Old 10-22-2014, 08:51 PM   #176
Xeen
Xeen's Avatar
Re: jimbosprint 1972 C20 - the good, the bad, and the ugly
Have you given any thought to replacing the damaged bedside?
I had made mention of it before but you didn't comment.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 10-22-2014, 08:57 PM   #177
jimbosprint
jimbosprint's Avatar
Yes, eventually. Going to make the truck mechanically sound before cosmetic repairs. Getting the bench seat re-done and fixing the fuel gauge take priority.
jimbosprint is offline   Reply With Quote
Old 10-23-2014, 07:57 PM   #178
jimbosprint
Some video of the new exhaust
http://www.youtube.com/watch?v=uRanr...ature=youtu.be
Old 10-23-2014, 08:55 PM   #179
Xeen
Xeen's Avatar
It looks and sounds good.
Old 10-24-2014, 01:14 PM   #180
jimbosprint
Not what I was hoping to find, but I just noticed some oil on the flywheel cover. Going to have to investigate a little further.
Old 10-31-2014, 08:37 PM   #181
jimbosprint
I have discovered my bench seat is not comfortable at all and must be fixed. I also discovered the seat cover I have is an upgrade "Deluxe" cloth trim option, and not readily available as a reproduction part. I thought about going with a stock repro cover from LMC or Brothers, but I don't think I want to sit on black vinyl on 105 degree summer days.
I sent this pic to SMS Auto Fabrics today, and they are shipping me some upholstery samples.
Old 10-31-2014, 09:39 PM   #182
litew8
litew8's Avatar
I did the same thing a long while back, contacted SMS and they sent samples.
Unfortunately, their samples didn't match my original's color like I had hoped.
Since yours is black in tone, maybe it'd be a perfect match.
Mine
SMS's (no gold flake and not parchment enough)
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 10-31-2014, 09:56 PM   #183
jimbosprint
Mine
What did it cost you to have the seat cover made? Was it done by TruckSeats?
Old 10-31-2014, 11:33 PM   #184
litew8
litew8's Avatar
Not a seat cover, original. I have a tear on the driver's side.
The camera picks up the dirtier spots but can't see it with the naked eye.
I decided not to try and recover it. I'll try and find a good slip cover instead.
Of course, I can't find one of those either (good quality). Might have one made.
Old 10-31-2014, 11:49 PM   #185
litew8
litew8's Avatar
Heck yeah, engine and exhaust looking real sharp
Old 11-01-2014, 12:02 AM   #186
litew8
litew8's Avatar
Originally Posted by jimbosprint View Post
Turned the key, got it to run smooth and the timing set pretty quick. Noticed quite a bit of smoke and shut it off.
Could have been the paint burning off. How's it running today?
Old 11-01-2014, 12:43 AM   #187
jimbosprint
Thanks, I'm very happy with the engine & exhaust. Runs good, no smoke. Just had to break it in.
The seat, brakes, and fuel gauge are at the top of my list of things to fix for now.
Old 11-02-2014, 05:40 PM   #188
jimbosprint
I unplugged the tan wire from the fuse panel and the fuel gauge moved past full, so I suspect the sending unit in the tank is probably the problem. Brothers has them on sale, so I just ordered one.
Old 11-04-2014, 08:28 PM   #189
jimbosprint
Ok, so here's my truck "to-do list" (not in any order):
** 23700 miles - change oil **
Try to make shifter work better
Fix instrument lights
Fix fuel gauge
Find local expert help to tune-up engine to ideal
Inspect/fix brakes
Replace shocks
Remove trailer brake
Replace fuel pump (just discovered I accidentally put on a big block fuel pump!)
Get seat reupholstered
Replace vinyl floor
Replace door window seals
Clean/service rear differential (see what gears are there)
Check trailer wiring
Old 11-05-2014, 05:04 PM   #190
jimbosprint
My truck has a working fuel gauge! The old float was full of gas, and the needle never moved. Now I can leave town if I have to!
Old 11-05-2014, 05:11 PM   #191
Xeen
Xeen's Avatar
Oh yeah a working gas gauge is a must have when going out of town.
I'm glad to hear it was something easy to fix.
Old 11-05-2014, 07:24 PM   #192
Jahloha
Jahloha's Avatar
Awesome build and thread! Loving the ram horns and crate engine, although premature, I am shopping crates as well.
-JASON
My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes.
My 1970 C20 Build Thread
Jahloha is offline   Reply With Quote
Old 11-05-2014, 09:26 PM   #193
rusty76
rusty76's Avatar
Cool truck. I really enjoyed reading about it. Keep at it.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 11-06-2014, 01:43 AM   #194
jimbosprint
Thanks rusty76 and Jahloha! It's been a fun project, I love driving it, and there's lots more to do still. I hope to someday take it completely apart for a full restoration.
Old 11-07-2014, 12:06 PM   #195
jimbosprint
I heard what sounded like some engine knock yesterday on a trip up to the disc golf course. I think I accidentally moved my timing with the air cleaner. I wish the air cleaner or distributor was just a tiny bit smaller because the bottom lid barely touches the closest plug wire on the HEI. I bent the air cleaner a bit to help, but it still touches.
I guess I'll have to be more careful in the future, and make sure the distributor is held down more securely.
Old 11-07-2014, 05:56 PM   #196
jimbosprint
So I don't think it was knocking. More likely this big crack in the exhaust manifold.
Old 11-07-2014, 06:32 PM   #197
rusty76
rusty76's Avatar
Well darn.
My build thread
Crossmembers CC
Old 11-07-2014, 07:10 PM   #198
jimbosprint
I'm gonna try the cheap ($46 shipped each) Ebay exhaust manifolds and see how that goes.
Old 11-10-2014, 12:59 PM   #199
jimbosprint
I replaced the driver side front brake rotor and pads yesterday. Gonna try to borrow an air compressor and impact gun for the passenger side to make taking the wheel off a lot easier. I'm sore from doing it by hand yesterday.
I'll post some pics after I get the other side done.
Old 11-10-2014, 04:11 PM   #200
Xeen
Xeen's Avatar
Being sore from work is a good thing it means you are building muscle, soon you will be able to do that work and it won't bother you, just eat protein after you work.
1972, c20, deluxe, stock
