Old 10-05-2012, 09:19 AM   #176
Portmod7
Portmod7's Avatar
Re: 72 k20 project
Originally Posted by ryanroo View Post
So, to celebrate my 28th trip around the sun i drove north on maybe the most beautiful day of the year for seeing the aspen and scrub oak in their fall colors and of course snag some truck parts
this is the area i drove through, not my pic just a random from google
Awesome! I'm hopefully headed up that direction tomorrow. Gonna load the wife up in the Jeep and hit the trails! Beautiful this time of year. And coincidentally, for the same occasion as you....
What junk yard do you go to for truck parts? I would kill to find some bumpers for my project. The back one is a little tough, doesn't seem to be much stepside stuff hanging around.
Anyway, keep up the nice progress!
Super Blue - 1968 C-10 Short Stepside
Fastburn 385, 4-Speed Sag. on the Column, Coleman 9" Floater w/Detroit TrueTrac
Portmod7 is offline   Reply With Quote
Old 10-05-2012, 10:52 AM   #177
ryanroo
ryanroo's Avatar
Re: 72 k20 project
i use a-1 and hwy 64 in kirtland for most of my random parts. for the 67-72 stuff i just look on CL. i havent really looked for any of these old trucks at the scrap yards. around here they seem only to have the newer stuff.
Happy birthday! if you find yourself in the Bayfield area and want to stop for a little truck talk ill be around most all day.
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 10-05-2012, 11:06 AM   #178
Portmod7
Portmod7's Avatar
Re: 72 k20 project
Thanks, happy birthday to you too!
I haven't really ventured into the scrap yards for that reason, didn't really see them having too much stuff for our trucks. Good to know I'm not missing much, ha ha.
I'll have to come up and see you sometime. Bayfield is an easy trip any day.
Porter
Old 10-06-2012, 11:01 PM   #179
ryanroo
ryanroo's Avatar
Re: 72 k20 project
I spent some time plumbing a little air line and installing a regulator. i wanted regulated air for my die grinders and the DA sander for paint stripping. and eventually a paint gun. hopefully i can pick up a drier before i get there though. this is the result
then i cut the hole for the B&W in the bed. and immediately used my die grinder to clean up the edge!
72 K20 12v build
Old 10-08-2012, 10:15 PM   #180
ryanroo
ryanroo's Avatar
Re: 72 k20 project
i got the hubs turned down to fit it the rotor hat. its a close fit, just tight enough that it will go on easily but tight enough to keep the rotor pretty much centered.
tomorrow i hope to waterjet the test backing plate so i can start designing the final version.
Ryan
72 K20 12v build
Old 10-10-2012, 10:54 PM   #181
ryanroo
ryanroo's Avatar
Re: 72 k20 project
i water jetted the spacer plate and then machined it down to the proper thickness. i think i can just ditch the dust shield and run .500 in the final version.
i hung all the stuff off the spindle. ill finish designing sometime soon hopefully.
72 K20 12v build
Old 10-13-2012, 10:14 PM   #182
ryanroo
ryanroo's Avatar
Re: 72 k20 project
the next version behind the spindle plate.
and proof of concept. i will run this on my truck, but if for some reason i feel boredom creeping up sometime down the road i will slightly modify the bracketry. there are a few spots where i had to grind for clearance that i can modify in the drawing. i could also swing the abutment slightly to perfect the caliper position on the rotor, but it is well within functioning.
i pretty much owe my design idea to mcmlxix.
i will finish the welding on this one and do the other side tomorrow.
ryan
72 K20 12v build
Old 10-14-2012, 09:31 PM   #183
ryanroo
ryanroo's Avatar
Re: 72 k20 project
both sides are done. i tweaked the bracket to allow the caliper to sit where it should. all i need to do now is get some wheel studs. and press them in.
Ryan
72 K20 12v build
Old 10-14-2012, 09:46 PM   #184
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: 72 k20 project
Nice! Will you fab some disc brakes for my Eaton HO52 ...
Old 10-14-2012, 10:55 PM   #185
ryanroo
ryanroo's Avatar
Re: 72 k20 project
rears are easy! unless you are wanting some fancy parking brake in hat new type thing. then i would have to look it over more. it took me maybe an afternoon to do the ones for my jeep. 14 bolt, but the concept is the same no matter the axle.
hows yours coming along?
Ryan
72 K20 12v build
Old 10-14-2012, 11:31 PM   #186
mosesburb
I had a V-8
mosesburb's Avatar
Re: 72 k20 project
You have some nice pics of the front brakes, but I didn't see where you said what you did and why??
