12-27-2020, 08:57 PM | #176 |
Re: My winter project
I did some panel alignment before I cut and weld the door skins
Just for the fun of it |
03-20-2021, 04:59 PM | #177 |
It's running good and I drove it a bit, how time flies.
04-09-2021, 11:05 PM | #178 |
I decided to stay away from welding the door patchs because I'm not much of a welder. I used a panel step tool and adhesive to glue the door patch skins together. I will use a tack weld in a couple of spots when I fold the edges over.
Just for the fun of it Last edited by 7D2N; 12-04-2021 at 09:53 PM. |
04-10-2021, 07:57 AM | #179 |
Nice work! Truck is looking great, almost done?
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
04-11-2021, 08:10 PM | #180 |
2WD Jimmy
. I like the adhesive idea..
04-14-2021, 08:21 PM | #181 |
Thanks, guys. I thought I would have been a lot further down the road on my metal repair but door repairs have taken me a ton of time. Put doors on then take them off, line this up with that then do it again and again.
04-14-2021, 09:42 PM | #182 |
Looks great!!!
Full top blazer or bust.... |
05-26-2021, 07:45 PM | #183 |
More rust repair, this time in the bed. Send in the donor.
06-04-2021, 10:23 AM | #184 |
You're doing a great job. Keep at it! Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
07-07-2021, 09:52 PM | #185 |
I have the donor bed pieces prepped to go in and there is still a bunch of work ahead.
07-08-2021, 01:22 PM | #186 |
Active Member
Nice work...Want to sell the donor tail gate?
07-11-2021, 08:45 PM | #187 |
Thank you. Starting the inside cutting.
K5, not at this time.
07-11-2021, 09:06 PM | #188 |
A lot of cutting and welding will be coming so protecting the front.
07-22-2021, 09:56 PM | #189 |
I found there is a lot of spot welds holding these pieces together. I had to be real careful cutting the welds on the inner wheel lip and outer skin.
07-23-2021, 11:24 AM | #190 |
Active Member
Great work..
07-24-2021, 12:37 PM | #191 |
Wow, that pile of shrapnel really tells the story. How did it drive? It sure looks good. Thanks for telling about the build process and posting pictures. I actually can relate a lot more to a build like this than the custom ones.
08-17-2021, 10:58 PM | #192 |
Patching the tailgate/bed floor area.
08-18-2021, 09:38 PM | #193 |
Wheel tubs are undercoated and painted.
08-19-2021, 11:19 PM | #194 |
2WD Jimmy
Keep at it. 👍
08-26-2021, 09:40 PM | #195 |
I have the wheel tubs in and the floor painted, a lot of time for what seemed like a little rust repair.
09-02-2021, 09:06 PM | #196 |
I have the fuel tank ready to go in and checking the length of the vent and fuel lines. I will need to put some on before the tank is in place. I did get a real dress-up kit.
09-20-2021, 10:59 PM | #197 |
New/old dress-up kit installed, pretty sure I lose some horsepower from removing the chrome/painted stuff but things we do.
10-09-2021, 05:17 PM | #198 |
Well after recovering from the shock of my paint job quote I decided to work on the refurbished parking lenses I got from a board member and all installed.
Just for the fun of it Last edited by 7D2N; 10-17-2021 at 06:57 PM. |
10-16-2021, 11:26 AM | #199 |
2WD Jimmy
Where did you get the quote on paint?
10-16-2021, 01:38 PM | #200 |
Hi Tom, I got the quote from a shop that has been around for years and I have had them do a lot of work for me from full paint down to accident damage. They want to take the blazer down to bare metal for warranty purposes, I can understand that since their name is on it but 25k + is just a bit steep for me. Maybe I will have to learn paint.
