Old 04-25-2011, 10:42 AM   #176
FnLow69
FnLow69's Avatar
Re: [PROJECT] Laidout53 Part II
Thanks guys
FnLow69 is offline   Reply With Quote
Old 04-25-2011, 10:53 AM   #177
67cheby
67cheby
67cheby's Avatar
i think it looks just right considering how thick the body of the truck is...if that makes sense to you !!
67cheby is offline   Reply With Quote
Old 04-25-2011, 12:49 PM   #178
VA72C10
VA72C10
VA72C10's Avatar
do you have a shot from further back to look at the rest of the 53...as is looks good to me...but I might change my mind if I could see it from a few feet away to get perspective on it
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 04-25-2011, 10:25 PM   #179
FnLow69
FnLow69's Avatar
thanks i'll get better pictures later....
Old 04-25-2011, 10:43 PM   #180
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Looks good id also like to see it from farther back.. The windshield looks huge though..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 04-26-2011, 03:31 PM   #181
thor
thor's Avatar
Looks good to me. Then again, since I'm 6'3", I would shy away from chopping too much as I'd hate to scrunch into the truck, no matter how cool it looks. Of course, you could always chop the seats too. In all, I think it looks good and still leaves you some glass and room for your head without that hunchback look.
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
Old 05-10-2011, 09:39 AM   #182
Kinghat
Kinghat's Avatar
awesome
Hail to the King, baby.
Kinghat is offline   Reply With Quote
Old 05-11-2011, 12:16 AM   #183
FnLow69
FnLow69's Avatar
Thanks guys
Old 05-23-2011, 03:46 PM   #184
Kinghat
Kinghat's Avatar
need updates!
Old 05-26-2011, 02:04 AM   #185
FnLow69
FnLow69's Avatar
Haven't worked on it in a couple of weeks but hopefully this weekend i will get chance to!
Old 05-26-2011, 11:12 AM   #186
77shortstep
77shortstep's Avatar
wow, all i can say is wow. awesome job man wish i had half your talent.
77 CHEVY - SHORT BED STEP SIDE 2WD
02 CHEVY - EXT CAB SHORT BED Z71 7 INCHES OF LIFT
77shortstep is offline   Reply With Quote
Old 06-07-2011, 01:19 PM   #187
m6z
m6z's Avatar
Chop looks perfect.
Doug
Looking for a 67-72 short bed driver.....
m6z is offline   Reply With Quote
Old 07-10-2011, 09:07 PM   #188
FnLow69
FnLow69's Avatar
Well i got to work on the chop this weekend, got the rear window tacked back along with the inside supports. in and the cab corners fitted as well as got the passanger door top put back together, had to hand make the filler peices but in all it turned out to be a productive wekend.
Top split in half
Used screw jacks to support the top
Back window
Inside supports done (not pic of the other side)
Cab door jams filled
Cab corners
Door frame fillers
Whatcha think?
Justin
Old 07-10-2011, 09:28 PM   #189
FRENCHBLUE72
PROJECT 7DEUCE
Looks like you made large strides in getting closer to done.. That roof gap is pretty daunting looking..
MEMBER #6377
Project "7DEUCE"
Old 07-11-2011, 12:18 PM   #190
67cheby
67cheby
67cheby's Avatar
WOW...nice work as always !!
Old 07-11-2011, 02:29 PM   #191
thor
thor's Avatar
awesome work as usual! that's a big streeeeeetch on that roof, however your work on those patch panels is making it look easy. niiiiiice!
Old 07-11-2011, 10:57 PM   #192
noonzor
looks sweet man!
69 c10 Shortbox Build
http://67-72chevytrucks.com/vboard/s...d.php?t=360622
noonzor is offline   Reply With Quote
Old 07-12-2011, 01:20 AM   #193
FnLow69
FnLow69's Avatar
Thanks guys ya the gap in the roof is a little intimidating... but i got myself into it Lol
Old 08-01-2011, 12:41 AM   #194
rondog4416
rondog4416's Avatar
Looking good dude !!!!!!!!!!!!!!!!
rondog4416 is offline   Reply With Quote
Old 08-02-2011, 10:40 AM   #195
FnLow69
FnLow69's Avatar
Thanks Ron.... There be a update soon, been working on it.
Old 10-30-2011, 11:38 PM   #196
FnLow69
FnLow69's Avatar
OK, big update!
Im happy with the chop but i didnt like the front window. still looked to big and aslo wanted to take some of the crown out of the roof, so i lowered the frame work an 1/2". Then i removed the seems on the A pillers. Fixed the drivers side corner and door jam area. Recently bought a TIG welder so what better time to learn than now. then on to filling the gap between the roof sections, need to redo it cause i got to big of gaps but it will have good flow. Then i tried to fix more of the driver side roof but i decide to just make a new section.
Any ways heres the pictures!!
Before lowering the window opening
During
After
New corner and a pillers
Back cab wall welded and smoothed
Cab upper corner after my first atempt to fix it
New peice i made
And fitted
What do you all think
Justin
Old 10-30-2011, 11:51 PM   #197
VA72C10
VA72C10
VA72C10's Avatar
Much better! Like how it lines up with the side windows!
Old 10-31-2011, 01:04 AM   #198
rondog4416
rondog4416's Avatar
indeed it is looking good !!!! nice work !!!!
Old 10-31-2011, 01:35 AM   #199
FnLow69
FnLow69's Avatar
Thanks Va72c10 and Ron!
Forgot about these pictures. Heres two showing the roof curve (like i said im going to redo the filler peice)
Justin
Old 10-31-2011, 10:02 AM   #200
67cheby
67cheby
67cheby's Avatar
that last pic is the money shot...so many chops you see from that angle seem to dip in the middle! nicely done !!