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE.
mosesburb is offline   Reply With Quote
Old 10-14-2012, 11:40 PM   #187
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Why? well because i am a masochist.
they are brakes from a 2003-08 dodge 2500. the rotors are bigger and the calipers are mo betta. i really hate ****ty brakes. the 1978 technology seemed a little underwhelming with the 1300#s of cummins and 47rh. i had this notion a while back and mcmlxix started doing it for his blazer and i was hooked. unfortunately i jumped in not realizing and not doing the research to find out that the 03-08 stuff was different than the 09-up. they have a symetrical mounting apparatus and these do not. so i had a little more head bashing to do. not to mention ford axles have the spindle outside of the brake bracketry. that actually helped with rotor clearance. it hurt with knuckle clearance.
the obvious advantage is the size. it also allows for a slip on rotor, which is handy. also if i fall into a pile of money i can upgrade to EBC rotors and yellowstuff pads. disadvantage is the size. i have to have 17" wheel. i had planned on 18"s so no biggy there.
72 K20 12v build
Old 10-15-2012, 09:32 AM   #188
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: 72 k20 project
Ryan
Just kidding around but I wish I had those skills/tools. The drums on my Eaton seem in good shape. The build is coming along slow but that's ok. Trying to decide single stage vs. base/clear. Will likely go single stage.
Old 10-18-2012, 07:27 PM   #189
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 72 k20 project
Nice work on your brakes! I hope you don't put ethnic wheels on your ride.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 10-18-2012, 09:24 PM   #190
ryanroo
ryanroo's Avatar
Re: 72 k20 project
no ethnics but i am planning on 18" wheels. trying to keep the sidewall towing friendly and the handling as nice a s possible.
i sheared this out and formed it tonight. hopefully get it welded up this weekend
ryan
72 K20 12v build
Old 10-18-2012, 09:57 PM   #191
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Re: 72 k20 project
Ethnic wheels eh, lol I like that. Ive always called them something along those lines... haha
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 10-18-2012, 10:05 PM   #192
Dieselwrencher
Re: 72 k20 project
Yep, presidential correct. I mean............... I had 325/85/18's on my 05 F-350 and it hauled like a dream with them. Did big smokey burn outs too. Hehe
Ryan
Old 10-20-2012, 12:13 AM   #193
mosesburb
I had a V-8
mosesburb's Avatar
Re: 72 k20 project
Ah, makes sense. I never had a problem with inadequate brakes on a K30, but when it comes to brakes, bigger is ALWAYS better. If you are towing around your neighborhood, there is no such thing as too much brake.
Old 10-20-2012, 09:42 AM   #194
ryanroo
ryanroo's Avatar
Re: 72 k20 project
that was my sentament as well. ive been over red mountain and wolf creek enough times to realize that i pretty much always get the bad weather. i make sure the trailer brakes are top notch and figured with this truck i may as well have 21st century technology. plus i have problems letting go of an idea if i haven't at least tried to make it work.
i am thinking about this swap for my jeep. it has a GM 60 and 40" tires and it still stops really well with the stock GM front brakes and the K20 rear disk swap. it is also lighter though so that helps
72 K20 12v build
Old 10-20-2012, 06:17 PM   #195
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Got a little done to the fuel tank. hopefully tomorrow i can borrow my friends TIG so i can glue the draw tube and return tube into the JIC fittings. the fittings are just steel hydralic pipe to JIC adapters and the tube is 1/2" and 3/8" .035 wall SS tube. i will add a drain in the bottom and baffle it after i get the tubes situated.
i picked up a few wheel studs too so i can try to get them pushed into the hubs and make sure they will fit. same knurl diameter as the ford hub and the same thread as the dodge rear.
Ryan
72 K20 12v build
Old 10-20-2012, 10:58 PM   #196
tsnow678
Re: 72 k20 project
You are a hell of a fabricator! Looks great from what I see!
Link to my 69 Camaro 6.0/T56 swap:
http://ls1tech.com/forums/conversion...69-camaro.html
tsnow678 is offline   Reply With Quote
Old 10-20-2012, 11:01 PM   #197
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Thanks!
i got bored and decided a test fit was in order. it will look a lot better in satin black.
any good coating recommendations for the inside? is there a type of paint that is petrol-proof after it cures?
it will be ~ 34 gallons. hopefully that will make it about 30 gallons usable maybe a little more. should be good for a 550ish mile range.
Ryan
72 K20 12v build
Old 10-21-2012, 05:05 PM   #198
jhiggy94
Re: 72 k20 project
I did the math and your figuring 18 mpgs!? maybe i lost it at one point in the thread but what engine are you planning on running to get that kind of mileage?
jhiggy94 is offline   Reply With Quote
Old 10-21-2012, 06:56 PM   #199
ryanroo
ryanroo's Avatar
Re: 72 k20 project
its a 12v cummins. rear gear is 3.54:1. tires are going to bee 33s. 18 mpg shouldn't be hard to do. i actually hope to break 20. not banking on that though.
more tank work
wife got me in progress
72 K20 12v build
Old 10-21-2012, 07:05 PM   #200
GMCJOE
GMCJOE's Avatar
Re: 72 k20 project
How much you charge to build a fuel tank like that?...lol I am not sure if I am joking or not, but I am sure the killer would be shipping on something like that..lol Looks awesome.
Joseph
Joe's 69 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=543253
1969 GMC SWB-350 SBC 700R4
2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust
GMCJOE is offline   Reply With Quote
