Old 10-23-2014, 03:55 PM   #176
y5mgisi
Second Chance Program
y5mgisi's Avatar
Re: Project "River Truck" - CCLB 4x4
Great work! You could consider dropping the rear back down by using ord's 2.5" lift brackets and selling your 4" ones. That is what I would do. Then, if over time the springs sag a bunch, you could just add a 1" block.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 10-23-2014, 04:08 PM   #177
arrover
arrover's Avatar
Yes that is definitely a possibility. I'm going to lift the front and see how much lift I get there. If it's pretty level, I will probably leave it. If not, I'll adjust it somehow. If the front is lower I might also add zero rate. Thanks for the bracket swap suggestion. I will certainly keep that in mind!
1982 GMC Crew Cab 4x4 - "River Truck" build thread
1973-1987(91) Chevy/GMC How-To Videos
arrover is offline   Reply With Quote
Old 10-23-2014, 08:55 PM   #178
MTCK
MTCK's Avatar
Nice job! I think you are right that your sprigs had a pretty tough life and we're tired. The new leafs should settle a bit.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 10-27-2014, 10:15 PM   #179
Gaelon
Are your tires the stock size for the H2 wheels (315/70R17) or are smaller tires mounted?
Gaelon is offline   Reply With Quote
Old 10-27-2014, 11:16 PM   #180
arrover
arrover's Avatar
No, the current tires are 285/70-17s. I've been eyeing another set of wheels and I have some really worn 315/70-17s that I would probably put on them. I would also just like to see what these current wheels/tires look like after the lift is done. So, I'm not really sure what I'm going to do yet....
Old 11-07-2014, 06:28 PM   #181
arrover
arrover's Avatar
I finished the front lift a few days ago. It went much easier than the rear. Things were less rusty so things came apart more easily. Here are some pics...
Old 11-07-2014, 06:30 PM   #182
arrover
arrover's Avatar
more...
Old 11-07-2014, 06:30 PM   #183
arrover
arrover's Avatar
couple more
Old 11-07-2014, 06:35 PM   #184
arrover
arrover's Avatar
And here is what it looked like after the front and rear lift. With all the things that I changed, the rear ended up a little too high. Some of the pictures don't show it well but it had quite a rake to it. You can see that on the level. So I ordered the 2.5" shackle flip brackets from ORD and installed them this morning. It has a nice stance now. I promise to get you pictures of the finished lift ASAP. I haven't had a chance to get good ones yet.
Old 11-07-2014, 06:40 PM   #185
arrover
arrover's Avatar
If you're planning on installing a lift, this is probably worth a watch:
Old 11-07-2014, 11:02 PM   #186
Sodell
Sodell's Avatar
Great info, truck looks great!
Scott
87 Chevy 2WD SWB, 88 4x4 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=610652
Sodell is offline   Reply With Quote
Old 11-07-2014, 11:23 PM   #187
MTCK
MTCK's Avatar
Truck looks awesome. Curious to see how the rear wheel is centered with the lower shackle flip.
-Marcus
Project Plow Truck
Old 11-07-2014, 11:37 PM   #188
y5mgisi
y5mgisi's Avatar
How does it ride and drive?
Old 11-09-2014, 06:31 PM   #189
arrover
arrover's Avatar
Thanks guys! I swapped out the 4" ORD shackle brackets for the 2.5". The swap was easy and quick. I'm really liking the result. It's much more level now.
Old 11-09-2014, 06:54 PM   #190
arrover
arrover's Avatar
I had read that on some trucks, depending on what lift and shocks you put on it, the rear passenger shock body could contact the axle tube. Unfortunately that was the case on my truck. The interference was so bad that the shock couldn't even be mounted to the axle. ORD said that a lot of guys just cut a slit in the shock bracket on the axle, then bend the bracket backwards, and then weld up the gap that opened up. That's how I did it and it seemed to work well.
After I actually drove the truck, I found that my turning radius was horrible to the left and the pitman arm/drag link joint would contact the tire. The steering wheel was also way off center so I adjusted the drag link and that fixed the steering/rubbing issues and centered the wheel.
The truck feels like it drives almost exactly the same as it did before the lift. The ride is better with the lift. I think that is probably because of the new shocks.
Old 11-09-2014, 07:05 PM   #191
arrover
arrover's Avatar
Forgot to post these pics showing the ORD 4" lift brackets next to a 2.5" bracket. The strange lines on the finish of the 2.5" brackets are because ORD shipped the brackets to me when the paint was still wet. I told them that I needed the brackets for this weekend. They called me back later in the day and gave me the option to ship them that day or wait for the paint to dry. I told them to ship them wet so I could get the truck together in time.
Old 11-09-2014, 07:13 PM   #192
arrover
arrover's Avatar
The payoff for the last few weeks of work was that I was able to actually take the river truck to the river this weekend! We went camping and the truck performed great. I hauled lots of gear and several loads of firewood. The truck is popular with people which is funny because it was over 20 years older than all of the other vehicles there. Fun time.
Old 11-09-2014, 08:27 PM   #193
Sodell
Sodell's Avatar
Looks awesome, not over done, and drivable!
Scott
Old 11-09-2014, 10:59 PM   #194
MTCK
MTCK's Avatar
Great work! Glad you got to get out and use it.
-Marcus
Project Plow Truck
Old 11-10-2014, 09:26 AM   #195
Low Elco
Looking good, glad you're putting 'er to work!
Low Elco is offline   Reply With Quote
Old 11-16-2014, 10:04 PM   #196
arrover
arrover's Avatar
Here's some footage of the truck from the river camping trip last weekend:
Old 11-16-2014, 11:06 PM   #197
y5mgisi
y5mgisi's Avatar
Looks great! How do you like the ride now compared to stock?
Old 11-16-2014, 11:20 PM   #198
arrover
arrover's Avatar
Thanks y5mgisi. It steers the same as before the lift and the ride is better. I think that's because the old shocks were shot. Hopefully the new shocks will continue to break in and it gets even better.
Old 11-16-2014, 11:34 PM   #199
y5mgisi
y5mgisi's Avatar
Thanks! I just cant figure out what the heck shocks i want to get... i was thikning the 8000's might be a bit too harsh and that i might want the 6000's. My k25 is fairly "light" and will be getting an ls motor which will lighten it up more. So im currently thinking i want to get the tuff country 2" ex ride(non hd) front springs, the 2.5" shackle flip for the rear and i kinda think the 8000's since i'll have the non hd springs.
Old 11-17-2014, 12:23 AM   #200
arrover
arrover's Avatar
I'm really not an expert on shocks but I have always been lead to believe that more expensive/higher end shocks will give a better ride. You might want to just call Tuff Country and ask them to explain the differences. The EZ Ride springs should ride better with your setup. I went with the HDs because of the 454 in the truck now and the possibility of a diesel in the future.
