Old 06-23-2011, 07:02 AM   #176
73gmc454
73gmc454's Avatar
Re: 77 yellow gmc swb
Yep Budd its a 160mph speedo ! I like the knobs they go with the old school look I got goin on , the twist style would give a newer retro fit look , just not what I'm lookin for , heres my dash panel getting closer to done , got the top of the steering wheel cover welded on and the bottom all formed up,
my build 77 gmc shortbed big block, http://67-72chevytrucks.com/vboard/s...d.php?t=438237
73gmc454 is offline   Reply With Quote
Old 06-23-2011, 08:08 AM   #177
67_SS396
Everything looks really nice. I can't wait to see how the gauge cluster turns out.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers
'66 C10 - The new hot rod
'77 3+3 Dually - 12 valve 4wd conversion tow rig project
'28 Ford 2 door sedan street rod
RevLimit Offroad
"Hang on beer, we can do this."
67_SS396 is offline   Reply With Quote
Old 06-23-2011, 03:49 PM   #178
watahyahknow
watahyahknow's Avatar
nice job on the knobs , you could glue rubber O-rings in the grooves if they end up beeing too slick to pull with greasy hands
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 06-23-2011, 04:38 PM   #179
73gmc454
73gmc454's Avatar
Thanks guys , I have had some o rings on them once , it looked good ,anyway hopefully no greasy hand will be in this truck !
Old 06-23-2011, 08:43 PM   #180
73gmc454
73gmc454's Avatar
I got the steering wheel cover on the dash panel welded up , got it all screwed on, also drew some gauges on !
Old 06-23-2011, 09:51 PM   #181
MadManAndrew
Are those gauges digital? Can I get a link?
1955 Chevy 3600 http://67-72chevytrucks.com/vboard/s...61#post8589061
MadManAndrew is offline   Reply With Quote
Old 06-23-2011, 10:46 PM   #182
SledBurban
Read through the thread and the work you are doing is simply astounding. Very thoughtful well executed modifications all around. I am glad to see the rear bumper filler panel you made, I had thought of doing the same thing except using a roll pan and making clearances or pass through's for the bumper brackets.. It does really complete the rear of the truck and it was a factory component on my first ride a 89 s10 blazer. Awesome progress and great fab skills!
SledBurban is offline   Reply With Quote
Old 06-24-2011, 12:30 AM   #183
luifer76
luifer76's Avatar
Nice work man keep it up....
nOtHiNg LiKe ThE gOoD oLe ChEvYs....
luifer76 is offline   Reply With Quote
Old 06-25-2011, 08:29 PM   #184
73gmc454
73gmc454's Avatar
Thanks guys , I just tried to make a plan and stick with it , just wanted a simple clean build ! so the digital flush mount gauges werent workin so I cut all the holes in for the autometers , also cut the hole for the heater, air ride switches and cut a notch in for the air gauge , put it all together to see how it looked , now I see I need to remove more of the dash support tomorrow ,
Old 06-25-2011, 08:41 PM   #185
BIGBERTHA
Very nice, love it. Keep up the good work
Marshall
1976 Chevrolet K10 4wd
2006 Chevrolet Impala (wife)
IF IT JAMS FORCE IT!! IF IT BREAKS, IT NEEDED TO BE REPLACED ANYWAY!!
BIGBERTHA is offline   Reply With Quote
Old 06-27-2011, 12:28 AM   #186
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
wow very good work!
John
1999 Toyota Tacoma 4x4
Old 06-27-2011, 01:07 AM   #187
bbbc10
Diggin The SquareLife
i would like to have some of them knobs for my truck! looks good
bbbc10 is offline   Reply With Quote
Old 06-27-2011, 09:27 PM   #188
73gmc454
73gmc454's Avatar
Thanks , next up was to make a shift indicator switch ?? something else I have to do to get the dash panel done , goin to take a hunk of plastic and rivet a wire to the back side at all 6 shift points ,add a bracket I can weld to the shift lever with a hunk of copper to use as a contact thats grounded,run eash of the 6 riveted wired to the 6 lights on the dash ,so tonight I made some brackets and mounted with the pan bolts and use some plastic and duct tape to moch it up, I think I may even work ! heres a pic taken at the trans shift point to help understand
Old 06-28-2011, 07:45 AM   #189
watahyahknow
maibe you can use a stepperswitch instead , seen someone use that a while back with a 7 segment led it showed P n R D 1 2 3
Old 06-28-2011, 08:58 PM   #190
73gmc454
73gmc454's Avatar
Yep I coulda used 1 of them maybe but I made this 1 today and added a bracket to the shift lever with a brass tab , hope to get it wired up to the dash tomorrow ,
Old 06-29-2011, 10:12 PM   #191
73gmc454
73gmc454's Avatar
Ok got the switch all hooked up, it even works! here a short video
Old 06-30-2011, 02:30 AM   #192
kikkegek
kikkegek's Avatar
very cool!
kikkegek is offline   Reply With Quote
Old 07-03-2011, 12:27 AM   #193
Gordonr1973
Home Built '87
Gordonr1973's Avatar
I can't believe you just fabbed that up out of nothing!!! That's awesome!!
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 07-04-2011, 08:51 AM   #194
73gmc454
73gmc454's Avatar
Thanks , I just knew just what I needed and just tried it , it went way easier than I woulda thought ,
Got the dash panel just about done, after a couple trys I finally got the headlight switch hole in the right place the wiper slot fit the first time! just need to weld in the area where the air gauge will go and tune it up for paint,
Old 07-04-2011, 10:54 AM   #195
J Knight
J Knight's Avatar
Necessity (or a hot rodders wants) is the mother of invention!
Awesome fab job on all of it!
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 07-04-2011, 12:25 PM   #196
BuddR
Yo the mannn
BuddR is offline   Reply With Quote
Old 07-10-2011, 06:44 PM   #197
73gmc454
73gmc454's Avatar
got the air gauge area tuned up on the panel and was able to get everything sanded down and put a couple coats of primer on ,
Old 07-10-2011, 11:49 PM   #198
luifer76
luifer76's Avatar
looking good 73.....
Old 07-11-2011, 04:49 AM   #199
kikkegek
kikkegek's Avatar
wow! that is realy looking very nice!
Old 07-11-2011, 09:15 PM   #200
73gmc454
73gmc454's Avatar
Thanks guys, tonight I was able to do some more sanding and aslo got the mounts for the heater switches drilled and tapped hope top get the holes drilled for all the led lights tomorrow anda bit more sanding ,then it will be ready for paint finally !
