Old 03-15-2013, 06:55 PM   #176
CRGRS 66
CRGRS 66's Avatar
Re: CRGRS 66 – Winter Build Thread
few more pics, I am quite pleased with myself as I never thought that I would go anywhere near this far on this when I bought this truck. I owe this to all of you guys. I have learned an incredible amount from looking in on all of your builds. The other thing that has been an amazing help to me is the ability to post up questions. The amazing thing about this is that when I have posted questions, I get responses from so many 60-66'ers, but I also have had responses from other "age" groups. I am eternally grateful to have happened on this forum, and eternally grateful for all of the help and inspiration I have received here.
Ok, enough of that nonsense, time for some fine ales!!!!!!
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 03-15-2013, 07:21 PM   #177
greg65
greg65's Avatar
Lookin good.
1965 c-10 swb
1997 c-1500 extended cab
2004 tahoe
1993 mustang gt
BUILD THREAD:http://67-72chevytrucks.com/vboard/s...d.php?t=336653
greg65 is offline   Reply With Quote
Old 03-15-2013, 08:59 PM   #178
Bomp
Bomp's Avatar
Really dig the "cab lifter cart".
I use an A-frame style and its a pain. Come-a-longs, chains,etc.
I just may copy.....NO... Im makin me one now.
Nice to see your making progress.
Bomp is offline   Reply With Quote
Old 03-16-2013, 11:46 AM   #179
Jazbojinx
Jazbojinx's Avatar
Hi CRGRS 66, don't know if you got your power brake mounting issue figured out. Here is an adapter that uses the stock bolt holes. They sell them on eBay I'm going to just make my own. Really simple plate. My 66 is going to go thru the frame off next fall. Going to drive it this spring/summer just picked it up a month ago. Put this number in eBay search. 330858926129
Jazbojinx is offline   Reply With Quote
Old 03-16-2013, 02:42 PM   #180
CRGRS 66
CRGRS 66's Avatar
Originally Posted by greg65 View Post
Lookin good.
Thanks for noticin' (Eyore)
My wife thought I was pulling her leg when I came in and said the cab is off, where's my dinner!
Thanks jazbojinx, I bought the captains bracket, heard nothing but positive feeeback from the others on the board. Just taking a break from getting the above mentioned ready to go to the blaster, last little job is to drill the holes for the PS bracket. Then on to a whole mess of clean ip, wire wheel, sandblast, paint his, paint that...
BTW, welcome aboard, and thanks for looking in!
Craigerrr
Old 03-16-2013, 03:22 PM   #181
McMurphy
McMurphy's Avatar
Could you shoot some pics of your cab lifter please?
Like Bomp, I would enjoy seeing how you made that.
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 03-16-2013, 05:22 PM   #182
CRGRS 66
CRGRS 66's Avatar
It is not actually a "cab lifter". It is a steel frame with casters on it, I got it from work. It was taking space, and a quick measuring job told me it would be perfect as a cab cart. The uprights really served me no purpose, just happened to be there. I had the frame supported by jack stands, and rolled the cart under the rear of the frame up to the jack stands. I then lifted the frame off of the jack stands at the rear of the truck just enough slide them out of the way. I then rolled the cart under the cab and used some paving stones between the cart and the frame at four (cab bolts were previously removed). I still needed to support the frame as I had to raise everything up further so that I could get the jack stands between the cab and the cart. This was necessary so that there would be enough clearance to get the frame out from between the two. I used a floor jack at the front to raise the frame at that end. As it was cantilevered it was super easy to lift the front end by hand, but I could not do that and place the jack stands at the same time.
More or less just a flat deck on casters. Hope that helps.
Craigerrr
Old 03-16-2013, 05:28 PM   #183
CRGRS 66
CRGRS 66's Avatar
Back at it today. Removed all of the clips and bits and fasteners from the frame, removed the cross member furthest back (I may try to mount my trailer hitch there, if not will bolt cross member back in), removed the brake lines, trac bar stud, emerg cables etc. from diff, drilled the holes for captain fabs PS bracket, drilled the holes in the trailing arms for the sway bar mounting brackets (had marked their location last weekend when mocking up the rear susp), and did some tidying up. I believe that there is workbench in my garage, hopefully when I put all of my tools away tomorrow I will find it
Frame, diff, trailing arms ready to go to the blaster now, but I won't take them until I have the cab floor, firewall, and underside cleaned and painted.
Craigerrr
Old 03-16-2013, 09:44 PM   #184
Rich 5150 69
Rich 5150 69's Avatar
You are doing an awesome job Craiger, definitely a lot of detail going on here..!
