02-19-2016, 09:39 AM | #176 |
Re: Project U S Army Sargent Slam
Looks super...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
02-20-2016, 01:07 AM | #177 |
Capped my front frame rails today. Had to cut them a little further back then I really wanted to. The previous owner didn't cut the frame rail very straight to begin with, but it won't hurt anything. First pic is before
02-20-2016, 01:08 AM | #178 |
After. Just have to do the radiator support bracket.i think I am going to use a L bracket on each side.then weld the bottom to the frame and bolt the top to the radiator support.
02-24-2016, 11:34 PM | #179 |
Bought premade brackets at the hardware today fot the radiator support. Just had to cut them down a bit.
02-24-2016, 11:36 PM | #180 |
Marked the inner fenders so I could use the plasma.
02-24-2016, 11:37 PM | #181 |
After the cut
02-24-2016, 11:39 PM | #182 |
Drilled holes for bolts in radiator support and mounted it back up
02-24-2016, 11:50 PM | #183 |
Welded and painted the brackets to the frame and bolted the upper bracket to the radiator support. The welds are solid I will clean them up when I strip the frame to powder coat it.To me it turns out a lot cleaner this way and you don't have any cross braces getting in you way. The brackets are also ovaled out so they have some adjustability.
02-26-2016, 03:52 PM | #184 |
Looking great, looking forward to a video of that beast rolling on the street!
03-05-2016, 01:20 AM | #185 |
Got a 47-48 fuel inlet tube, grommet and gas cap today.
03-05-2016, 01:21 AM | #186 |
Used the plasma to cut a 2 3/4 home for the filler grommet.
03-05-2016, 01:22 AM | #187 |
Grommet fit perfectly
03-05-2016, 01:23 AM | #188 |
Filler neck installed
03-05-2016, 01:26 AM | #189 |
Top view. Just need to get a longer filler hose
03-07-2016, 03:18 AM | #190 |
that is looking so good!
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years. 96 ECLB 2500, 6.5 diesel, auto, gone. |
03-17-2016, 11:02 PM | #191 |
Took about 5 hours to get all the belts and brackets to line up. I had to be the one to run power steering and a/c on a blown motor. Still don't like the angle of the power steering fill neck.so I need to get a shorter belt. Next is plumbing the radiator hoses, fuel pump and fuel line. Then I will fire it up again and set the timing.
03-17-2016, 11:21 PM | #192 |
Wild thang..
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
03-23-2016, 01:37 AM | #193 |
Mounted the upper radiator hose. The space was so limited near the water neck because of the blower I had to use a flexible stainless radiator hose.
03-23-2016, 01:42 AM | #194 |
Couldn't use the billet radiator clamps on the Lower radiator hose because of the limited belt room. Hope they hold, I have never used radiator hoses like these before.
03-23-2016, 01:44 AM | #195 |
Overflow tank
03-23-2016, 10:01 AM | #196 |
Man, looking good!
1969 Chevy C10 SWB 350/400 4"-6" drop on steelies 53' Chevy 3100 5 window http://67-72chevytrucks.com/vboard/s...d.php?t=660793 http://67-72chevytrucks.com/vboard/s...d.php?t=771679 |
03-25-2016, 12:25 AM | #197 |
Got the fuel line and the pre and post filters installed
03-25-2016, 12:28 AM | #198 |
To the tank. Had to plug off 2 of the 4 lines going into the tank. Only needed the vent and the pick up tube.
03-25-2016, 12:38 AM | #199 |
Going to run the battery in the bed. Just need to install the battery shut off on the side of the bed. Need to pass tech because I am planning on doing a little racing at the local drag track
03-25-2016, 06:12 AM | #200 |
Great build. Love the wheels and speed in which you are building!! dug
My Build - http://67-72chevytrucks.com/vboard/s...d.php?t=515876 |
