05-09-2017, 11:12 AM | #176 |
Re: RnD Fabrication 1967-1972 Chevrolet & GMC early C10 / C20 / Blazer Radiators!
back up
05-10-2017, 07:41 PM | #177 |
Need a price for radiator for 67 c10 ls6 4l80 with trans cooler and electric fans please
07 GMC Sierra 2500 compound turbo' duramax 99 GMC Yukon solid axle swapped 67 Chevy c10 small window swb stepside supercharged ls6 70 Chevy c10 suburban 72 K5 Blazer 4wd |
05-11-2017, 10:02 AM | #178 |
The radiator is $425 after discount. For the fans, what hp is your engine making? We have 3 levels of fan kits, and here are the prices after discount:
standard kit (dual 12's): $220, good to around 425hp upgraded kit (single 16 HD or single dual-speed 17 HD): $320, good to around 550-600hp extreme duty kit (dual extreme duty 12" fans): $430, we have these on vehicles with upwards of 1,000hp Shipping to AL is $50 |
05-11-2017, 10:24 AM | #179 |
The engine is supercharged don't know if that matters or not. But it's currently putting a little over 500 to the wheels
05-11-2017, 04:33 PM | #180 |
That does make a difference. That means you are probably in the 600-620hp range. I would go with the upgraded unit at a minimum, and would consider the extreme duty (that's what I run on one of my LS applications that will eventually be boosted).
05-22-2017, 05:48 PM | #181 |
back up
06-09-2017, 10:11 AM | #182 |
up top again
06-11-2017, 12:13 AM | #183 |
Nice looking radiatior. I need a price on 1 for a 71 c10 I have 4 row mounts. I also have the Lq4 ls truck motor. Don't need steam port or heater hose outlets but do need a trans cooler that will work with the factory steel lines. Also want dual good fans with shroud. Thanks my name is Jason.
06-11-2017, 08:24 PM | #184 |
The Forum member discounted price is $425 for the radiator, and for the fans I need to know what kind of power you are making in order to make a recommendation
06-19-2017, 01:28 PM | #185 |
How do i order? I went to your site and i saw i can buy via PayPal but doesn't give as option for the forum discount or to specify ls swap and port location ... also what is your current lead time?
06-19-2017, 01:32 PM | #186 |
Power is 400 hp on mine with ls motor
06-27-2017, 10:36 AM | #187 | |
Ok, that will use our standard 12's unless you are in a very hot location (southern USA, etc). Those are $220 with forum discount. let me know if you'd like to order. |
07-10-2017, 11:22 PM | #188 |
Thanks for the orders!
07-13-2017, 06:13 PM | #189 |
So what is your actual lead time if I were to order a radiator from you say this coming Monday. And also, can I get a quote for an LS swap radiator, no fans or shrouds, no trans/oil cooler shipped to 46755. Thanks, and I will be in touch soon.
07-13-2017, 06:19 PM | #190 |
we are about 3 weeks out from date of payment at the moment, possibly sooner. The discounted price is $425, and shipping is $60 to that zip.
07-13-2017, 06:38 PM | #191 |
Thanks man. Not sure I wanna drop 5 bills on a radiator but if I change my mind I will be in touch.
07-13-2017, 11:08 PM | #192 |
No problem, thanks
07-16-2017, 01:01 PM | #193 |
Your fabricated valve covers for LS engines - do they have a provision for oil fill?
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
07-23-2017, 05:59 PM | #194 |
I'm considering one of your radiators but the one year warranty throws me? I barely drive my blazer and don't want to spend close to a grand to only have it spring a leak in a few years. I was looking at Other options and some offer a lifetime warranty against manufacturers defects. I have heard of people going through 3 or 4 radiators that leaked (not yours).
Kirk 72 Blazer CST 4wd highlander 66 Nova |
07-25-2017, 01:36 PM | #195 | ||
07-25-2017, 03:24 PM | #196 |
Fair enough but my concern is I drive about 2-3000 miles a year if that. Would you stand behind it after the warranty if a weld failed or some other defect presented itself? I'm looking at entropy and they are made state side with a lifetime warranty.
What do you recommend for an ls3 swap in a 72 blazer? At most 500-600 hp.
07-25-2017, 04:16 PM | #197 |
Our current policy is 1 year against manufacturing defects. We usually work with our customers, and rarely have any warranty claims. We get a lot of former Entropy / Champion customers.
On that set up, I would go with our 17" dual speed HD fan which is good to around 550hp. Above that and in warm temps, I recommend our Extreme Duty dual spal 12's which are good to just shy of 1k hp. |
07-27-2017, 09:22 PM | #198 |
08-15-2017, 08:47 AM | #199 |
bringing up again!
08-15-2017, 11:23 AM | #200 |
Hey Sparky,
You said your LS swap radiators have NPT fittings for the transmission cooler lines. Is there anyway to get the quick disconnect O ring fittings instead, so the factory hard lines can be used with your radiator? Thanks. |