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 03-16-2013, 10:08 PM   #185
chad64chevy
chad64chevy's Avatar
craigger, glad to see that your getting some work done on your truck! it always snowballs when you want to upgrade something or clean something, you start thinking to yourself that you can clean and paint that part since you got those parts off and so on and so on, lol!!
chad64chevy is offline   Reply With Quote
Old 03-17-2013, 12:02 AM   #186
CRGRS 66
CRGRS 66's Avatar
Thanks Rich
Thanks Chad, I truly hope to get some miles back on it by late summer or fall, whatever the case, I am just thrilled to have the truck, and to be working on it
Craigerrr
Old 03-17-2013, 10:35 AM   #187
MARTYZ
MARTYZ's Avatar
Look at CRGR go, looking good ,peices look too be in nice condition too will be real nice all painted up . Keep up the nice work
MARTYZ is offline   Reply With Quote
Old 03-17-2013, 12:56 PM   #188
clemdaddy
clemdaddy's Avatar
you're doing it right man... back to the bone.
looks great....
clemdaddy is offline   Reply With Quote
Old 03-17-2013, 10:18 PM   #189
CRGRS 66
CRGRS 66's Avatar
looks great....
Thanks guys!
I have figured out what I want to do for my trailer hitch. I am going to turn my bumper upside down, and relocate my receiver higher. I am also going to grab one of those flip up tag brackets to hide the receiver. Should look pretty slick, and will also be a very simple mod. Not crazy about the receiver hanging down so low, rather unsightly actually!
Craigerrr
Old 03-18-2013, 05:13 PM   #190
flips72
flips72's Avatar
can anyone say snowball i like the idea on the hidden hitch and fliped rear bumper. great work and you will be very glad you have took it to this stage, nothing like starting with a clean frame and going up
flips72 is offline   Reply With Quote
Old 03-19-2013, 11:32 AM   #191
Bomp
Bomp's Avatar
Looking good on the progress. Even though it doesn't have lifting capabilities its still a cool cart.
Old 03-21-2013, 07:52 PM   #192
CRGRS 66
CRGRS 66's Avatar
Thanks for posting guys.
Hope to get some serious progress on cab cleanup this weekend.
Meanwhile, i received a package in the mail today from my very good friend McMurphy all the way from the North Frigid Pole!!! Thank you so much Murph! Speedo looks great, looks much better than mine, i will put it in my cluster when i get some time.
Craigerrr
Old 03-22-2013, 12:20 AM   #193
McMurphy
McMurphy's Avatar
You are VERY welcome sir !!
I was hoping that shipping it in one of the cluster bodies would be Ok.... guess it arrived undamaged?
I am happy you got it and happy to help out !!
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 03-22-2013, 03:01 PM   #194
cjj737
Originally Posted by CRGRS 66 View Post
Oh, I forgot. After about the hottest most wonderful shower in the history of hot showers, I donned my favorite tee shirt, and chilled
where did u get that shirt i want one!!!
cjj737 is offline   Reply With Quote
Old 03-22-2013, 03:44 PM   #195
Rich 5150 69
Thanks guys!
Thoughtbi would show you this pic in case you want this, remember Fchava's truck. He uses a chrome cap bolted to a receiver plug when he's not towing.
Old 03-22-2013, 06:30 PM   #196
CRGRS 66
CRGRS 66's Avatar
St. Armand Circle, Sarasota FLA, it is actually died with beer! There was a "will sell husband fir wine" one there that my wife wanted... I told her she couldn't have it
You appear to be new, welcome, and thanks for posting!
Thanks Rich, I saw that in a thread, cool idea! Wasn't that the one pulling the boat that had a V8 and zoomies?
Craigerrr
Old 03-22-2013, 07:09 PM   #197
Rich 5150 69
Correct....!
Old 03-29-2013, 04:01 PM   #198
CRGRS 66
CRGRS 66's Avatar
have been working away at cleaning up the firewall inside and out as well as the cab floor. Someone did some welding (pretty ugly welding, but who am I to say), and there will need to be some fixes done. I have a welder/buddy coming to have a look one night next week. Here is the hole that the PO cut in the floor for the shifter as well... I actually cleaned it up a little bit, yes it was worse than this. Once it is welded up, and I figure out where the new hole needs to go I will cut it with the minimum diameter hole saw necessary.
Craigerrr
Old 03-29-2013, 04:03 PM   #199
CRGRS 66
CRGRS 66's Avatar
Question, is this trim piece glued on?
I have a new chrome one that I bought a while back, but don't want to cause any damage to the door removing the old one.
Craigerrr
Old 03-29-2013, 04:25 PM   #200
CRGRS 66
CRGRS 66's Avatar
tattoo Don (Ta2don) would like my glove box emblem, so I could really use a little advice on getting it off without causing damage to the emblem, or the door...
Craigerrr
