Old 10-14-2014, 08:07 PM   #176
solareclpse2000
Re: 1970 C20 long bed Duramax, Allison, on a 2003 4x4 chassis
The front being one if the main concerns for wanting to use the 2500 donor. This is an option, but only assuming the mating point where the factory weld has the same width and height of the frame rails between a 1500 and 2500. If that makes sense, it sounded much better in my head
solareclpse2000 is offline   Reply With Quote
Old 10-15-2014, 11:48 PM   #177
72 Copper C-10
72 Copper C-10's Avatar
That's is so sweet!!!! I can't wait to see more!!
72 Copper C-10 is offline   Reply With Quote
Old 10-29-2014, 05:08 PM   #178
SWB4x4
SWB4x4's Avatar
Awesome truck! My B.I.L. is lookin for something like this care to sell it?
J.T.
1972 SWB 4X4 on 35"s with 6" lift all around 3/4 ton running gear with high steer and 4.88s 350/th350. SOON TO BE DONE:2" higher in front 37"s,LSX Swap,Hugger Orange & White Paint Scheme,Air Conditioning,Power Windows & Locks,Complete Gauge Kit,Tank Relocation,Double Din Nav with full Audio System.
My Build Thread http://67-72chevytrucks.com/vboard/s...=1#post4169140
SWB4x4 is offline   Reply With Quote
Old 10-29-2014, 09:02 PM   #179
Lazzardkng
With all the time and Money I have in this truck I don't think I could get enough for it to make me give it up.
1970 Chevrolet + 2003 GMC Duramax 4x4 = Awesome
Lazzardkng is offline   Reply With Quote
Old 11-10-2014, 03:41 PM   #180
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Wow, great work you've done here! You sure know how to paint too. I really like the new needles and your gauge cluster. Very nice, and very well executed swap!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 11-10-2014, 04:47 PM   #181
Lalla666
Originally Posted by Lazzardkng View Post
How hard was it to swap that seat in ? And how's the leg room and clearance for a 4 speed ?
Lalla666 is offline   Reply With Quote
Old 11-12-2014, 09:54 PM   #182
Stryker67
Stryker67's Avatar
I tried to upload a couple videos but can't get them to load. Anyone know how or why?
Do you have a youtube account?
I will soon be combining a 2007 2500 HD extended cab long bed and a 68 GMC cab. The plan is to shorten the frame up under the cab, and make it a stake bed truck. I plan to tow and use the truck. It looks like you could have set the cab lower if the bed fitment wasn't an issue. Any thoughts?
[FONT=Georgia]
If nothing else, we can all serve as a bad example.
We don't know what we don't know.
The world needs ditch-diggers too.
Stryker67 is offline   Reply With Quote
Old 11-13-2014, 03:56 PM   #183
Lazzardkng
Yes, if you don't have to worry about the bed lining up and trim the bottom edge of the back of the cab you can lower it about 2"
Old 11-13-2014, 03:59 PM   #184
Lazzardkng
It required cutting the hump out of the floor where the original front seat mount attaches to but other then that it was easy. Leg room is a little tight but I'm 6'1" tall and fit pretty comfortably.should have plenty of room for the 4speed
Old 11-30-2014, 11:56 PM   #185
schwoch1
Local Detroit diesel nut!
schwoch1's Avatar
I just wanted to say that your truck is awesome and if you did not live 2000 miles away, I would love to see it personally! You have any more pics? Have you driven it yet? Sorry for 101 questions, but I am in the planning stages of a similar frame swap with my '69 GMC 3/4 ton crew cab truck. Hardest part is trying to find a suitable donor for a reasonable price, even wrecked/abused/rolled over Duramax powered trucks in my area still command stupid amounts of money!!!!! I was told at first to not waste my time doing a frame swap, just adapt a Duramax and axles to the old frame. Problem is, the newer trucks drive SO nice compared to the older trucks and my plan is to put some serious family miles on this thing pulling my 27 ft camper over the next multiple years! After seeing this thread I have decided to go with my original plan, which is exactly what you are doing! I have attached a pic of my ride that will start to undergo the same treatment come next summer! Thanks for the thread, looking forwards to seeing more updates!!!
Mike
Nothing cool anymore, I am old and boring....
schwoch1 is offline   Reply With Quote
Old 12-02-2014, 11:21 AM   #186
Lazzardkng
Attachment 1331351
Mike
I love the crew cab and wish I could have done one vice a reg cab but the original truck I started from has been in the family since it was new so I wanted to keep as much of the body as possible. I have a few smaller items to finish, wheels/tires, stereo, Bed liner, and such. Once that's done I will take some final pic's. If there is anything specific you would like to see pictures of let me know and I'll get them emailed to you or posted.
With doing a reg cab I was lucky and could use a reg cab donor which are harder to find but much cheaper. I picked mine (rolled over total) up for $2300 . I found it on COPART auto auction. Be careful when shopping for totals, these year chevy/gmc frames are usually bent if there is a front end impact. The frame horns have a weak spot right behind the front shock towers. Can usually be straightened or replaced but look for it so you know going into it.
Old 12-02-2014, 01:11 PM   #187
Jahloha
Jahloha's Avatar
Really loving these seats! Have a local shop do the upholstery or did you send it out?
-JASON
My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes.
My 1970 C20 Build Thread
Jahloha is offline   Reply With Quote
Old 12-02-2014, 01:31 PM   #188
Lazzardkng
A local shop here in Vancouver Washington. Texas Auto Upolstery.
