Old 04-25-2015, 10:09 PM   #176
69cunningham
69cunningham's Avatar
Re: Lss3
Thanks-
The engine was a pull out from a 2010 Camaro with 4 miles. An LS7 swap was done. The accessories are CTSV ones. No notching was done, but the fittings are tricky. I bought some parts that almost work. They will require a bit of machining.
69cunningham is offline   Reply With Quote
Old 04-27-2015, 05:20 PM   #177
rkleypas
Re: Lss3
Thanks. I have a line on a 2010 ls3 with 14,000 on the clock. Going to use a T-56 behind it. I was thinking of using the vintage air front runner. Did you finish your wiring harness? I've heard that Painless makes a nice one that is easy to deal with. Any advice is greatly appreciated.
rkleypas is offline   Reply With Quote
Old 04-27-2015, 11:08 PM   #178
69cunningham
Re: Lss3
I’m using the GMPP 19201861 controller kit. It includes the wiring harness, computer and many of the needed sensors. I’ve laid it on the engine. To dress it nicely, I will need to take all the tape and split tubing off.
Old 05-01-2015, 09:37 PM   #179
69cunningham
Re: Lss3
I scored today. At work, we had an action of excess equipment to benefit the United Way. I came home with this killer TIG welder. I hope it will improve the sheet metal work. It will likely divert my attention from the truck to get the welder set up.
Old 05-01-2015, 10:00 PM   #180
rkleypas
Re: Lss3
Sweeeet! I'm so tired of grinding my crappy mig welds. Good luck on learning your new machine
Old 05-02-2015, 02:20 PM   #181
kitsbeach
kitsbeach's Avatar
Re: Lss3
What are you going to wrap your wires with.? I saw someone else using some expensive stuff but it sure looked good. Can't remember who's thread.
Kitsbeach (Ken)
1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills"
kitsbeach is offline   Reply With Quote
Old 05-02-2015, 04:02 PM   #182
69cunningham
Re: Lss3
I am using Power Braid from Painless Performance.
Old 05-22-2015, 08:38 PM   #183
69cunningham
Re: Lss3
There’s been a little progress to the to the brake lines. My Eastwood flaring tool is working great double flaring the stainless steel lines.
Old 06-23-2015, 09:51 PM   #184
69cunningham
Re: Lss3
Well it’s been a while. As I suspected, the new welder diverted me for a while. I had to get Argon for it and resolve a flow meter issue. I ended up rebuilding it. Now the system is working. Now to learn how to use it.
I have spent a lot of time, staring at the chassis, trying to figure out how to run the brake and fuel lines, the emergency brake cables and where to hang the battery. It is much easier to look at it than work on it.
I did receive one wheel. It is a 17X9 Rally from Year One. It passed the first test: Does it clear the brake caliper? Now I need to assemble more of the truck to see if it clears everything else. I only bought one just in case there is a problem.
Old 08-02-2015, 08:30 PM   #185
69cunningham
Re: Lss3
I think I finally have the emergency brake routing figured out.
Old 08-28-2015, 05:26 PM   #186
69cunningham
Re: Lss3
Several months ago I got a 25’ coil of 3/8” stainless steel tubing to use for fuel lines. I didn’t spring for the $90 tubing straightener from Eastwood. A tool that only works on one size material that would likely only be used once. I tried hand straightening. That really screwed it up. I also tried several wooden jigs clamped together with C clamps. This worked a little better, but not good enough. Lots of ripples remained. Today I used the machine shop at work to make a base plate out of aluminum. Home Depot had some wheels used on patio doors. It is a bit tricky to adjust, but the tubing ended up straight. Now there is no more excuse for not completing the fuel lines.
Old 08-28-2015, 08:59 PM   #187
notchbackgta
Re: Lss3
Thats what I did, works great. I put 5 rollers on though
notchbackgta is offline   Reply With Quote
Old 09-07-2015, 01:10 AM   #188
mechanic350
mechanic350's Avatar
Re: Lss3
Nice work. Coming along great
1972 Chevrolet swb fleet side. - SOLD
2018 Toyota Tacoma but hunting for another C10
Link to my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=607303
Instagram: https://www.instagram.com/72c10shortbox/?hl=en
mechanic350 is offline   Reply With Quote
Old 09-08-2015, 10:57 PM   #189
69cunningham
Re: Lss3
Running the fuel and brake lines has really stumped me. I want to run them in a single length inside the frame. I couldn’t figure out how to get the right shape. On Monday, I decided to make a layout table that I could draw a full size template of the frame on it. I taped a laser level to the bottom of the frame so I could measure the different heights of it. It will take a bit more time to finish the drawing and start bending tubing.
