Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 01-31-2022, 12:40 AM   #176
Captainfab
60-66 Nut
Re: '60-'62 POwer Brake Booster Adapter Bracket With A Clutch
Two of the pics included with your order show how that is installed as well as all the other linkage components.
Old 01-31-2022, 01:16 AM   #177
sirJim
Originally Posted by AngryPirate View Post
Does anyone have a picture of this part installed?
You mean like this?
http://67-72chevytrucks.com/vboard/s...d.php?t=737695
62 burb in the making.
sirJim is offline   Reply With Quote
Old 01-31-2022, 11:25 AM   #178
AngryPirate
AngryPirate's Avatar
Yes, those pictures were helpful, but the one picture with the new inside linkage fitting were should not installed (it was a picture of basically the ordering of the parts with no indication of where the firewall fit into the assembly), so i was a little confused since the step-off of the notched nuts seemed a little more than I would've expected, but if that is the way it goes on, that's great. I was just making sure I had the correct part and was installing it properly before drilling any more holes or holes that were bigger than needed.
Thanks for the response.
AngryPirate is offline   Reply With Quote
Old 01-31-2022, 11:26 AM   #179
AngryPirate
Originally Posted by sirJim View Post
You mean like this?
Not those pictures. Those are the old linkage fitting installed.
The new linkage fitting it the one I posted in my question.
Old 02-01-2022, 08:30 PM   #180
AngryPirate
I figured it out. Here's a picture of the newer style (past ten years) of linkage installed.
Old 02-16-2022, 09:14 PM   #181
Carkrazy1987
anyone installed an lt1 t56 with this bracket? how is the pedal feel. ive put almost 10k on my setup, and i feel like my leg is going to fall off. i thought maybe the clutch was garbage, but i just changed it to a new factory unit, and clutch is still hard. hard enough that i doubt my wife could drive the truck. any ideas?
Carkrazy1987 is offline   Reply With Quote
Old 02-17-2022, 07:53 AM   #182
Carkrazy1987
Also after looking at the setup, we are installing the push rod on the lower hole in the pedal. By doing so arent we changing the pedals effective ratio. My quick measurement shows current setup to be 3:1 ratio. Movin the push rod hole up 2in would change the ratio to a better 5:1 but not quite the recommended 6:1 ratio. Am i wrong in my measurements and assumptions here?
Old 02-17-2022, 10:58 PM   #183
Captainfab
60-66 Nut
What bore size is your clutch master? For that hydraulic release bearing it should be a .750" bore. The clutch pedal shouldn't be that hard to push. A hard pedal is often times a clutch master with a bore size that is too large. The object of the linkage assembly on the inside is not so much to achieve a certain pedal ratio but more so to achieve a full pedal travel while not overstroking the clutch master.
Old 02-18-2022, 12:44 PM   #184
gijoec
Hey Captainfab - I finally got back on this site and I'd like to order another 60-62 power brake adapter set-up. I want the complete package w/hydraulic clutch master and powdercoated black. Also need the hydroboost plate. Thx!
gijoec is offline   Reply With Quote
Old 02-18-2022, 01:41 PM   #185
Carkrazy1987
I have the 3/4 master that came with the kit. And i understand the reasoning of the lever on the master assembly, i was more referring to the pedal side of the pushrod. If comparing the mechanic leverage from the factory location and the new location, the pedal ratio changes drastically. I will redo my measurements this weekend, but i do think the pedal pushrod should be mounted closer to the pedal pivot
Old 02-18-2022, 09:31 PM   #186
Captainfab
60-66 Nut
PM sent.
Old 02-18-2022, 09:36 PM   #187
Captainfab
60-66 Nut
I really don't think the mounting point on the clutch pedal is the issue. I have sold over 2000 of my hydraulic clutch conversions and no one else has had this issue that I know of.