Old 01-06-2015, 04:21 PM   #189
01chevduramax
01chevduramax's Avatar
I'm down in Astoria about an hour from you. I am attempting a similar build. Mine is a '71 long bed. I will be swapping all the parts to the truck frame. I would love to see your truck in person some day.
'71 org/wht 3/4 ton 4x4
01chevduramax is offline   Reply With Quote
Old 01-06-2015, 05:18 PM   #190
Lazzardkng
Anytime your going to be up my way (Kalama, Wa.) let me know and your welcome to see it. Send me a PM and I'll send my phone number.
Old 01-25-2015, 05:55 PM   #191
72k/5
I plan on doing this same thing with a 5.3 truck. I have based most of my plans off of your build. And was wondering on your headlight switch behind the dash how did you mount it. And was it fairly simple to wire the headlights off of the new harness. Any advice you could give would be nice. I bought a 2002 Silverado 1500 with 85000 off a old man. The plan is to put my 1972 blazer on that chassis it has had its first frame off finished about 5 years ago with 44 inch boggers and a 454 now I just want something easier to drive long distinces.
72k/5 is offline   Reply With Quote
Old 01-25-2015, 06:04 PM   #192
coopdog
coopdog's Avatar
what a cool truck and build, nicely done
.................._____
__________//___{\____
/__---____//____/__---/
.....(O). ..................(O).
BUILD THREAD K20 http://67-72chevytrucks.com/vboard/s...d.php?t=651601 pages 2-4
coopdog is offline   Reply With Quote
Old 02-05-2015, 05:04 PM   #193
bufmatmuslepants
Junior Member
How did you buy it off of Copart? Do you have a dealers license, know someone with one, or work a deal with a dealer?
1979 K10 reg cab short bed 33x12.50s - GONE
1988 4x4 reg cab long bed 337k miles - GONE
1995 Z71 GU6 G80 F44 ext cab short bed 149k 305/70/16s - GONE
1995 NZZ GT4 2dr Tahoe 3" lift 14 bolt sf 155k 305/70/16s - GONE
1994 Z28 M6
1995 Z71 GT4 G80 ext cab short bed 215k GONE
1997 GT4 G80 Yukon 4 door leather, sunroof 168k miles GONE
2003 Avalanche Z71 GT4 G80 165k miles
bufmatmuslepants is offline   Reply With Quote
Old 02-06-2015, 10:48 AM   #194
aggie91
I'm just glad to be here!
aggie91's Avatar
You can register online on their web site. If you are not a dealer, you can bid upto a $1000 without any deposit. You can only bid/buy vehicles with a salvage title. If you need to spend more than the $1000, you have to put up a deposit equal to 10% of the total you will bid. Pretty easy, you can follow online and bid online for the auctions. Only need to visit the yard if you need to look at what you are trying to buy...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 02-09-2015, 07:23 AM   #195
bufmatmuslepants
Junior Member
I've been hunting copart for a long time. What do you mean by only vehicles with a salvage title? You mean the ones with an "S" next to them? What does the "E" mean?
1994 Z28 M6
Old 08-11-2015, 06:49 PM   #196
1tonwannabe
How did you attach your light switches to the back of the dash? I wanted to just copy it, but I have factory air. I have a big vent hole where you attached you headlight switch. I made a bracket to bolt under the dash kind of like the panel you have that holds your A/C vent. I was also planning on using Vintage air. Is the A/C switch panel a new piece, or is it the 1972 panel?
1tonwannabe is offline   Reply With Quote
Old 08-15-2015, 07:07 PM   #197
Lazzardkng
All of the 2003 switches are held in with high quality 2 sided tape. You will have to do a little modification to the face plates of the switches so they sit flat on the back side of the dash.
The AC heat controls are stock. When you order your vintage air buy the kit that is for factory controls. It will come with the electronic actuators the stock controls.
Old 08-17-2015, 07:38 AM   #198
NastyBuzzard
NastyBuzzard's Avatar
Installed BOLT lock cylinder into door to use new style ignition key vice multiple keys.Attachment 1260278
What lock cylinder did you use for this? I am wanting to do something similar with my build but my donor came with no doors. However, from what I see the lock cylinder is actually in the handle portion. Is that what you used? You removed the lock cylinder from the door handle and installed in your door?
1988 GMC R3500- Cut Brothers 4WD Conversion Kit, 6.5 TD NV4500/NP208 D60 14BFF
2020 1500 Silverado 3.0 Babymax
2002 2500 Silverado- 6.6/ Allison
2010 CTS V- The "NastyBuzzard"
1979 Trans Am - Eventually getting 6.0/T56 swap with boost
NastyBuzzard is offline   Reply With Quote
Old 04-18-2016, 12:18 PM   #199
Farm Shop
Farm Shop's Avatar
I've read through this entire thread several times and every time I'm 110% impressed. Any updates?
1970 SWB 2wd C10, Vortec 454/80e, CPP 3/5, slotted mags, patina
1972 K20 Super Cheyenne, Short bed, EFI 396, NV4500, NP208
1970 GTO Judge, heads/cam LS1 & stalled 4L60e
Farm Shop is offline   Reply With Quote
Old 10-05-2016, 10:57 AM   #200
Bagd72Chevy
C10 Collector
Bagd72Chevy's Avatar
Updates?
///Ryan
1972 Chevy C-10-Bagged, Blown LT1, 700r4, Suicide Doors
1967 GMC- SC & Cam'd 4.8, built 4l80, 3200 stall, posi, 4.10
1967 Chevy LWB- 454 and patina
1971 Blazer - Rusty
1968 Crewcab project
Bagd72Chevy is offline   Reply With Quote
