Old 03-15-2016, 01:33 AM   #176
Transam461
Re: FITECH EFI 600 Basic and Command center intall with pics, factory tank
In reality, they both SHOULD adjust by just turning the front screw, since the linkage on these throttlebodys are setup for 1-1 operation of the primary and secondary butterflies , instead of being progressive, but it's a possibility for the linkage to still have a slight movement of the primary butterflies before it starts to move the secondaries, just simply from the little play that's in the linkage rods, or some may not be adjusted exactly perfect. Ours seemed to have just a tiny bit of play, it wasn't very much at all though. That's the reason I always recommend to adjust the primary and secondary screws evenly.... I hope this helps
Brian
Transam461 is offline   Reply With Quote
Old 09-19-2016, 11:16 AM   #177
AnotherWs6
AnotherWs6's Avatar
Wondering if there are any updates. How do you feel about the system now that you have had it on for an extended period? I'm on the fence about. Certainly a lot of good [I]potential[I] things about it. I have seen people having problems with the Fuel Command Center, have you had any?
1968 C-10 Suburban - Original 396/TH400
2002 Transam WS6 - M6 - Black/Black - Evil Garage Queen
2000 Silverado - DD - Small lift+Body lift+35" Duratracs+4.88's + Eaton TruTrac - Monster Truck
2010 Cadillac CTS Wagon Sport - Wife's DD and the only classy car we have.
AnotherWs6 is offline   Reply With Quote
Old 09-19-2016, 11:48 AM   #178
steveo3318
steveo3318's Avatar
I had some issues with the FCC one time it got hot from sitting at idle and shut down on me but once it cooled it hasn't done it again. They did have me lower a fuel psi parameter as well at idle. My unit was one of the first and being a controls programmer I expected bugs. I had a failure of the ecu sending the injector a fuel pulse signal. Causing two whole cylinders to be starved. The truck ran and operated great but was weak and would bog. The system corrected as much as it could only using 3 injectors and got me home. I sent the throttle body back and they confirmed ecu took a dump on that injector. They sent me the new and improved throttle body with the newer bug fixes and larger power wires and fuel pump wire.
All this being said the new system is night and day difference. Starts better runs better. Feels like more hp. And I have not had a single issue. The guys supported me through all the issues and I am very happy. I feel safe to say they have got the bugs fixed now and when I get my 65 mustang fastback ready I will put the same kit on it. I am happy.
1967 c10 3OTT with R10 overdrive.
385 Stroker, 373 posi
FITECH EFI, Vintage air, York 210 OBA,
4/6 drop with riddler 20x8 and 20x10
1957 S5T Leslie Supertyfon train horns and EMD bell
"No bolt left unturned"
steveo3318 is offline   Reply With Quote
Old 09-20-2016, 11:21 AM   #179
Big Kev-O
Big Kev-O's Avatar
Hey Steveo how exactly did you determine you had "a failure of the ecu sending the injector a fuel pulse signal"? Did the controller indicate a fault? I have the same FiTech setup and my truck recently started running a bit rough. I had initially suspected my cheap chinese MSD HEI or a intake manifold leak but after reading your post it got me thinking about my EFI. Thank you.
Made in America by Americans
Big Kev-O is offline   Reply With Quote
Old 09-20-2016, 11:36 AM   #180
steveo3318
steveo3318's Avatar
I did the same thing. It ran like my Msd or distributor was taking a dump but after I checked all plugs firing and not breaking up I started looking at fuel. I simply looked down the throat of the tb and seen one whole port was dead and not squirting fuel. I swapped the injector thinking it was bad but it didn't leave that port so I knew it was signal. I then put my meter on it and seen it was not outputting a signal. Injectors was fine. The funny thing is when I data logged a pull it showed the truck was running fine of afr and fuel because the system was strong enough to correct the issue afr wise but I was about a 100hp down. Basically driving a V6. Hope this helps
Old 09-20-2016, 11:39 AM   #181
steveo3318
steveo3318's Avatar
Absolutely no faults on the system. They said it was the first they seem!
Look down the tb with it running with a flashlight. If one is dead you will see it not squirting the ring or weak. Before calling them swap it with the injector right beside it. If it's squirting good start with timing.
Old 09-20-2016, 02:20 PM   #182
snj8198
snj8198's Avatar
Hi Steveo,
I see that you used your existing dual plane intake and added an open phenolic spacer. Can you comment on your reasoning behind it's use please? If the divider between the intake plenums was cut down half to full inch would you have still used the spacer?
Also, have you ran into any supporting data that suggests a dual or single plane intake works better with the FITech unit?
