Old 05-12-2017, 06:31 PM   #176
rusty76
rusty76's Avatar
Re: Introduction, nostalgia, and '68 build, oh my
It is actually 20th if anybody else is interested. I understand how it goes. I really hope one of these fine days I'll be driving my ole pickup to the show and not just working. Lol. I think if you keep at it you'll do good.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 05-19-2017, 08:05 AM   #177
hewittca
hewittca's Avatar
And the results are in: The timing set WAS changed, but the pan was never pulled. After pulling everything apart I discovered a scored damper and mangled bottom edge of the timing cover that were both contributing to my oil leak, a very loose timing chain, and a "custom" grooved cam gear! Overall I'm glad I decided to inspect this stuff because it all needed attention.
Fortunately, I finally reached the end of the parts destruction and started reassembly. Ultimately, I had to replace the rear main seal, oil pump (Melling M55), pan gasket, timing set (Cloyes 3001K), and rework the timing cover, but the bottom end should be sealed up nicely now.
I also noticed that my truck has entered the stage of the project where it begins to be absorbed by it's surroundings and become a place for additional storage in the garage. At least it's still getting used as a truck I suppose...
And lastly, some fitment motivation. While the truck's up on stands, I somewhat mocked up where the rear will be once I finally add in the drop blocks. Even with only 4" backspace on the 9" wide rears, I still think they are tucked a little too deep. I'd really love to throw the wider rear end in there with the 6 lugs from '69, but for the meantime I am going to put in some longer studs (Moser 7/16-20 x 2 7/8") and 1/2" spacers. I ran spacers for years on my Malibu, and with the Moser studs I think I'll be alright. I don't beat on this truck anywhere near what I did to my Malibu.
Next up is getting the transmission reassembled and installed. I hope to have that done within the next month. Then maybe I can actually get back to painting the bed.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 05-19-2017, 02:08 PM   #178
hewittca
hewittca's Avatar
My schedule cleared up for this weekend and I think I will try to make it out to the show (without the truck of course). I was going to go to the VW show at Farmington Dragway, but since I've sold my Beetle and have moved on to the truck, I think I'd prefer to attend this show. Where will you be working at the show?
Old 05-19-2017, 03:33 PM   #179
SCOTI
SCOTI's Avatar
Originally Posted by hewittca View Post
....I also noticed that my truck has entered the stage of the project where it begins to be absorbed by it's surroundings and become a place for additional storage in the garage. At least it's still getting used as a truck I suppose...
Nice investigative work on the motor. Prob extended it's life significantly because eventually there would have been a brief starvation issue that likely would have taken out a bearing or two.
As for the rear wheel being too far in, it looks good from the pic posted (and I am picky about it). It could be the angle but again, looks right to me. On the 'wider' 69/later 6-lug housing... Seemed the change to the wider housing happened sometime in 70. That's where there were 2 different length 6-lug housings. Measure the distance between the backing plate & T/A perch on your current housing to ensure you're getting a longer one if you go shopping around.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-19-2017, 05:15 PM   #180
rusty76
rusty76's Avatar
PM sent
My build thread
Crossmembers CC
Old 05-19-2017, 06:01 PM   #181
warbird1
Judging by the work you're doing on your truck, I'm pretty sure you could pull it off. I do really like the setup you are currently running, but your truck would look amazing on a set of big steelies. The guy I got my wheels from can do a 5 lug conversion for you, just sayin'
do you have this guys contact info? i would be VERY interested in a set of transits in 5 lug
warbird1 is offline   Reply With Quote
Old 05-19-2017, 08:57 PM   #182
hewittca
hewittca's Avatar
Great, thanks for the correct year to look for. I knew it was sometime during the 69/70 model years. You're right, from the photos I posted it really doesn't look off at all, but I like to have the rear wheels as tight as I can get them. I have about 1 1/8" on each side and I'd like to get it down to at most 1/2". Any more than that and at certain angles the rear wheels just don't look right to me.
Old 05-20-2017, 06:46 PM   #183
rusty76
rusty76's Avatar
It was great meeting you today. I wish it would have been a little cooler. A few more trucks did show up. This year seemed to be off. I feel the heat and the race down in Charolette may had something to do with it. Either way we still had fun and saw some cool stuff.
My build thread
Crossmembers CC
Old 05-26-2017, 01:25 PM   #184
hewittca
hewittca's Avatar
Re: Green Gus the 68 shortbed convert
Just wanted to update my thread to mention that I have had the title changed to better represent the project through the title. For some reason, the build thread was actually duplicated with a new title and my old thread titled "Introduction, nostalgia, and 68 build, oh my" is still active, but I will not post in there anymore.
As far as the truck goes, I am hoping to get it running again this weekend. I am running by to pick up some parts (for an unrelated project) from Larry (GR8-68) on Saturday morning, and then getting to work on the truck. An update will hopefully be posted soon.
