Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > LSx Classifieds
Old 04-27-2016, 08:23 PM   #176
BustedTruck
BustedTruck's Avatar
Re: DBW Gas Pedal Adpater bracket for truck/suv pedal
Great product! I've only got one issue. The throttle is a good inch above my brake pedal, but my brake pedal is not on the rest. My question is with power brakes does the brake pedal rest against the stop?
BustedTruck is offline   Reply With Quote
Old 04-27-2016, 09:04 PM   #177
Hart_Rod
Hart_Rod's Avatar
How far off of the stop is it? I think it should rest again the stop regardless of power or not, at least all of mine have.
Hart_Rod is offline   Reply With Quote
Old 04-27-2016, 10:00 PM   #178
BustedTruck
It's got a good inch before it touches the stop. Do you think there is that much adjustment in the rod?
Old 04-30-2016, 03:25 PM   #179
BustedTruck
Looking back through this thread most of the pictures show the brake pedal higher. Here is one a little furthur back in this thread shows what mine looks like.
Old 04-30-2016, 03:36 PM   #180
BustedTruck
Here is what mine looks like. I took it loose & tried to adjust it back some. I made about 5 full turns and the end fell off in my hand. So it looks like there isn't enough adjustment there to make it come close to touching the stop. You can see where I cut the pedal & tried to make it work then welded it back.
Old 05-02-2016, 08:19 AM   #181
Hart_Rod
Hart_Rod's Avatar
I would try to figure out a way to lengthen the brake pedal rod as it should really be resting on the stop. Your local hardware store should have some all thread and couplers to help you accomplish this.
Old 05-02-2016, 08:54 PM   #182
tony2tall
Hi Rob.
I bought your pedal bracket a while back and have gotten around to installing it today. It seems that the pattern for mounting to the firewall is off.
Assuming the orientation in the picture is correct (other than the picture is 90 degrees counterclockwise), my actual holes in the truck are 1.50 between the top holes and 2.00 to the bottom one.
Not sure whats up but, no big deal, I'll take it to work tomorrow and just slot the holes.
tony2tall is offline   Reply With Quote
Old 05-03-2016, 11:30 AM   #183
Hart_Rod
Hart_Rod's Avatar
Originally Posted by tony2tall View Post
Hi Rob.
Tony - it looks like your firewall has the 73-87 pedal bolt pattern. Just use the bottom hole on the triangle and redrill the top two holes. Sorry for the inconvenience.
Rob
Old 05-03-2016, 06:11 PM   #184
tony2tall
No problem. Strange that my 71 would have a different pattern, but oh well. It will still save me a bunch of time and fabrication!
Old 05-04-2016, 02:23 PM   #185
Hart_Rod
Hart_Rod's Avatar
It is odd, but I've seen about 4 or 5 of them. Luckily it's an easy fix, .
Rob
Old 05-22-2016, 05:46 PM   #186
yeahsee
Do you have any brackets available? I need one.
Thanks!
yeahsee is offline   Reply With Quote
Old 05-22-2016, 06:41 PM   #187
Hart_Rod
Hart_Rod's Avatar
Thanks!
Yes I do! Paypal info in first post. Thanks!
Old 05-22-2016, 06:55 PM   #188
yeahsee
Payment on the way. Thank you.
Old 05-24-2016, 09:09 AM   #189
Hart_Rod
Hart_Rod's Avatar
Thanks! Shipped today via USPS!
Old 05-25-2016, 03:50 PM   #190
FarmerSid
FarmerSid's Avatar
I'm fitting my DBW gas pedal in my AD. It's the same as in the pic. It is comfortable to have the gas pedal ahead of the brake pedal. Mines looking the same in order to get full travel.
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 08-27-2016, 09:56 PM   #191
Hart_Rod
Hart_Rod's Avatar
bump!
Old 09-15-2016, 08:12 PM   #192
68C10LQ9
Sir, I would like to order a pedal bracket please.
Chris
68C10LQ9 is offline   Reply With Quote
Old 09-15-2016, 08:15 PM   #193
Hart_Rod
Hart_Rod's Avatar
Chris
No problem! PayPal is robhartley@aol.com, $100 shipped. Thanks!
Old 09-15-2016, 08:25 PM   #194
68C10LQ9
Smile Re: DBW Gas Pedal Adpater bracket for truck/suv pedal
Money sent...thanks
Old 09-15-2016, 09:39 PM   #195
Hart_Rod
Hart_Rod's Avatar
Money sent...thanks
Thank you! It will ship via USPS tomorrow. Take care.
Rob
Old 09-15-2016, 11:48 PM   #196
AustinBelair
Man, do you have ANY way to make a 97-04 Corvette pedal to work in a 66 C10?
My mother is a recent cancer survivor and this truck build is for her
AustinBelair is offline   Reply With Quote
Old 09-16-2016, 09:02 AM   #197
Hart_Rod
Hart_Rod's Avatar
Please post pictures of the pedal and the firewall.
Old 10-19-2016, 09:33 PM   #198
michael bustamante
michael bustamante's Avatar
Hey bud.. I FINALLY got around to xtrying to get the pedal in. I had cherry insulation. Kinda hurt to cut it! Lol
Anyways has anyone mentioned havng to notch the bracket for the taillight plug? No biggie just wanted to mention it. Thanks again rob.
Early production 67.
1967custom
michael bustamante is offline   Reply With Quote
Old 10-20-2016, 09:00 AM   #199
Hart_Rod
Hart_Rod's Avatar
No one has mentioned that Michael, I wonder if the 67 plug is in a different location then the 68-72?
Old 10-21-2016, 10:59 AM   #200
michael bustamante
i made the cut larger than it had to be but after i did that it worked perfect. i wouldnt doubt the plug location being just a bit lower on a 67.
1967custom