Steve
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 09-20-2016, 03:11 PM   #183
steveo3318
steveo3318's Avatar
I had the plate on my carb setup for heat soak. I knew the efi didn't need it but knowing the ecm is on the tb I figured it wouldn't hurt to keep the heat off. Plus all my linkages where set up with the spacer so I figured why not. Not real reasoning behind it other than those and I like the taller carb look.
Now the single or dual intake is a hard one and prob best answered by someone else. Mine is an older Holley that is completely open right to the tb. In other words no divider. I feel like the dual plane is best suited for my needs for low end torque considering it's a truck and not a race car and rarely sees 6500 Rpms. But it does pull hard to 6500. I also feel that the open plenum is the main reason I didn't hurt two cylinders when that injector stopped firing. In a single plane it would of starved those two cylinders even at idle where my truck ran fine at idle and low Rpms. Again this is just opinions.
Old 09-20-2016, 03:40 PM   #184
snj8198
snj8198's Avatar
Thank you for the info. I'm currently installing the same system on my 489 and am using an Eddie Air Gap dual plane which FITech assures me that the efi will work fine with. During my research I found some instances of the dual plane intake divider and port walls blocked the spray pattern resulting in some stumbling and performance issues. I think it's best that I just perform the install as is with the dual plane and deal with any issues later if they come up.
Steve
Old 09-20-2016, 04:39 PM   #185
steveo3318
steveo3318's Avatar
Yes the system is pretty robust in making its own corrective measures. If you feel one bank is leaner than the other just order a second o2 bung and swap the sensor and see if it changes any. Or run a seperate o2 sensor on the other bank like I do anyway to make comparisons. I do wish fitech would of made the system with two o2 sensors that averaged the data in logic yet still have seperate read outs.
Old 09-20-2016, 05:01 PM   #186
AnotherWs6
AnotherWs6's Avatar
Agreed that a 2 O2 sensor system would be much better. I have to assume this was not done due to cost and complexity. This is not a multiport system so think about it..... If it is reading that one side is spot on while the other side is lean and it is averaging the two readings it is going to sense a mild lean condition. Then it is going to compensate by adding more fuel. Then it is going to see that lean bank get corrected while the bank that was running good already goes rich, which is going to want to make it pull fuel and then you're back where you started.
snj8198 - An open spacer may help mitigate problems. Also, grinding down the divider or both. You're messing with how your manifold was originally designed to work, but it may be worth it. Aside from stumbling, etc issues, I like the fact that the system was able to compensate when steveo lost an injector. Depending which bank it was on he could have easily lost a motor if his intake was completely divided.
Old 09-20-2016, 05:08 PM   #187
steveo3318
steveo3318's Avatar
I program for a living. Building the average block logic and viewing the 2o2 sensors separately would not of been hard at all considering the other logic and pids the system already has. Build a parameter to use one or two o2s and build another side loop watching differential of the two. If they get to far apart throw a code and start checking sensors then injectors and on and on. You could essentially use it like a multiport adding fuel to either bank that needed it just not each cylinder. That on the other hand would be duplicating the first control of the o2 and making them seperate yet work in conjunction for overall outcome. Lol
Old 09-20-2016, 05:12 PM   #188
AnotherWs6
AnotherWs6's Avatar
But you would have to ensure that there were separate banks to begin with. Which means that all the people with single plane manifolds are out. It would be limited to divided dual planes. How else would you create separate banks? And now the "you can throw this on anything with a carb easily" goes out the window. Cost and complexity, cost and complexity. I'm sure they weighed the options.
Old 09-20-2016, 05:17 PM   #189
steveo3318
steveo3318's Avatar
I agree completely. But I think it would only work on single planes. Not dual. A dual feeds both banks from each side. A single feeds one bank from one side. Is that correct???
Old 09-20-2016, 05:28 PM   #190
AnotherWs6
AnotherWs6's Avatar
My understanding has always been that a dual feeds from the opposite side of the bank which would mean that it would only work on duals. A single plane is essentially an open plenum. The dual planes cross over the engine in order to lengthen the runner. Long, narrow runners = low end torque. Short, wide runners (direct shot at heads) = high rpm power.
The picture of this Edelbrock Super Victor illustrates the idea well. Each cylinder is being fed with the shortest path to the carb as possible. No twists and turns, crossing over etc. Now what would happen if you put a divider right down the middle of that thing to create two banks?
Old 09-20-2016, 05:33 PM   #191
snj8198
snj8198's Avatar
Thanks, the Edelbrock RPM air gap does have the divider ground down about 3/4". I have the same 1" spacer as Steveo as well to play with.
I think for starters it will be a good idea to get the system mounted, running, and get some miles on it to see if any problems arise before making modifications if any are necessary.
Thanks for the info guys, all good stuff. Should be up and going in a couple days.