Old 09-10-2015, 08:18 AM   #190
mcbassin
Still Learning
mcbassin's Avatar
Re: Lss3
Nice progress on your truck. Just keeps getting nicer!
mcbassin is offline   Reply With Quote
Old 09-15-2015, 11:11 PM   #191
69cunningham
Re: Lss3
I finished measuring the frame and drawing it on the layout table, then drawing the fuel line. I did a test bend with aluminum tubing and tried to weave it into the frame. No luck. The tube got mangled. Maybe the stainless tubing would have sprung back, but I decided not to chance it. I added a bulkhead fitting to the cross member in front of the fuel tank. This way the fuel line can be split in two. There will be fewer obstacles for each piece to work around.
I got a couple of parts to start my intake system, both from Spectre Performance. The flexible elbow is part number 9785 and the mass air flow sensor 9718. I still need to figure out an air cleaner and housing. It needs to pull cool air from in front of the radiator.
Old 09-16-2015, 08:42 AM   #192
Hart_Rod
Hart_Rod's Avatar
Re: Lss3
Nice job on the project! I built a cold air box and mounted it where the factory battery was mounted.
Hart_Rod is offline   Reply With Quote
Old 09-16-2015, 12:04 PM   #193
nlped
nlped's Avatar
Re: Lss3
Killer truck & amazing attention to detail!
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 09-16-2015, 09:41 PM   #194
69cunningham
Re: Lss3
Rob-
That’s a nice setup. I have been considering several commercial parts like the 9831 from Spectre performance or the 17-2519 from DoghouseRepair.com. The Spectre unit would require some more fittings to connect to the radiator support. The doghouse part is nice. I like the large filter, but the filter is not commonly available. I think the setup was designed for dune buggies.
The other possibility is making my own housing for a standard filter. The Fram CA6818 looks interesting. It has a 4” ID, 8.5” OD and is 12.38” long.
Since you’ve been running your system for a while, is there anything you would do differently?
Old 11-16-2015, 11:08 PM   #195
69cunningham
Re: Lss3
Well I finally got the stainless fuel line bent. What a pain. It is in the chassis and ready to have clamps installed. Once that is done it is time to test the fuel system. Hopefully there will be no leaks.
Old 12-31-2015, 07:03 PM   #196
69cunningham
Re: Lss3
Look what my truck got for Christmas:
Old 12-31-2015, 07:14 PM   #197
69cunningham
Re: Lss3
Another piece I’ve been working on are the turn buckle adjustments for the rear sway bar. He ones that came from Hotchkis were intended for a 6 inch drop. Since I am only doing 4, the turn buckles needed to be longer. I made them out of ¾” aluminum, 8.5” long. The ends are drilled and taped. To make the turn buckle work, one needs to have left hand threads. Flats were milled to have a place for a wrench to adjust them.
Old 01-10-2016, 11:03 PM   #198
69cunningham
Re: Lss3
I did some mock up work with the new AC. I don’t plan on mounting it the way Vintage Air recommends. I want it to be more hotrod like. This means it will be neater. The firewall will be smoothed. I’d also like to get a deeper glove compartment than the stock VA allows. As can be seen in the second photo, the bracket spaces the evaporator pretty far away from the firewall. It should be able to move an inch or so closer. This will require the hoses to be moved further to the passenger side, something like the third picture.
Old 01-10-2016, 11:05 PM   #199
69cunningham
Re: Lss3
Been thinking about body work and paint. The sheet metal is in very good condition with the exception of the rusted out holes shown below. Looks like I'll get the chance to use that TIG welder. The rocker panels and cab corners appear to be good. I hope to abrasive blast and use an inspection camera to verify they are really solid.
Old 01-10-2016, 11:49 PM   #200
swamp rat
swamp rat's Avatar
Re: Lss3
Nice work on the cold air box, most people just route the air cleaner into the corner and call it good. The truck is looking sweet!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
