Old 01-11-2015, 11:50 PM   #176
Advanced Design
Advanced Design's Avatar
Re: Cecil the 1953 5 window / S-10 / 5.7 TPI
Originally Posted by skymangs View Post
As requested, here's the pic of my balls... LOL. the one on the left is the resizing ball, the other 5 follow through to force the first one.
Lol...thanks! Looks like they worked pretty well.
Advanced Design is offline   Reply With Quote
Old 01-12-2015, 01:26 PM   #177
oossuuu754
oossuuu754's Avatar
SKYMANGS:
Finished the exhaust back to the muffler, dropped the tranny pan to install the kickdown cable and a new filter, put the torque converter bolts in, and finished up the shifter linkage today.
---Shawn
Cecil-1953 5 window build thread
Skymangs..Chris of Old Sarge customs had a shop fire and was severly injured. To help with the medical bills and expenses a fund has been set up here....http://gofundme.com/c49h5mjx8 More details are here...http://67-72chevytrucks.com/vboard/s...=1#post7253189
oossuuu754 is offline   Reply With Quote
Old 01-12-2015, 01:28 PM   #178
oldman3
oldman3's Avatar
Looking sweet...Jim
oldman3 is offline   Reply With Quote
Old 01-12-2015, 01:34 PM   #179
oossuuu754
oossuuu754's Avatar
SKYMANGS:Here's how she sits tonight. Tomorrow I want to fill some firewall holes, then set the cab on and bolt it down. This is the Final time it will go on!!!
Here is what Cecil sounds like with the exhaust setup https://www.facebook.com/video.php?v...type=2&theater
---Shawn
Old 01-12-2015, 05:33 PM   #180
oossuuu754
oossuuu754's Avatar
SKYMANGS:Worked on the firewall this morning. Lots of holes filled! This afternoon the cab goes back on.
Pic 2:That's 41 holes to fill... damn, and I do this once a month!
Pic 3&4: All finished and ready for paint
---Shawn
Old 01-12-2015, 06:38 PM   #181
oldman3
oldman3's Avatar
Engine sounds great, firewall looks good, nice job...Jim
Old 01-14-2015, 12:53 PM   #182
oossuuu754
oossuuu754's Avatar
SKYMANGS:
Firewall in paint, steering shaft finished up, and steering column removed to seam the welds on the Lower plate.
---Shawn
Old 01-14-2015, 12:56 PM   #183
oossuuu754
oossuuu754's Avatar
SKYMANGS:
I also finished wet sanding and paint on the back wall of the cab and installed the rear and corner glass.
---Shawn
Old 01-14-2015, 01:12 PM   #184
oldman3
oldman3's Avatar
Nice install on the glass, that can be a b**ch...Jim
Old 01-14-2015, 02:31 PM   #185
skymangs
skymangs's Avatar
Jim, thanks... the corner glass is easy, the one that sucks is the rear window. Fanned near impossible to do it without a second person on the inside. But eventually I managed it. Lol
skymangs is offline   Reply With Quote
Old 01-15-2015, 10:49 AM   #186
oossuuu754
oossuuu754's Avatar
SKYMANGS:
Today's progress was slow and tedious. Running boards are on for the last time.
---Shawn
Old 01-15-2015, 10:50 AM   #187
oossuuu754
oossuuu754's Avatar
SKYMANGS:
Dash repair complete, primed, wet sanded, primed again, and wet sanded one last time. Ready to shoot some flat black on it tomorrow.
---Shawn
Old 01-15-2015, 10:53 AM   #188
oossuuu754
oossuuu754's Avatar
SKYMANGS:
Pic 1,2,3 Passenger side power window installed and functional. I still need to get run channels in it, and work on the drivers side tomorrow.
Pic 4. Shawn really liked the look of the brushed steel on the column. I just sprayed it in satin clear to keep it from rusting. Once the dash is in paint, i'll start working on the stereo and wiring.
---Shawn
Old 01-19-2015, 10:27 AM   #189
oossuuu754
oossuuu754's Avatar
SKYMANGS:
Passenger side power window all finished up
---Shawn
Old 01-19-2015, 10:28 AM   #190
oossuuu754
oossuuu754's Avatar
SKYMANGS:
Electric wiper motor conversion installed
---Shawn
Old 01-19-2015, 10:30 AM   #191
oossuuu754
oossuuu754's Avatar
SKYMANGS:
This is the insert I made to install the radio begin the origins speaker grill
---Shawn
Old 01-19-2015, 04:59 PM   #192
oossuuu754
oossuuu754's Avatar
SKYMANGS:
This is the stand alone engine harness routing and the ECM placement behind the dash.
---Shawn
Old 01-19-2015, 05:02 PM   #193
oossuuu754
oossuuu754's Avatar
SKYMANGS:
Now we are moving along on the body harness wiring! Pic 1,2,3
Pic 4, This is the unused wires yhat got pulled before the harness ever got near the truck. Over 100ft!
---Shawn
Old 01-19-2015, 07:35 PM   #194
Advanced Design
Nice work and great detail! Really like the radio behind the grill too. Wondering which power window product you used?
Thanks for sharing.
Old 01-19-2015, 11:33 PM   #195
skymangs
skymangs's Avatar
Thanks AD. I use ez wiring's power window kit (universal). It is relatively in-expensive, straight forward design, and works quite well in these doors. Just enough travel to fully close the window, yet allow it to open far enough to be below the trim when the window is down.
Old 01-20-2015, 03:13 PM   #196
oossuuu754
oossuuu754's Avatar
SKYMANGS:
Engine wiring finished up today. Now on to those accessories!
---Shawn
Old 01-20-2015, 03:18 PM   #197
oossuuu754
oossuuu754's Avatar
SKYMANGS:
Cecil was missing all the accessory brackets so I purchased a 1991 Camaro Engine for $150 and salvaged all the parts I could. Here's the before and after of the Dona Camaro. I stole everything, including the water pump.
---Shawn
Old 01-20-2015, 03:23 PM   #198
oossuuu754
oossuuu754's Avatar
SKYMANGS:
After hours of cleaning and painting, the front end of the motor is together. Notice I had to change the water pump... The 87 had a normal flow pump, while the 91 had a reverse flow. Everything fit like a glove. In order to delete the smog pump and clear the K&N air filter I had to re-route the serpentine belt, while keeping all the pulley's spinning the right direction.
---Shawn
Old 01-20-2015, 04:30 PM   #199
oldman3
oldman3's Avatar
Looks sweet, nice clean up on the parts...Jim
Old 01-21-2015, 08:00 PM   #200
tlorber
tlorber's Avatar
I'm shocked that Chris does in 2 days what has taken me the better part of a year to do-and I have nowhere near the rust that most of his builds have.
Really nice to see.
tlorber is offline   Reply With Quote
5 window, 5.7 tpi, chevy truck, rusto mod, s-10 chassis swap
