Old 08-16-2011, 08:58 AM   #176
Russell Ashley
Russell Ashley's Avatar
Re: slamburban
You've done some nice work on this truck. It's looking good. The checker board is way cool, too bad the driveshaft doesn't show. We folks here on the forum and a few others might be the only ones who get to see it and that blue frame.
That's a good looking 66 in the background, yours?
Russell Ashley is offline   Reply With Quote
Old 08-16-2011, 10:00 PM   #177
Rude Dude
Rude Dude's Avatar
Re: slamburban
What kind of wheels are you running? Beautiful Burb!
Rude Dude is offline   Reply With Quote
Old 08-16-2011, 10:55 PM   #178
tantrumpipeline
Master Procrastinator
tantrumpipeline's Avatar
Re: slamburban
WOW!!!!! Looks sweet!!!
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506
20 Duramax tow pig
68 2wd short stepper project
77 2wd short fleet beater
52 short project
tantrumpipeline is offline   Reply With Quote
Old 08-17-2011, 01:41 AM   #179
fredscarryall
fredscarryall's Avatar
Re: slamburban
the 66 chevy in the back ground is a customers car. its a all original and even has the factory paint.but someone did a bad lowering job and it needs some suspension work.the rims on the burb are a 15 inch stock steel wheel powdercoated blue off a 66 ford falcon. the wheels are pretty hard to find because they accept the larger 10 inch center cap. i had to do the 5 on 4.5 ford conversion because the hubs where to small in the irs to convert to a chevy bolt pattern.i have stainless center caps and hot rod rings. but i'm not sure if i want to put them on.
fredscarryall is offline   Reply With Quote
Old 08-19-2011, 05:07 PM   #180
1lo67
1lo67's Avatar
Re: slamburban
The Suburban is lookin Sick..
1lo67 is offline   Reply With Quote
Old 08-21-2011, 10:45 PM   #181
fredscarryall
Re: slamburban
finish fixing the fulton visor.man it was hammered.it took about 5 hours and $15 in stainless nut,bolt and screws.
Old 08-21-2011, 11:43 PM   #182
VA72C10
VA72C10
VA72C10's Avatar
Re: slamburban
Definitely looks worth the effort!!!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 10-07-2011, 10:19 PM   #183
fredscarryall
Re: slamburban
got it back from the electricial shop today.finally got the autometer gauges back in after taking a tablespoon of sand out of each one.word to the wise never sandblast the inside of your truck with the gauges in.no matter how much you tape them up, sand always finds a way in.started fab on the the rear bumper brackets and a skid plate for the underside because i dont want the oil pan to be the lowest point on the frame.
Old 10-13-2011, 09:36 PM   #184
fredscarryall
Re: slamburban
installed the fiberglass rear filler panel and bumper. had to use rear truck brackets and straighten then out a bit because of the custom back half of the frame,but they worked really good. also installed some mirrors i got off of ebay.
Old 10-14-2011, 12:14 AM   #185
Ratpin
Ratpin's Avatar
Re: slamburban
What autometer gauge set are you running there? Do you have a better pic? (straight on)
Ratpin is offline   Reply With Quote
Old 10-14-2011, 01:36 AM   #186
fredscarryall
Re: slamburban
the guages are autometer 1204 designer black II series.i got them from chevs of the 40s. they are pretty expensive at $650 for both, but they come with everything you need.the only thing is, they are 5 inch guages and i think the opening in the factory dash are 5 1/4 or 5 1/2 inches. so i had to buy 2 factory chrome guage bezels at $15 each to put in the holes, then the guages went right in.
Old 10-14-2011, 01:41 AM   #187
Ratpin
Ratpin's Avatar
Re: slamburban
Thanks! I sure wish autometer made the old tyme street rod ones in black. Those look pretty good tho, just a little too modern for my build.
Old 10-14-2011, 08:39 PM   #188
fredscarryall
Re: slamburban
installed fulton visor
Old 10-14-2011, 08:41 PM   #189
VA72C10
VA72C10
VA72C10's Avatar
Re: slamburban
Love that visor. I think they MAKE these trucks
Old 01-04-2012, 11:04 PM   #190
fredscarryall
Re: slamburban
1950foru yes i had to raise the top hats on the mustang II rack.i bought the tires at walmart. they are goodyear viva 2. fronts are 205 70 15 (26.3 tall). rears are 215 70 15 (27 tall). then i took them over to hurst tires in oregon city, oregon and had the whitewalls vulnanized on.
Old 01-04-2012, 11:31 PM   #191
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Re: slamburban
burbs lookin good.who did you get the rear filler panel from and how much?
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 01-05-2012, 03:10 AM   #192
fredscarryall
Re: slamburban
chizzler, the rear splash guard is fiberglass with 4 fiberglass bracket. i bought it off ebay about two years ago for $100. he no longer sells on ebay and i cant remember the name of the company that sell them.the only reproduction that are availiable are fiberglass. i will look through my paper work tomorrow to see if i can find the receipt and get back to you. my buddy has three original ones.i will see if i can get one from him.
Old 01-05-2012, 11:26 AM   #193
CHIZZLER
CHIZZLER's Avatar
Re: slamburban
jeff wont take them off those burbs.fiberglass will have to do.thanks
61-crew cab D-max
Old 01-05-2012, 11:18 PM   #194
fredscarryall
Re: slamburban
chizzler, looks like jim carter sells them for $92.00 part number sm180.there number is 1-800-336-1913. i just ordered all the inside interior panels for my suburban and am very happy with them.there website doesnt work very well for online ordering.so give them a call when you order one.
Old 01-06-2012, 01:45 AM   #195
CHIZZLER
CHIZZLER's Avatar
Re: slamburban
thanks.i will check it out.
61-crew cab D-max
Old 01-06-2012, 11:59 PM   #196
fredscarryall
Re: slamburban
let me know if jim carter still sell the rear valance. if not i can ask the guy that makes them. he sells them for a bit little more money. but they are just as nice. the only thing is. they do come with bracket just like the original, but are they are made of fiberglass also. the valance isnt drlled for them. but i didnt use the brackets anyway.i really like the smooth look. so i just screwed it into the body with self tapping screws.
Old 01-15-2012, 03:04 AM   #197
fredscarryall
Re: slamburban
i finally took the maiden voyage in suburban. i took my wife and son for about a 2 hour drive around town and it ran perfect. the only problem i had so far is one of my headlights went out, but the halo lights worked fine.
Old 01-15-2012, 03:30 AM   #198
parkwood
parkwood's Avatar
Re: slamburban
Isn't that a great feeling driving it for the first time... all those long hours and hard work seems to fade away after a few miles...
good job...
parkwood is offline   Reply With Quote
Old 01-15-2012, 10:59 AM   #199
oldman3
oldman3's Avatar
Re: slamburban
good job...
I agree, the first ten to fifteen minutes you keep listening for something to go wrong. Then you settle in for lots of smiletime....Jim
oldman3 is offline   Reply With Quote
Old 01-15-2012, 11:01 AM   #200
99 to Life
99 to Life's Avatar
Re: slamburban
siiiiiccckkkk congrats. Can't wait to see some more photos and perhaps some footage would be supreme. Drive day is the most exciting.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
