Old 05-06-2015, 09:06 PM   #176
65sub
65sub's Avatar
Re: My suburban's Twisted Little Sister
Had a few days off but we're back now. We spent some time with the hammer and dolly on the weld. Then we fit the wheel opening panel
Dale
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 05-06-2015, 09:42 PM   #177
Advanced Design
Advanced Design's Avatar
Nice work on the seam. That takes a lot of time.
Advanced Design is offline   Reply With Quote
Old 05-06-2015, 10:51 PM   #178
hotrod66
hotrod66's Avatar
Looking good .What's the plan on the front end leaving stock or lengthen it?
Between saying and doing many a pair of shoes are worn out
hotrod66 is offline   Reply With Quote
Old 05-09-2015, 03:22 PM   #179
65sub
65sub's Avatar
Thanks A.D.
Thanks hotrod. On the front I had considered moving the engine back into the firewall but I didn't want to hide it. The only other way to fit the V12 in was to move the front wheels ahead about 9". I still haven't got all the sheet metal on the front figured out yet but that can wait until we get farther along.
We got started on the spot welding. We also did some more hammer and dolly work on the rear of the driver side.
Dale
Old 05-11-2015, 08:56 PM   #180
65sub
65sub's Avatar
Here's a couple of shots of the passenger side wheel opening panel all welded. And a couple more of the drivers side fit in and the tacks started.
Dale
Old 05-13-2015, 09:21 PM   #181
65sub
65sub's Avatar
We finished the welding on the drivers side except for the hole left by the gas door. So we made a patch and tack it in place.
Dale
Old 05-13-2015, 09:27 PM   #182
65sub
65sub's Avatar
We also got the wheel tubs painted with POR15
Dale
Old 05-13-2015, 10:26 PM   #183
Advanced Design
Nice work 65sub!
Old 05-23-2015, 09:32 PM   #184
65sub
65sub's Avatar
Nice work 65sub!
Thanks A.D.
I got a little busy this week but we did manage to get some work done. First we tacked the inner fenders in place then finish welded the top section
Dale
Old 05-23-2015, 09:36 PM   #185
65sub
65sub's Avatar
We also got the frame painted with POR 15
Dale
Old 05-23-2015, 10:06 PM   #186
rusty76
rusty76's Avatar
The work here just blows my mind.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 05-24-2015, 09:36 PM   #187
65sub
65sub's Avatar
Thanks rusty I'm glad you're enjoying it.
On friday we decided it would be easier to weld the bottom of the inner fenders with the truck flipped on its end. So we cut the top of the door frame since it will have to cut soon anyway. Mother Nature had already separated the rocker panels and the floor. Then we lifted off the firewall and windshield and set the back section on its end
Dale
Old 05-24-2015, 10:02 PM   #188
65sub
65sub's Avatar
Once we got the back section on its end we started making pieces to connect the inner fender. We also pushed the old frame out to the junk pile that will go for scrap.
Dale
Old 05-28-2015, 08:14 PM   #189
65sub
65sub's Avatar
I have a bunch of pictures to upload so this will take a few posts. First are some shots of the top of the windshield frame in the corners. Also a picture of flipping the frame up to paint the bottom.
Dale
Old 05-28-2015, 08:22 PM   #190
65sub
65sub's Avatar
This post shows the body going on the frame and then being levelled
Dale
Old 05-28-2015, 08:28 PM   #191
65sub
65sub's Avatar
After a bit of fine tuning on the body we started welding the body to the frame.
Dale
Old 05-28-2015, 08:48 PM   #192
pimpston65
pimpston65's Avatar
my daily crack!!! keep it coming...
pimpston65 is offline   Reply With Quote
Old 05-30-2015, 07:15 PM   #193
65sub
65sub's Avatar
First time's free! Lots more coming
Well we got so tired of moving the huge roof around that we decided to skip ahead and chop the top so we can put the roof back on. We started by carefully measuring 4" on all the pillars. Then after careful study we decided it wasn't enough and marked them again at 5". Then there's nothing left but the cutting.
Dale
Old 05-30-2015, 07:19 PM   #194
65sub
65sub's Avatar
I also included pictures of the inside structure of the A, B and C pillars.
Dale
Old 05-30-2015, 07:51 PM   #195
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
looking cool!
when I chopped the top on my 61 I removed the inner trim panel so that I could access the center part of the pillar to weld that up
Old 05-30-2015, 07:55 PM   #196
jonzcustomshop
1961 crewcab
.. and when I put a new cowl on my 64 sub I did it like this:
Old 05-31-2015, 08:00 PM   #197
65sub
65sub's Avatar
Thanks for the pictures Jon. I will be cutting access holes on all 6 pillars to allow welding of the inner structure. After the pillars get welded all of the cross bracing will have to be extended. Then comes cutting the roof to fit. We sure are using up a pile of cutting and sanding disks.
Dale
Old 06-01-2015, 08:42 PM   #198
65sub
65sub's Avatar
Today we started fitting the top half of the pillars. the last two pictures show the alignment issues with the C pillar
Dale
Old 06-03-2015, 09:45 PM   #199
65sub
65sub's Avatar
We took a break from the project today to change the valve seals on the 409 in my daily driver plus a couple of other small repairs.
Dale
Old 06-08-2015, 08:27 PM   #200
65sub
65sub's Avatar
We took another short break to repair a leaking lower rad hose on my suburban today. Then we started tacking the tops on the pillars. First the outside of the B pillar then on the inside we removed the top of the inner panel for access. The rear pillar needs so much modification that there are only a few places to tack. Aligning the window frame required a small relief cut before we could start tacking.
Dale
