Old 04-05-2015, 03:35 PM   #176
vannatta20
vannatta20's Avatar
Re: 1968 C10 5.3 swap, the easy way.
Next I need to install my LS2 intake but need to save up a bit more money to change the waterpump and fuels rails.
vannatta20 is offline   Reply With Quote
Old 04-06-2015, 10:06 AM   #177
bodydropped68
bodydropped68's Avatar
Originally Posted by vannatta20 View Post
Yes I used a stock truck oil pan with all truck accessory's. It will hang down below the crossmember about an 1-2 inches. No issues since my truck only has been lowered 3 inches.
I did a bunch of changes of this last month. Sold the 6.0 and got a L33 5.3 engine for cheap (all aluminum block).. Had the heads milled .036 for high 10's compression. Installed a free lq9 cam. My 4l60e went bad and had that rebuilt. I also custom made a complete engine harness from scratch since I now build and sell them. I kept the DBW setup but re wired it to work with a 90mm LS2 throttle body. Im hoping to get decent economy out of this setup. Hoping for high teens in the gas mileage with 300hp to the wheels. I also installed headers finally.
Attachment 1387020
Attachment 1387021
Attachment 1387022
Attachment 1387023
Nice
bodydropped68 is offline   Reply With Quote
Old 04-06-2015, 11:01 PM   #178
vannatta20
vannatta20's Avatar
How do I get the link as a thumbnail?
https://youtu.be/KNK3atXuxcU
Old 04-06-2015, 11:08 PM   #179
vannatta20
vannatta20's Avatar
Well I drove the truck today with the new engine and transmission. The l33 has 130000 miles.I had the heads milled .036 and had the valves redone. I put a free lq9 cam in along with ls3 valve springs. With high 10 ish compression this engine runs! It's feels so peppy and strong yet is mostly stock. it will roast the tires now when I down shift frI'm 3rd to second. Sounds awesome with the new headers and high compression engine.
Old 04-06-2015, 11:26 PM   #180
oldman3
oldman3's Avatar
Sounds really good...Jim
oldman3 is offline   Reply With Quote
Old 04-07-2015, 06:18 PM   #181
notchbackgta
You only paste the video number, like this (but don't try to copy that,lol)
http://www.youtube.com/watch?v=KNK3atXuxcU
notchbackgta is offline   Reply With Quote
Old 04-22-2015, 12:02 AM   #182
iceship
So how did you swap and use a 80's power steering pump... My 6.0 did not come with ps pump and the 80's is muck easier to find...
iceship is offline   Reply With Quote
Old 04-30-2015, 07:12 PM   #183
engairuph
Sounds good. On the starter you used the 68 starter wire or off the computer, and what did you do with the hot distributer wire?
Ralph L. Jasper
69 4x4 Suburban PTO winch(NAVY)
13 GMC Ext cab
12 Ford Fusion SE(wife)
MAI
Interior shop
engairuph is offline   Reply With Quote
Old 04-30-2015, 07:25 PM   #184
vannatta20
vannatta20's Avatar
I used the orginal starter wire. The pcm just gets iGnition ,constant and ground and it's go to go.
[+QUOTE=engairuph;7154910]Sounds good. On the starter you used the 68 starter wire or off the computer, and what did you do with the hot distributer wire?[/QUOTE]
Old 05-01-2015, 01:37 AM   #185
solidaxel
solidaxel's Avatar
The hot (switched) distributor wire makes a good point for your switched side of your new harness
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 05-22-2015, 02:45 AM   #186
SIETEDOCE
is the redline air filter kit? How work work?
SIETEDOCE is offline   Reply With Quote
Old 05-24-2015, 03:31 AM   #187
Rusty69
I'm waiting on my 5.3 to come in. Is the accelerator drive by wire or is it cable operated? How much are you asking for your harnesses? The engine I'm getting is complete, but I'd imagine your harness is more tailored to our trucks.
