Old 05-13-2013, 08:50 AM   #176
rs74
rs74's Avatar
Re: My new project 86 Silverado
I would consider doing the body work myself but I just don't have the time for it right now. Oh well it is what it is. Are you getting anywhere with yours?
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 05-13-2013, 08:56 AM   #177
naphtali5725
naphtali5725's Avatar
oh yeah, just got a shipment of a gallon of epoxy primer, and a gallon of 2K primer. Hood/fenders done in epoxy. bottom of cab epoxied, working on sanding the upper parts/sides of the cab so I can epoxy. then i'll move to the doors which I have to take apart. they are electric locks/windows, all rusted to hell, going to be a pain, they need all new weatherstripping/soft parts.
hoping to get my Mcgaughy's drop spindles today
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
naphtali5725 is offline   Reply With Quote
Old 05-14-2013, 11:06 AM   #178
naphtali5725
ordered my wheels today...
http://www.summitracing.com/parts/wv...2/media/images
http://www.summitracing.com/parts/wv...4/media/images
My build thread...
Disabled Veteran
Old 05-14-2013, 11:17 AM   #179
77ChevySharkBite
77ChevySharkBite's Avatar
Nice!! Got to love the stock rallies!!
Korwin
77 C10 Silverado Sharkbite LWB Build
67 Chevy C10 Frame Off
06 Dodge Magnum 2.7v6 aka swag wag!
2010 Honda Accord 2.4I4 DD aka Liquid Metal
77ChevySharkBite is offline   Reply With Quote
Old 05-14-2013, 12:06 PM   #180
naphtali5725
thanks, I'll have to wait on the caps and trim rings for a bit
My build thread...
Disabled Veteran
Old 05-14-2013, 12:12 PM   #181
77ChevySharkBite
I knew that was my question I was going to ask you, had a brain fart can't wait to see them on the truck man there going to look sharp!
You get the spindles yesterday?
Korwin
Old 05-14-2013, 12:18 PM   #182
naphtali5725
hell no grrrr! grunion took 5 days just to process my damn order.... will be here in 4 days....sucks but the wheels should get here at same time
My build thread...
Disabled Veteran
Old 05-14-2013, 12:46 PM   #183
77ChevySharkBite
Yeah i'd be pretty upset myself but I'll have my fingers crossed everything will get there all at the same time!
Truck is looking good man, keep the work up!
Korwin
Old 05-14-2013, 09:54 PM   #184
rs74
rs74's Avatar
Are you running a flip kit? I was thinking that you were not. I will be ordering the 5"bs for the rear due to the flip kit.
Roy
1987 R10 shortie
Old 05-14-2013, 09:57 PM   #185
naphtali5725
yeah, i'm going to flip... why the extra 1/2 inch bs for the flip on your's?
My build thread...
Disabled Veteran
Old 05-14-2013, 10:18 PM   #186
rs74
rs74's Avatar
I started a thread about this somewhere on here and I was thinking that was what I was told. I am going to be running 295/50/15's in the rear. Maybe the extra was for that wide of a tire.
Roy
1987 R10 shortie
Old 05-14-2013, 10:27 PM   #187
naphtali5725
I'll prolly be running the same... hopefully they wont rub the rear fender...
My build thread...
Disabled Veteran
Old 05-15-2013, 08:07 AM   #188
naphtali5725
Since i'm putting 2.5 inch drop spindles up front, trying to figure out what is best kind of shock I should use, what do you guys recommend?
I'm doing a flip in the back too, so i'd like to use same brand shocks front/back...
using Mcgaughy's spindles/flip kit. Their shocks are like 50 bucks a piece...
thanks
My build thread...
Disabled Veteran
Old 05-15-2013, 08:40 AM   #189
rs74
rs74's Avatar
I still need to buy my shock extenders for mine. I am going to try to run the stock shocks. I am going to look into Bilsteins first. The only thing I am not sure about is if I can run stock shocks up front with the 2.5" spindles and 1.5 springs. I have read that I should be able to though. I would be interested in know about this question too. You might have to start a seperate post on the message board.
