, 11:47 PM   #186
Captainfab
60-66 Nut
Sorry but I'm not understanding what you mean by 'pedal rod displacement distance'? As for connecting the hydroboost pushrod to the brake pedal, you will probably want something in the neighborhood of a 4:1 ratio.
Old 03-27-2016, 12:27 AM   #187
BBPanel
When you apply the brakes how far does the HB pedal rod move before it bottoms out - or will the m/c bottom out first?
Old 03-27-2016, 01:29 AM   #188
Captainfab
60-66 Nut
I do not have that answer. I have not installed a hydroboost yet and I do not have an operational one to measure. I am not in the business of working on cars and trucks for others and no time for any of my own with working 80 hrs a week.
Old 03-28-2016, 04:49 PM   #189
juddss
Posting so I can find thread again. Looks nice
juddss is offline   Reply With Quote
Old 04-05-2016, 06:46 PM   #190
YOLO
Custom Truck Lover!
YOLO's Avatar
Captainfab.
Here are the pictures of my hydroboost from mcgaughys. I also included pictures of my 64 c10 fire wall. Do I buy your bracket, unbolt the bracket on my hydroboost, bolt your bracket on, then mount it to the fire wall? Or do I just use the bracket that came with my hydroboost and re drill it to match the fire wall? I just installed your PS adapter plate and worked out perfect. Thank you.
Name:  2016-04-05 15.37.57.jpg
Name:  2016-04-05 15.38.01.jpg
Name:  2016-04-05 15.38.48.jpg
Squarebody guy
YOLO is offline   Reply With Quote
Old 04-05-2016, 09:29 PM   #191
doublebeetx
The picture you posted isn't a hydroboost, that is power brakes via vacuum. You simply bolt that to the firewall as you have it. Hydroboost uses hydraulic pressure via the power steering pump, not vacuum.
doublebeetx is offline   Reply With Quote
Old 04-05-2016, 11:13 PM   #192
YOLO
Custom Truck Lover!
YOLO's Avatar
This is part of the front disc brake kit I bought. The master cylinder bolts to it. The holes do not line up with the fire wall and I prefer not to drill the fire wall. I would rather re drill the bracket to fit the holes on the fire wall.
Squarebody guy
Old 04-05-2016, 11:17 PM   #193
Captainfab
60-66 Nut
As stated by by doublebeetx, that is a vacuum booster noot a hydroboost. To mount that vacuum booster to your firewall you need one of my booster brackets shown in this fro sale thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=339081
However I do not know what the mounting stud pattern is on that booster. You will have to check that and see if it is the same as the holes in my booster brackets.
Old 04-18-2016, 03:05 PM   #194
Budman56
Budman56's Avatar
I should have known that you (captainfab) has already built a adapter plate for the hydro boost conversion. I just did this swap on my dodge cummings truck which will later become a 65 chevy cab on the dodge frame.
MY 65 C20 BUILD
http://67-72chevytrucks.com/vboard/s...d.php?t=483346
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
Budman56 is offline   Reply With Quote
Old 04-18-2016, 08:11 PM   #195
Theboatandcarman
ended up not needing the hydroboost plate. here we are
Theboatandcarman is offline   Reply With Quote
Old 04-30-2016, 07:40 PM   #196
burnitg
Originally Posted by Curtb1971 View Post
Thanks Captianfab! Finally got the my hydro boost mounted tonight.
CaptainFab:
What is your price for the direct mount plate, in bare steel, like the one you made for Curtb1971?
Thanks,
Burnett
burnitg is offline   Reply With Quote
Old 05-01-2016, 12:10 AM   #197
Captainfab
60-66 Nut
I'll send you a PM with ordering and payment info.
Originally Posted by burnitg View Post
CaptainFab:
Thanks,
Burnett
Old 06-26-2016, 12:57 AM   #198
Possmguts
Possmguts's Avatar
so.. with the hydroboost, I only need a direct mounting plate to keep it tight and clean to the firewall?
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline   Reply With Quote
Old 08-08-2016, 12:55 AM   #199
Captainfab
60-66 Nut
I will be on vacation from 08-08-16 thru 08-25-16. If you wish to make a purchase you can post here in this for sale thread, send me a PM or an email to captainfab454@hotmail.com. I will reply to your inquiry when I return on the 25th. I do currently have a list of orders to build and ship when I return but I will add your name to the list in order of when received. Thanks for your understanding.
Old 08-08-2016, 11:28 AM   #200
solidaxel
solidaxel's Avatar
I made up a couple extra of the hydroboost nut sockets. The cost on these is $52.50 each plus a flat $10.00 for shipping. If purchased with a hydroboost adapter plate, the shipping for both would be $10.00 as well. additionally, if you purchase either of my booster adapter brackets along with the hydroboost adapter plate and the socket, it's still $10.00 for shipping. Plus you get $5.00 off on the hydroboost adapter plate.
Has Anyone found anymore uses for this size socket, other than the Hydro boost nut?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