Rusty69 is offline   Reply With Quote
Old 05-24-2015, 04:21 PM   #188
vannatta20
vannatta20's Avatar
Talking Re: 1968 C10 5.3 swap, the easy way.
PM sent
Old 05-24-2015, 04:23 PM   #189
vannatta20
vannatta20's Avatar
Amazon.com: Spectre Performance 9900 Air Intake... Amazon.com: Spectre Performance 9900 Air Intake...
Old 06-01-2015, 05:54 PM   #190
Juiced06GTO
You are better off with a truck intake than the ls2 unless you are just doing it for looks. The truck intake makes more tq and hp than the ls2 intake. An ls6 or FAST would be the only upgrades worth doing to it as far as intakes go. On my GTO I picked up 30hp and 37lbft tq going from the ls2 intake to a 90mm Fast intake.
Juiced06GTO is offline   Reply With Quote
Old 06-02-2015, 01:32 PM   #191
jadedbird
jadedbird's Avatar
Wonder how similar a 64 build would be
jadedbird is offline   Reply With Quote
Old 06-03-2015, 06:57 PM   #192
mobymikeguide
Two questions as I will be doing this to my 68 soon, It appears you hooked your 4l60e to the standard column shift, how did you do that. Next question is what headers did you use, they look like doug thorleys and how did they fit?
mobymikeguide is offline   Reply With Quote
Old 06-03-2015, 07:12 PM   #193
jadedbird
jadedbird's Avatar
He used ls3 manifolds off a camaro
Old 06-03-2015, 08:20 PM   #194
engairuph
The LS3 fits better then the truck manifolds with more room. US shift has linkage for any type transmission to your column and excellent people to answer questions if confused.
Ralph L. Jasper
13 GMC Ext cab
MAI
Interior shop
Old 06-04-2015, 09:34 AM   #195
bodydropped68
PM sent
I also pm'd you any info would be appreciated Thanks Paul
Old 08-08-2015, 02:51 PM   #196
layingC10nK5
Very nice bro. I just got a 03 lq4 and I'm going to get back on my project after 3 yrs. Do you have any more details on how you made the stock pump work on the fuel tank? You are able to run the 6 pin throttle body?
layingC10nK5 is offline   Reply With Quote
Old 08-08-2015, 09:35 PM   #197
ls1nova71
ls1nova71's Avatar
Originally Posted by ls1nova71 View Post
Ok, tell me I'm not losing my mind, your sig says you live in Vegas, but I would swear I just saw this truck northbound on 291 in Independence about a half hour ago? I was going the other way and the nearest place to turn around was 1/4 mile away, so I couldn't just turn around....
So 8 months later, I saw the truck again at a local cruise in. Not totally loosing my mind, going down the road this truck looks identical to yours.....
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 08-10-2015, 01:40 PM   #198
55chevy1st
We used the boyd welding carb tank and simply dropped in a LS1 fuel assembly I got off ebay for 50$ It works great and was simple to do. The tank also came with a fuel sender so my fuel gauge will work properly now. My dad made the truck a short bed. I bought new bedsides to help with that and they shorted the frame. Found a deal on TTII rims in 18x8 and will be installing those shortly. The rest of the truck should be finished and assembled next week some time. We used a single stage paint.
What did you do to get module to lock into place in the boyds tank? Was the LS1 module the right length? I just ordered a boyds tank and want to do the same thing but I cant find where I can buy the flange to mount to the tank. Any help would be greatly appreciated. Love your build by the way!
55chevy1st is offline   Reply With Quote
Old 08-16-2015, 01:54 PM   #199
vannatta20
vannatta20's Avatar
HAHAHA omg that looks just like it!! Just different wheels!
Old 08-16-2015, 01:57 PM   #200
vannatta20
vannatta20's Avatar
Try this one
Amazon.com: ACDelco TR14 GM Original Equipment... Amazon.com: ACDelco TR14 GM Original Equipment...