Roy
1987 R10 shortie
Old 05-15-2013, 12:48 PM   #190
77ChevySharkBite
thanks
I'm running Gabriel shocks on mine, and though I haven't really driven it a lot it's definitely an improved ride that's for sure. I would have to say though Bilsteins shocks are pretty awesome and a great shock to use! I wouldn't run drop shocks though as i've heard there crap. KYB is another brand but your going to pay quite a pretty penny or 2 for them.
You should be able to run your stock or any aftermarket shock aside from drop shocks, because even though your dropping the truck, and putting springs that shock will have to meet up with the spring so I personally don't see where there would be an issue with it.
Korwin
Old 05-15-2013, 01:28 PM   #191
naphtali5725
prepped the cab for epoxy primer, I hope to get it sprayed this afternoon...washed with tide and a red scrub pad inside and out, then 180 grit wet. got out the big hair dryer and got it dry Man i'm tired...
My build thread...
Disabled Veteran
Old 05-15-2013, 01:30 PM   #192
naphtali5725
after dry...
My build thread...
Disabled Veteran
Old 05-15-2013, 06:24 PM   #193
naphtali5725
too much wind, pollen pods, and Maple seeds a flyin around to spray today...
going to make a bootleg spray booth that is 12x12 ft by 8ft tall out of PVC pipe and fittings.
going to put the cab up on cinder clocks and 4x4's to get it up off the ground, with a sheet of plastic on the ground underneath it so I don't get dust and crap off the ground when I spray... should be interesting... updates soon
My build thread...
Disabled Veteran
Old 05-15-2013, 08:01 PM   #194
naphtali5725
several (16 so far) pieces of 1 inch PVC x 10 feet long
2 2x4's
4 cinder blocks
various T's and side outlet fittings
clear 4 mil plastic sheeting
will probably make it 16x16 feet... needs more room around the sides...
should have it complete in the morning...
My build thread...
Disabled Veteran
Old 05-15-2013, 09:34 PM   #195
CuRtdOgG
CuRtdOgG's Avatar
Truck looks good man. I'm using stock shocks front and back and they work fine
CuRtdOgG is offline   Reply With Quote
Old 05-16-2013, 09:44 AM   #196
naphtali5725
ordered lines from inline tube today...
spoke to Chuck was a cool guy, made order...
http://inlinetube.com/Preformed%20Li.../CT-CAT-11.htm
sctb8102 - stainless kit - 195.00
ct1004 - braided steel lines - 105.00
ctt8102 - stainless trans lines - 75.00
shipping 20.41 fedex ground
total + shipping = 395.41
My build thread...
Disabled Veteran
Old 05-16-2013, 09:47 AM   #197
naphtali5725
ordered my brake kit, and flip kit today from Summit, searched all over, was cheapest at Summit because of how cheap their shipping is...
Mcgaughy's front brake kit part # MMC-63156
http://www.summitracing.com/parts/mmc-63156
Western Chassis flip kit part # WST-2104
http://www.summitracing.com/parts/wst-2104
slowly getting there...
My build thread...
Disabled Veteran
Old 05-16-2013, 01:06 PM   #198
naphtali5725
Summit came, got wheels... I know they look crooked... it's the camera angle
got spray booth frame up...
My build thread...
Disabled Veteran
Old 05-16-2013, 01:23 PM   #199
trout
thanks
I have 3 in Spindels and brand new factor coils with one cut coil and a flip in rear and new stock shocks and air shocks on the rear and rides great and pulls wat i need it to
Edited by staff
trout is offline   Reply With Quote
Old 05-16-2013, 02:04 PM   #200
naphtali5725
I taped all the connections of the pipe with 100mph tape...
need a top cross bar, so i'll do that tomorrow because of the impending rain, had to just cover the cab with plastic sheet and wait...
thinking of what tires to go with now for my new rims
tracking says my front spindles will be here tomorow, so I can get them on, and all the front rod ends, all that stuff...
slowly but surely...
My build thread...
Disabled Veteran
