08-08-2016, 11:19 PM | #176 |
Re: 67-72 cross members
Sorry 68 K10 engine crossmember and engine brackets for smallblock chevy shipped to 15668. Thanks Rich
08-09-2016, 09:51 AM | #177 | |
Hey man 67 GMC Short Stepside 400 small block, turbo 350. Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=650603 |
08-09-2016, 10:56 AM | #178 |
Oregon 67, no havent had any luck, im kind of in a bind need to get motor back in my kids truck. Sorry
10-02-2016, 10:50 PM | #179 |
looking for small block 350 engine crossmember and engine brakets for 71 GMC K15. Shipping to 83646.
Thanks 18Z |
10-04-2016, 04:14 AM | #180 |
Do you have upper rear shock mounts for a 68 4x4?
10-04-2016, 11:28 AM | #181 |
Sorry i have nothing for sale, was looking for a crossmember and sourced one from a local board member
10-04-2016, 12:57 PM | #182 |
The OP has not logged on to this site since May...
Jimmy Hoelzel |
10-05-2016, 09:30 AM | #183 |
Tom the OP says very busy with his business right now and is generally active on the board in the early part of the year. You can google DLTruck and call his parts department if you need something and they will work with you to get what you need. If you are in a hurry then you may want to try other alternatives. I personally have found them to be helpful.
1968 C10 292/3 spd - sold 1969 K10 350/3 spd/205 - sold 1971 K5 350/4 spd/ 205 - sold 1970 K20 350/350/205 - sold 1969 K20 396/400/205 - work in process |
10-21-2016, 03:49 PM | #184 |
Would you have a complete set of rails to change a SWB from steel floor to a wooden floor?
Thanks Eddie |
12-19-2016, 07:29 PM | #185 |
do you have one?
very rear cross member (has hole for tail light wiring harness) 4x4 thank you -rex |
12-19-2016, 09:00 PM | #186 |
I need the 4x4 cross member that mounts to the top and bottom of the frame rails for a 1972 blazer and the transfer case skid plate if you have one. The blazer has a 205 with an automatic. shipped to 85086. Thanks.
12-26-2016, 11:38 PM | #187 |
12-27-2016, 02:31 PM | #188 |
I have a 1968 K10 with A/T. Do you have a xmember for the rockwell transfer case.
Roger Koop |
03-22-2017, 11:00 PM | #189 |
Hello I'm looking for a rear crossmember to mount shocks on a 69 C10 short bed I have leaf springs and converting to railing arms shipped to 85037 thanks
03-23-2017, 06:27 AM | #190 |
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
04-29-2017, 05:17 PM | #191 |
Stock 1972 gmc jimmy 4wd suspension
I have a 1972 gmc jimmy 4wd. I am trying to find stock 1/2 ton leaf springs, leaf spring hangers, and shackles for the front and rear. Do u have any? Shipping would be to 02631 thanks
05-03-2017, 12:34 PM | #192 |
I need a rear cross member for my 67 C10 short step.
Glenn 1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca 1929 Ford Model A Roadster - traditional pre-war banger hot rod |
05-03-2017, 01:01 PM | #193 |
Have a 4x4 frame and axles. Tried to send you a private message but cant.
05-03-2017, 01:53 PM | #194 |
Any clean 2wd 3-4spd manual x members out left? Thanks
website https://www.villagegarage.com/ truck guy in the whiskey world https://www.instagram.com/c10glen/?hl=en https://www.hemmings.com/stories/car...e-perfect-day/ |
05-03-2017, 02:47 PM | #195 |
He hasn't been on here since 5-24-16 !
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
05-03-2017, 05:50 PM | #196 |
I called them directly:
D & L Truck Parts www.dltruckparts.com 91720 Highway 99 S, Junction City, OR 97448 (800) 231-2603
05-07-2017, 05:36 PM | #197 |
05-07-2017, 11:51 PM | #198 |
They have them in stock. I ended up straightening mine.
05-09-2017, 06:01 PM | #199 |
Originally Posted by Krex View Post do you have one? very rear cross member (has hole for tail light wiring harness) 4x4 thank you -rex Didn't get a response.. lmk thank you Are you saying you have the cross member in stock? Also, would you happen to have the rear horns basically from the rear leaf spring mounts back for a 4x4? |
07-10-2017, 05:24 PM | #200 |
Looking for a set (left and right) of the rear upper shock mounts from a leaf spring/4X4 truck. Mounts are inside of the frame rails, 3 rivets holding to frame.
Thanks |