Steve
Old 09-20-2016, 05:37 PM   #192
steveo3318
steveo3318's Avatar
Ahh. I smell what your stepping in. The only way it would work correctly is a single plane with a divider. A dual plane still feeds both banks off one side
Old 09-21-2016, 08:47 AM   #193
AnotherWs6
AnotherWs6's Avatar
Gotcha. I was halfway close with my dual plane thought process, lol. So divided single plane. And that means a newly designed intake manifold, which begins the whole cost increase thing. Plus the extra O2 and wiring. More complex programming. FItech's niche seems to be simple/easy, inexpensive, no major mods needed.
That being said, monitoring and tuning based off of one bank is leaving a major hole unplugged. But if everything is working correctly it SHOULD work just fine.
Old 09-21-2016, 09:56 AM   #194
steveo3318
steveo3318's Avatar
Yes we were both half way there. Maybe we should build our own system with an intake. Lol.
To solve the single bank o2 hole you can always do what I am doing. I am running a seperate afr gauge on that other bank. All I am doing is using it to make comparisons against the fitech. They stay fairly close to each other. Now if I have an injector fail I should see the bank it failed on. it's just a cheap innovative gauge and o2 I have had for years that I used to tune my carbs. I keep it hid under the dash until I want to make comparisons I just pull it out.
Old 09-21-2016, 10:06 AM   #195
AnotherWs6
AnotherWs6's Avatar
Lol.
What you're doing makes sense, especially if you have the extra gauge and sensor laying around. I bought a new carb 6 months ago and then ordered a pair of 02 sensors and gauges along with a bunch of other stuff 6 weeks ago. THEN I came across Fitech. For the price of all this stuff I could have fuel injection???? I sent it all back thinking I can put that money towards the FI and sell the carb afterwards. That's how I came across your thread, researching. But I'm not totally convinced now, going to wait a while and see. In the mean time I got my $700 back for that stuff, it just felt like I would regret installing it after seeing this. We shall see.
Old 09-21-2016, 10:11 AM   #196
steveo3318
steveo3318's Avatar
I am not unhappy with the product by any means. My truck runs and cruises better than it ever has. Cold starts are a dream. Hot starts also. I just had one of the first runs with glitches in it. I have recently been adjusting my afr on cruise and I am seeing a good increase in mpg. It's a very good system.
Old 09-21-2016, 10:20 AM   #197
AnotherWs6
AnotherWs6's Avatar
I don't doubt that it's a good system when all is working. Reliability is a huge factor for me and I have read a decent amount about problems, especially with the fuel command center. And the FCC is one of the things that I really like about it, it truly makes this a simple install in the sense that you don't have to redo fuel systems, modify/change tanks.
I don't just pleasure cruise my truck. I commute in it and would like to start towing our camper with it. I also sit in a lot of traffic, so if the FCC doesn't like heat and it's 90 out while I've been doing literally 4mph for 45 minutes which happens sometimes........ Just makes me a little nervous.
Pop the hood after a good drive on a summer day and it is HOT under there. Feels like an oven, LOL. I don't think these trucks breath very well underhood.
Old 09-21-2016, 10:30 AM   #198
steveo3318
steveo3318's Avatar
Ahh I am picking up what your laying down now. When my pump got to hot I sit in one spot over an hr at idle with the ac on. Funny thing was the pump didn't die right there. It let me take off and get a mile down the rd and died. Now it came back on after 30 minutes cool down. Fitech did send me a brand new replacement which I have yet to install because after I told them what happened they told me the fuel pump idle parameter to lower because I am using the FCC and not an inline pump. The system comes set up for an inline with fuel returns. After I changed this I let the truck idle in the shop for an hr then drove it. Absolutely no issue on the same pump that crapped out the first time. So I am keeping the one they sent as a spare. Also they now have many many notes referencing to change that setting if you use a FCC. My 67 is my driver. I only have a company truck. I drive it everywhere and pull with it. I am not trying to sell you. Just giving you my experience with them.
Old 09-21-2016, 10:51 AM   #199
AnotherWs6
AnotherWs6's Avatar
That's good, pertinent information. I wonder if that was the cause of some of the other heat related issues I have seen referenced. Appreciated.
Old 09-21-2016, 10:59 AM   #200
steveo3318
steveo3318's Avatar
It seemed to be an ongoing issue that they felt was a big enough problem to start tagging the FCCs with a "this fuel idle parameter must be changed to -40 if the FCC is used". A lot of the problems are installer inflicted. Had a guy some how get my number and begged me to come find the problem on his system. After 20 minutes with a meter it was fixed. He ran the ignition source wire to an accessory plug which actually drops all power while starting. He couldn't get it to start without spitting and sputtering requiring a lot of throttle lol. Moved the wire and presto. Happiest guy in the world.
