Old 05-16-2018, 12:38 AM   #176
Hankster
Hankster's Avatar
Re: "The Convict"
Originally Posted by 85raiderburban View Post
your gonna need the trans go vacuum modulator to drop line pressure since by default with jakes box it will be full line all the time. NOT good. But dont drill the case wit the tapped fitting that comes in the kit, drill thru the pan on the pass. side like i did and run regular vac hose to the intake.
Been sending it with full line pressure and the same fluid that was in it when i got the trans, no issues yet thankfully. Got the truck pulled apart for vortec heads, bigger cam, torker 2 intake, and headers right now. The full manual with max line pressure makes for a fun cruise.
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
Old 08-18-2018, 09:26 AM   #177
Hankster
Hankster's Avatar
Re: "The Convict"
Fired it up with the new top end. Got a set of roller tip rockers as well. The headers I ordered did not fit, oh well. Broke the cam in and re-adjusted valves. Tuned the carb but haven't got the timing dead set yet. Sounds healthy and feels more torquey then it use too. I'll have to get a video up soon.
Current Build
Old 11-27-2018, 03:23 PM   #178
Hankster
Hankster's Avatar
Re: "The Convict"
Been driving it when I can, I found that the intake is not sealed correctly. Didn't figure it would as it is a gen 4 intake on gen 6 heads. Time to order an intake manifold. I also have anew daily driver, 1986 Chevrolet c20, 350 4 speed truck.
Current Build
Old 10-29-2021, 04:17 PM   #179
Hankster
Hankster's Avatar
Re: "The Convict"
I eventually pulled the big block and went ls with a holley terminator. Shortly after I sold the truck because I wanted something I could enjoy instead of always wanting to do something else to it. I have had a few ride since then. 07 classic crew cab, stock, lifted, then lowered, three mustang GTs, and now have a one owner '99 gmc yukon that i saved from a field with 147k miles. Was a spare vehicle from 09-18 and sat from 2018 until a few months when I bought it. Fired it up and drove it home. It is my daily.
Current Build