Old 05-26-2017, 10:06 PM   #185
webberjames95
loookin amazing dude. fitment is sick
webberjames95 is offline   Reply With Quote
Old 05-27-2017, 08:10 PM   #186
rusty76
rusty76's Avatar
Bought time you changed the title. Lol.
My build thread
Crossmembers CC
Old 05-29-2017, 04:32 AM   #187
NewType72
NewType72's Avatar
I'm definitely going to look into those moser studs. I have 20 x 9.5's all round and they severely lack width in the rear so I see spacers in my future lol
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 06-01-2017, 08:27 AM   #188
hewittca
hewittca's Avatar
Green Gus is on the road again
I had a chance to work on the truck last night and get it back down on all fours to test everything I did to it. Ultimately, we rebuilt the transmission, replaced the rear main seal and oil pan gasket, and replaced the timing set. After rolling it outside, we topped off all the fluids and started it up.
I'll be honest, I was a bit nervous because we fixed a number of issues at once and messed with all the fluid carrying components (oil, coolant, and trans) so the possibility for at least a leak was present. Diligence paid off, however, because she started right up, everything sounded and looked right, and there was not a drop of fluid leaking anywhere. After warming up, it was time for a test drive and again, everything felt great.
The trans shifts firmly and quickly now and the engine idles smoothly with no inconsistency like it used to. The only thing is that I've had the cobbled together exhaust out and in 3 times now since I got the truck and it's on its last leg. With the worn out glasspack and 2" single pipe exhaust it sounds like a tractor, but I plan on doing exhaust soon. First thing's first though, I think it's finally time for some paint!
Old 06-01-2017, 11:12 AM   #189
knomadd
knomadd's Avatar
Sounds pretty good for a tractor! Nice job so far.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 06-01-2017, 11:22 AM   #190
GR8-68
GR8-68's Avatar
Sweet !!! Great to see it back on the ground And it sounds great
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 06-01-2017, 02:16 PM   #191
preacher anthony
Good job! Changing cam and lifters in mine. Had a Comp cams 282S, solid lift. Truck needed a 3k stall and low gears. Way too much for cruising around w/ the grands.
preacher anthony is offline   Reply With Quote
Old 06-01-2017, 02:25 PM   #192
hewittca
hewittca's Avatar
Green Gus the yard art
And here she sits as yard art at my dad's house until I can find some time to paint the bed. The tailgate is off in preparation for paint. She also gets to hang out with my dad's '75 dually for a while. He has had this truck since 1988 or so and before that it was a PA state utilities truck.
Old 06-01-2017, 03:27 PM   #193
lolife99
67-72 parts collector,…
lolife99's Avatar
Wow. What a thread!
I just read this from start to finish.
Excellent EXCELLENT work.
Love the pics and all the info.
I can't believe I hadn't seen this thread before now.
Keith
Convert to disc brakes.
Old 06-01-2017, 05:24 PM   #194
rusty76
rusty76's Avatar
Glad to see Gus back together. Can't wait to see it in person one of these fine days.
My build thread
Crossmembers CC
Old 06-01-2017, 06:42 PM   #195
Derek@AccuAir
Derek@AccuAir's Avatar
Sounds good! For some reason nothing sounds as good as a small block with a cam to me.
Can't wait to see it with the bed painted!
BUILD IT! DRIVE IT!
My Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=734098
Derek@AccuAir is offline   Reply With Quote
Old 06-02-2017, 08:29 AM   #196
hewittca
hewittca's Avatar
Wow. What a thread!
Thank you, that means a lot!
I keep saying to myself, I'll make it to next months round of cruise-ins, nope now next month, etc... I originally planned to make it to the first cruise-ins of the year, now I'm thinking I might make it to the last.
Thanks! I agree. I had a 383 with a 3" x-pipe in my Malibu and it sounded lethal. I loved that thing. Maybe I shouldn't have let it go... oh well, I do love the truck too.
Old 06-05-2017, 02:36 PM   #197
Derek@AccuAir
Yeah, that's the sound I'm talking about! I've heard a lot of built LS stuff, and never heard one sound like that. What brand were the mufflers on the Malibu?
BUILD IT! DRIVE IT!
Old 06-05-2017, 03:57 PM   #198
hewittca
hewittca's Avatar
It was a Pypes x-pipe kit for the Malibu that came with their "street pro" mufflers. I bought it for the pipes mostly, but ended up liking the mufflers too, so I kept them.
Old 06-06-2017, 11:51 AM   #199
NewType72
NewType72's Avatar
I would say Gus has some really nice company at your dads place for sure!
- Dylan
(209)-985-7721
Old 06-07-2017, 01:26 PM   #200
MojoZA
Wow...fantastic read. That 2.5" drop on the bin/chassis is the business, truck appears to be lowered but retains the std suspension. Brilllant.
MojoZA is offline   Reply With Quote
