#176 |
Re: Carolina K10, 1979 Reg cab short bed.
Any updates Austin?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#177 | |||
I can't wait! Everyone is saying I'll be happy with the stock 5.3 setup (and I will), but I know I'll be SUPER happy with the TT setup! ![]()
Austin 1996 Chevrolet K1500 Silverado ![]() 1979 Chevrolet K10 Scottsdale - Carolina K10 - My 4.8L Twin turbo build - Project Short Stroke - Instagram - TheBlueBomber1996 |
#178 |
Yes I do!
So the past few days I've been going to job interviews (between jobs as of a week ago) and have been waiting on the transmission for my daily driver (which I picked up today) While I was waiting I figured I would try my hand at some welding... These welds look like something a blind kid with no hands could do ![]() ![]() ![]() I'm still learning. At this point I feel like a majority of the problems I'm having are the machines fault and a little bit is my fault. Later this year I'll be picking up a better machine. Here's the tranny for the '96 Z71. So beautiful!! ![]() ![]() So I'll be dropping this in either tomorrow or Sunday, and once I start getting some steady paychecks I'll have the K10 on the road. I'm aiming for a mid April to early May finishing point.
#179 |
Hope you find a job soon. These old trucks like money.....lol.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
#180 |
Thanks and yes they do! Shouldn't be long now, should be hired up within the next week or so. So ready for beach weather and this 5.3 swap.
#181 |
Me toooooooo. I went to Roaring Gap wensday and there was close to four inches of snow on the ground. Had to dig out the walk boards to get into the house I was working on. And it was cold up there. Man I'm ready for a warm up.! I'm ready to hit Kure Beach. Maybe take a fishin rod and just chill on the pier.
#182 |
Welds don't look bad Austin....will come with practice. Trans looks great and congrats on the new job!!!!!
#183 |
So I think I've found a transfer case a few hours away. Contacted the seller but no response so I left a message. Won't be until next week before I could go out and get it.
Thinking of just ordering a transmission through Monster transmissions... I'd plan on rebuilding it come turbo time so I might as well get it done now and not have to worry about it later.
#184 |
Just got off of the phone with the owner and he's going to double check if it's splined for a 4l60e or 4l80e. Most likely I'll end up picking it up either way.
#185 |
Keep practicing with the welds. Its hard for them to look nice when you are using flux core. Clean all your metal before you weld and they will look better.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
#186 | |
So next Friday I will be going to pick up the transfer case... it's setup for a 4l60e/700r4 so I will have to change the input shaft. The ball has started rolling once again!!!!
#187 |
When you get the chance read this thread. Lots of good tips for improving the look of the weld (yes strength is more important): http://weldingweb.com/showthread.php?30845-Mig-like-Tig
Your making good progress! Keep it up
#188 | |
Drove two and a half hours out to Newport, North Carolina to pick this bad boy up... It's an NP241C out of a 1989 K5 Blazer. The T-case had been sitting out of the truck and in the rain for a while so I will be going through this case. I will need to re-spline the input shaft for the 4l80e and install the slip yoke eliminator. Also I won't have to go through the trouble of building the wiring harness/fabbing up an electronic speedometer. Has the hook up for cable driven speedo. Will be looking for a tach cluster as the build gets a little bit further ahead. ![]() ![]() ![]() ![]() ![]()
#189 |
Any updates Austin?
#190 |
None so far on the k10. I've been buttoning up the Z71 lately. Have a few things left on that and I'll be able to focus 100% of my project time/budget on the k10. I should be making a thread on the z71 soon. Recently picked up a set of 2014 wheels and tires for next to nothing.
#191 |
Just read through this whole thread, love the k10 to say the least. My dad used to have one just like it but black, lots of memories. Z71 is badass too dude! Also I follow you on instagram so I can see the truck more often.
Andrew 85 Sierra Classic c10, 305/350/2:73(86k original) instagram: anabb_98 |
#192 |
We are doing some similar stuff!! What headers/manifolds you plan on using? What motor mounts as well? I too live in the carolinas! Just South Carolina!!
I am swapping ls setup into 87 GMC V1500 LWB. However, I got an almost complete 2001 ext cab silverado 4x4 so I am swapping almost everything off it. The entire wiring harness, engine, trans, fuel tank, rear end, radiator, gauge cluster, steering column and front seats. I am currently having some trans issues with the 4L60E and I am in the teardown (of the 2001) stage and labeling wiring as well as gathering parts. I can't afford too much down time on my 87 b/c it is my only truck. Plus the 87 has a rebuilt 350tbi/700r4 combo with less than 8k miles on it, I just want to go LS!! |
#193 | ||
I plan on going with some $30 adapter plates for the motor mounts. As for the headers I'll end up using the stock ones for now. The cool thing about the LS is I can flip the manifolds upside down and use them for the turbo setup if I wanted to. Does that 2001 truck have rear disc brakes?
#194 | |
Yes the 2001 does have stock rear disc brakes with 1 piston calipers. I plan to take the brake master cylinder and distribution block off the 2001 as well. I am not sure if the booster off the 01 will work on my truck though. I am trying to do as much research as I can. I know the 01 rearend is about 1" or 2" wider than my 87 but that is fine with me! |
#195 |
Nice job Austin...looking good!!
#196 | |
I've seen where some people have had frame trouble with the manifolds and where others have not. Guess it's depending on the type of mount you use. I'll throw the dart at the board blindfolded on this issue and hope I hit it. Haha
#197 |
I'm excited to see how it goes! What is your plans for a/c?
#198 |
Delete haha!! The truck didn't have factory air but between the floor vents, the wing windows, side windows, and sliding back glass I get a good amount of air flow. If my next truck comes with the A/C option I'll definitely run it.
#199 | |
I checked codes on my setup last night in the 01 chassis still. I had codes: P0133 - 02 sensor P0332 - knock sensor on Bank #2 is generating a low output voltage P0785 - 3-2 Shift Solenoid Circuit Electrical So it looks like I have some stuff to replace before I finish disassembling everything. I want it to run perfect on the 01 chassis before I do my swap that way if I have a problem, its wiring! |
#200 | |
Got the adapter plates for the motor mounts. Now it's down to getting a trans so I can get this engine out of my garage and in the truck!
