Old 03-30-2011, 09:29 AM   #176
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Originally Posted by blitz'd View Post
You needed drop spindles? You dont really need the upper arms, these frames do not really camber that much. I know mine is maxing out the upper ball joint though so I either need to get different arms or longer travel ball joints. I like the MMW arms, looks like I would get a lot more clearance for the inner fenders if I ran them.
For how much they cost I figured the extra 2" would'nt hurt. Got them on ebay for 150.shipped
daverod is offline   Reply With Quote
Old 03-30-2011, 10:22 AM   #177
MrDude_1
Re: Daverods 52
Originally Posted by daverod View Post
I think it has a bigger ring gear. It's made for off road. You would think it would be stronger? Not really sure what the ring gear does? I just like it because it's wide enough and it has disk brakes. No, I'm no staying out of the throttle.
There isnt really any 10-bolt rear I would call strong.
That said, if you're running normal street tires and messing around like a normal driver, i wouldnt worry about it.
If you're going to take it down the dragstrip on a regular basis, or if you're planning on putting drag radials or slicks on it... then Id start to worry about it.
otherwise... its fine. you'll burn up your street tires in a cloud of smoke before it breaks.
MrDude_1 is offline   Reply With Quote
Old 03-30-2011, 10:43 AM   #178
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Great thats all I want a big cloud of smoke. Hell, my frame will be on the ground anyway. It's not as if I'll be going anywhere.
Old 03-30-2011, 11:12 AM   #179
MrDude_1
Re: Daverods 52
Unless you setup your air suspension and driveline angle for it, you probably dont want to try to do burnouts with the bags fully deflated.
Old 03-30-2011, 08:51 PM   #180
Strodder
Daring to be Different
Strodder's Avatar
Re: Daverods 52
Your right Dude. A parallel 4 link would help minimise the pinion angle. But Dave doesn't care. He likes to burn up money anyway.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 03-30-2011, 11:59 PM   #181
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Good point. I might have tried it. Now I'll think twice about it.
Old 03-31-2011, 09:38 AM   #182
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Re: Daverods 52
Just get a double u joint for 12* of change. Then let it rock and roll.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 03-31-2011, 06:53 PM   #183
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Got my rear air kit for 125 off.
Saving $$ not it. Strodder
What you doing for bags/cups in the front Paul.
Old 04-01-2011, 01:52 PM   #184
ruffrida2005
Re: Daverods 52
I bought some off a guy local. He said they are SD cups. And I got a set of DOM II's 2500 i'm gonna use. Most people say you dont get the lift that you big lift, but I'll just have to see.
They have them on sell right now for $185. cups, 2500 DOMII, line and some fittings.
I was talking to Jason (SD) the other day, and he said that he doesn't like the bags on the outside of the frame like that. He said that they will twist, so just watch it. I'm still not sure how I'm gonna run mine. I may go bag behind the axle!
Paul
Old 04-01-2011, 02:23 PM   #185
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
20 minutes digging in the dirt at the junk yard and look what I found.
Old 04-01-2011, 02:25 PM   #186
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Thats the way they are on the kit they sell for the c66.
Old 04-01-2011, 10:35 PM   #187
ruffrida2005
Re: Daverods 52
Here is your kit installed on a truck so you know how it looks.
This is what I use for my background so I know what it looks like!
Paul
Old 04-01-2011, 10:37 PM   #188
ruffrida2005
Re: Daverods 52
You have to remember on the C10's the bars can be ran on the outside of the frame. On the S10 they cant. So you will get a little bit of twisting!
Paul
Old 04-01-2011, 11:53 PM   #189
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
My first powder coat job. Should have maybe put it on a little thicker. Next time.
Old 04-02-2011, 12:01 AM   #190
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
What kinda pain meds did the doc give u Paul. I'm not sure but it looks like they go on the outside? Could be wrong? Guess I'll find out. If it was on the inside would'nt it hit the gas tank?
Old 04-02-2011, 09:28 AM   #191
GRIMSS
GRIMSS's Avatar
Re: Daverods 52
I think the twist he is talking about is on the link bushings because the bag mounts are not centered over the bar. With them hangin on the side of the link bar it puts a twist on the bushings and may wear out faster.
2001 GMC SIERRA
1956 Chevy Panel Build Page with a Scott's Hotrods IFS
1953 Chevy trucks Project Dime Time
1968 Camaro
1968 Volksrod "NOBACK"
55-59 one piece window Video
55-59 one piece window template files
Jared
GRIMSS is offline   Reply With Quote
Old 04-02-2011, 10:26 AM   #192
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Is the twist coming from the truck going up and down or from the engine? I really don't see it. It's bolted to the axle on one end. ??? Most your shocks are mounted that way.
Old 04-02-2011, 05:32 PM   #193
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Sold my old frame for 150. Parts for parts. Still have the old transmission. Don't think I'll get rid of it very easy.
Old 04-02-2011, 05:34 PM   #194
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Sale!!!! I did just 150 in my pocket.. Trans 35 anyone anyone....Paul, I know you need a trans.
Old 04-02-2011, 07:39 PM   #195
Strodder
Strodder's Avatar
Re: Daverods 52
Shocks aren't load baring. With urethane bushings the arms should be OK. Not the best setup, but is very popular.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 04-02-2011, 09:46 PM   #196
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Makes me feel better. I was'nt looking for the best anyway. More like fast,easy and cheap. I know.
Old 04-03-2011, 09:31 PM   #197
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Wire whipped my frame painted it . Sand blasted my lower arms pressed some new ball joints in and painted them. Ordered some bags for the front and some cups. Rented the press for Auto zone pressed them myself. Did'nt know they rented the press.
Old 04-04-2011, 10:45 PM   #198
ruffrida2005
Re: Daverods 52
The twist that I'm talking about is going to be at the bushings. Because the bags are offset on the bar. You know the bars will mount under the frame with the bags on the outside. So that will give you a little bit of twist.
No I dont need a trans. Just so you know you will have to cut the spring pockets in the front for the bags to sit in and not rub. Once you get your cups and bags check it out.
Paul
Old 04-04-2011, 11:00 PM   #199
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
The cups weld in? I was kinda wondering how that worked. Does this mean I'll have to repaint?Guess I better get some metal.
Old 04-05-2011, 09:48 AM   #200
ruffrida2005
Re: Daverods 52
You can buy weld in cups. or you can get bolt in like I have. Most people use the bolt in, no holes to drill, they go in the factory holes for the shocks.
Paul