Old 02-21-2022, 06:41 PM   #188
Carkrazy1987
oh i dont doubt the product,i love the product, it does its job. i ended up moving the attachment bolt up 1 in on the pedal. made a big difference in feel, and also i dont have a napping/popping my pedal was doing before. may have been just too much for the lt1 clutch. also i maybe the pushrod more level, and doesnt "push up" on the lever, and more push on it.
Old 02-21-2022, 11:46 PM   #189
Captainfab
60-66 Nut
The pushrod between the pedal and the link bar is supposed to be fairly level in the first place.
Old 03-17-2022, 07:14 PM   #190
Captainfab
60-66 Nut
Here is a link to my new website and online store where you can see and purchase all of the products that I fabricate for the '60-'72 GM trucks.
https://customfab-cda.com
Old 04-04-2022, 11:27 PM   #191
60short
60short's Avatar
I accidentally posted this in the regular bracket thread, but another bump (probably) never hurt!
Hey Captain!
I am definitely a newbie to this whole thing, but can you tell me the difference between master cylinder bore, or how to calculate which one I should use?
I am looking to make minimal changes, but I have a transmission swap coming up ( t5) and I figure this is the only way to keep things straight while maintaining my drum breaks
Thank you
1960 C-10 Apache- "Rusty the Redneck Reject"
1/2 Ton short bed step side.
350 crate motor, 3 speed manual (floor shifted) MKII - Buddy Buckets and Glass Packs
20+ year long term project in process
Lots of Rust, more memories...
60short is offline   Reply With Quote
Old 04-05-2022, 10:29 PM   #192
Captainfab
60-66 Nut
To figure the needed bore size of a clutch master I usually look at what GM used as a reference, if you are using a factory clutch slave cylinder or hydraulic release bearing. If you are using aftermarket slave or hydraulic release bearing, the manufacturer typically has a recommendation on what bore size of clutch master to use. If you are keeping the original '60-'62 clutch slave cylinder, you will need a 1" bore clutch master.
Hey Captain!
Thank you
Old 05-03-2022, 04:00 PM   #193
AngryPirate
Old 05-04-2022, 10:09 AM   #194
AngryPirate
I finally got everything installed and bled.
Was not easy, but the CaptFab adapter plates made it MUCH less painful.
Old 05-05-2022, 09:51 PM   #195
Captainfab
60-66 Nut
That is a nice clean installation
Old 05-06-2022, 10:47 AM   #196
AngryPirate
Thank you, sir. :-)
Old 03-21-2023, 04:00 PM   #197
Matt's k5
BLAZER THIRTY!!
Matt's k5's Avatar
Hey Captain Fab, I'm on your website right now. I'm confused of some of the options of this kit looking to purchase his kit for my 62,
49 chevy 5 window 20 year project (sold)😟
57 ford fairlane (dad's car never got to it before he passed away R.I.P I LOVE YOU DAD.)
62 GMC 305 V6 custom L/B
72 HIGHLANDER K5 BLAZER 2nd owner
71 K5 MAMMA'S RIDE!
63 GMC 4X4 305 V6
62 GMC SHORT BED SERVICE BODY V6 (STUMPY)
74 GMC CUSTOM 1500 L/B
Matt's k5 is offline   Reply With Quote
Old 03-21-2023, 04:14 PM   #198
Captainfab
60-66 Nut
What options are you confused about?
Old 03-21-2023, 04:49 PM   #199
Matt's k5
BLAZER THIRTY!!
Matt's k5's Avatar
its saying remove booster bracket is that talking about hydro boost? i also emailed you
71 K5 MAMMA'S RIDE!
63 GMC 4X4 305 V6
Old 03-21-2023, 04:56 PM   #200
Matt's k5
BLAZER THIRTY!!
Matt's k5's Avatar
you are welcome to pm me as well , do you still take paypal? i have ordered from you before
71 K5 MAMMA'S RIDE!
63 GMC 4X4 305 V6
