Old 11-08-2010, 11:43 PM   #176
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: 3r!c84 build
Sounds really good man! Love the truck, ya drivin it yet?
John
1999 Toyota Tacoma 4x4
Old 11-09-2010, 12:00 AM   #177
3r!c84
Badass
3r!c84's Avatar
Re: 3r!c84 build
nope. its acting a little funny, timing still of alot. maybe tomorrow ill drive it up and down the road once
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 11-09-2010, 12:09 AM   #178
nbpro
Re: 3r!c84 build
Originally Posted by 3r!c84 View Post
hahahahaa!!!!! with or with out all the body parts on yours
i think i got you beat tho. no video but i got it on the converter and then it broke a tire lose. i got the almost 12inch wide make to prove
broke a tire lose so you did take it out of park huh?
nbpro is offline   Reply With Quote
Old 11-09-2010, 12:10 AM   #179
3r!c84
Badass
3r!c84's Avatar
Re: 3r!c84 build
well yea lol put it into the garage
-00 Saturn 5spd
1/4:13:90
Old 11-09-2010, 12:25 AM   #180
nbpro
Re: 3r!c84 build
are truck is out to where we're gonna paint it at
Old 11-09-2010, 11:19 PM   #181
3r!c84
Badass
3r!c84's Avatar
Re: 3r!c84 build
so after putting on the exhaust tonight its running worse. sounds stuffed up. realy under powerd. im still thinking its the timing is way off. or maybe i didnt find TDC correctly when i droped the dis in. also its droping alot of rpms and about dies when i put it in gear...
-00 Saturn 5spd
1/4:13:90
Old 11-10-2010, 12:13 AM   #182
nbpro
Re: 3r!c84 build
maybe this weekend you can reset the distributor and with a TDC Indicator and see if that helps. im assuming all of your vaccuum lines are in the right places also good luck
Old 11-10-2010, 12:23 AM   #183
3r!c84
Badass
3r!c84's Avatar
Re: 3r!c84 build
yea all in the right places. and what not being used is pluged so no vac leaks. must be my timing is way off. im going to pull the spark plugs and see how they look too.
the part where i shift it in gear and it drops alot of rpms is strange too
-00 Saturn 5spd
1/4:13:90
Old 11-10-2010, 12:34 AM   #184
nbpro
Re: 3r!c84 build
Some guys tell you that any big RPM drops from Park to Drive are caused only by incorrect ignition timing, while others say that it can also be due to the stall speed chosen being too low for the camshaft that's being used
In a street motor with a perf cam correct base timing (at least 16-18 deg with perf cam)/is vac adv being run /is vac adv hooked to ported or full intake vac all the time/what spring & weight setup is in mech adv/size of cam/carb idle mix adj/and stall speed all collectively play a role in how much rpm drop there is from park to drive.
But the better the above " adjustable items (carb idle mix/timing/mech adv/vac adv/etc) are dialed " in the less of an rpm drop from park to drive you should see .
Old 11-10-2010, 12:43 AM   #185
3r!c84
Badass
3r!c84's Avatar
Re: 3r!c84 build
sweet thanks for the info. where whe first had the timing it said it was at like 40. and it was running good,maybe i didnt have right tbc when i droped the dis in so it reads 40 when its realy at 20? idk just a guess. we had it set at 6 and it ran like ****
-00 Saturn 5spd
1/4:13:90
Old 11-10-2010, 12:57 AM   #186
nbpro
Re: 3r!c84 build
http://www.summitracing.com/parts/PR...5&autoview=sku
http://67-72chevytrucks.com/vboard/s...d.php?t=290498
Old 11-10-2010, 01:00 AM   #187
3r!c84
Badass
3r!c84's Avatar
Re: 3r!c84 build
yea i seen that a few times. call me slow and or cheap. i dont have a stop and i dont realy understand is methods
-00 Saturn 5spd
1/4:13:90
Old 11-10-2010, 01:09 AM   #188
nbpro
Re: 3r!c84 build
Advance Timing Light is a must tho how are you setting your time by ear or are you using a light your vacuum advance curve needs to be looked into as well. i was thinking the weights may be set diff on the 305 than it is for the 400. not sure
http://www.autozone.com/autozone/acc...ntifier=718069
Old 11-10-2010, 01:18 AM   #189
3r!c84
Badass
3r!c84's Avatar
Re: 3r!c84 build
Yea we where using a light like that. And this dis is not the one off the 305. It's just a stock msd streetfire right out of the box .
-00 Saturn 5spd
1/4:13:90
Old 11-10-2010, 01:20 AM   #190
nbpro
Re: 3r!c84 build
o i see advance curve set ?
Old 11-10-2010, 01:22 AM   #191
3r!c84
Badass
3r!c84's Avatar
Re: 3r!c84 build
I have no idea what that means..
-00 Saturn 5spd
1/4:13:90
Old 11-10-2010, 01:30 AM   #192
nbpro
Re: 3r!c84 build
http://www.msdignition.com/forum/showthread.php?t=1485
Old 11-10-2010, 10:05 PM   #193
3r!c84
Badass
3r!c84's Avatar
Re: 3r!c84 build
trying them tricks tomoorow.
-00 Saturn 5spd
1/4:13:90
Old 11-10-2010, 10:21 PM   #194
oldblue1968chevy
Re: 3r!c84 build
Yeah..the springs weights is awhole bag of worms..never really got it figured out myself..
John
Old 11-10-2010, 10:21 PM   #195
3r!c84
Badass
3r!c84's Avatar
Re: 3r!c84 build
hmmm might get somthing to park next to in the garage..
454/700r4/3:73posi
-00 Saturn 5spd
1/4:13:90
Old 11-10-2010, 11:15 PM   #196
muthstryker
muthstryker's Avatar
Re: 3r!c84 build
What kind of paint did you use for the motor? Having trouble finding something to use..
muthstryker is offline   Reply With Quote
Old 11-10-2010, 11:27 PM   #197
3r!c84
Badass
3r!c84's Avatar
Re: 3r!c84 build
i wouldnt recommend it tho. not glossy at all. and chips off wish i woulda known before i did the whole thing
-00 Saturn 5spd
1/4:13:90
Old 11-10-2010, 11:29 PM   #198
muthstryker
Re: 3r!c84 build
hmm, Ya I cant decide on mine there are alot of different brands out there. Thanks though..
Old 11-10-2010, 11:30 PM   #199
3r!c84
Badass
3r!c84's Avatar
Re: 3r!c84 build
i heard vht is good stuff. try them
-00 Saturn 5spd
1/4:13:90
Old 11-10-2010, 11:38 PM   #200
muthstryker
Re: 3r!c84 build
Ya thats on the top of my list, just trying to find more reviews on it. More then likely will end up using them.
